Old Apr 06, 2007, 05:51 PM
switchman is offline
Find More Posts by switchman
Joined Mar 2007
Help!
Esky 0905A simulator - XP Need driver help
I am trying to get my new Esky 0905A simulator controller to work under Windows XP. I need the help of someone who’s controller is working under XP. If you could look and tell me what drivers are loading for the controller, I would appreciate it.
If you do not know how to find this information, the steps below will show you how to do it.
Steve
Go to: Start-->Control Panel-->System
Double click System to open it.
Select the Hardware Tab
Click the Device Manager Button
Scroll to the bottom of the list till you see “Universal Serial Bus Controllers”. If it has a plus “+” next to it, click the “+” to expand the list.
Plug your Esky 0905A Simulator Controller into a USB port. You should the see it appear in the “Universal Serial Bus Controllers list.
I need the name of the device that just appeared?
Mine is “Unknown Device”
Right Click the new item that just appeared. Select Properties from the drop down list.
Select the Driver Tab. What does you computer list for the following items:
Driver Provider:
Driver Date:
Driver Version:
If there is any other information, can you please provide it.
Click the details Tab
In the drop down list Select “Hardware ID’s”
You should se a list of text in the box below.
Left click your mouse in the box and select all of the text.
Use the keys Ctrl-C to copy the text.
Paste the text into your response.
switchman is offline Find More Posts by switchman
Old Apr 06, 2007, 06:49 PM
skirtz is offline
Find More Posts by skirtz
Joined Sep 2002
There is nothing to it. It is plug and play. Just plug in the controller and select "Start", then "Control Panel" then "Game Controllers" and you will see the controller listed as "ADC". Click on it and you will see red control bars. Move the sticks and the bars will move. You are all set. You may select "Properties" and do "Calibrate". That is all.
Stefan
http://rcflightsim.com
skirtz is offline Find More Posts by skirtz
Old Apr 06, 2007, 07:18 PM
Joined Mar 2007
Originally Posted by skirtz
Just plug in the controller and select ...
Thats the problem, its not plug and play on my system. XP sees a USB device but does not recognize it. When you look at the controllers, there is none listed. This is why I was asking for someone who has one working to tell me what driver windows is assigning. I am hopeing I can then locate the drivers and manually assign them. That is assuming my controller is OK.
Old Apr 06, 2007, 07:38 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
My Esky works great. I just did as your instructions and there is no change in the list under "Universal Serial Bus controllers when I plug or unplug the Esky. XP does give a sound signal when I plug in or unplug the Esky, but it does not show up in The Universal Serial Bus controller list.
Under "Universal Serial Bus controllers I have 4 "Intel(R) 82801EB USB...." listed. There are 4 "USB Root Hub" listed. I think these must be my 4 USBs on my mother board. There is also a "USB COmposite Device" but this does not seem to change when I plug in or unplug my Esky.
Anything else and I will give it a go,
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Apr 06, 2007, 07:39 PM
skirtz is offline
Joined Sep 2002
Have you tried on another USB port? It may be the port. Or, try the unit on another computer so you find what is the problem - your computer or the E-Sky unit. I have tried many of them and they all worked, so the chance the unit is bad is small (but indeed not zero).
Stefan
Old Apr 06, 2007, 07:45 PM
Joined Mar 2007
I've tried two computers with the same exact results. I am thinking I got a bad one. As I purchased it on E-bay, I am probably out of luck.
Old Apr 06, 2007, 08:55 PM
skirtz is offline
Joined Sep 2002
Try contacting the seller, in most cases they will get it back if not working.
Old Apr 06, 2007, 09:20 PM
Out the Window
Joined Jul 2004
Under the "Human Interface devices" there is a listing for "HID-compliant game controller"...this must be it.
The properties for it is :
Driver provider: Microsoft
Driver Date: 7/1/2001
Driver Version: 5.1.2600.2180
Digital Signer: Microsoft Windows Publisher
Under Details:
Device Instance Id
HID\VD_0402&PID_)0402\6&21782538&0&0000
Hope this helps
Old Apr 06, 2007, 11:03 PM
Joined Mar 2007
Thanks, I am going to see what I can do with this info.
Old Nov 28, 2008, 03:23 PM
Maximilianus is offline
Find More Posts by Maximilianus
Mr. too many toys
Maximilianus's Avatar
Amsterdam, Netherlands
Joined Sep 2006
Had the same problem with this USB simulator. Could not find any proper driver! The automatically found driver would not work.
Then I looked for a driver in the windows/system32 and it found something. So finally its working!!
Maximilianus is offline Find More Posts by Maximilianus
Old Feb 04, 2010, 04:47 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
My Esky Simulator was working perfectly until today. Now Window XP stated the device is not working properly. I have uninstall the device driver and reinstalled it numerous times with no luck.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Feb 05, 2010, 02:44 AM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
Do you use windows updates.. could be that one of those has knocked it out
Malc C is offline Find More Posts by Malc C
Discussion Esky 0905A Simulator Controller Mods? duckman6 Simulators 4 Sep 14, 2008 09:47 PM
Discussion Flight Simulator 2004 Windows Xp Need Help jgregory Simulators 1 Jan 01, 2006 06:00 PM
My Esky HB2 3d, need a little help gns30 Micro Helis 7 Mar 27, 2005 02:30 AM
need some help building my Rally XP Pics included kushal_22 Parkflyers 5 Jul 03, 2002 12:23 PM
Need JR XP 8103 programming help! jimmy6819 Electric Plane Talk 1 Jul 09, 2001 04:30 PM
