Old Oct 15, 2002, 09:22 PM
LoneRanger is offline
Find More Posts by LoneRanger
Ocala, Fl
Joined Jan 2002
Cirrus Vrs. Hitec micro servo's
I am going to buy 2 or 3 small servo's (not HS-81 small)
more like HS 55's
so I was comparing the HS 55 to the cirrus servo's....
this is the HS 55=
Torque: 4.8VDC: 13oz-in.
Speed @ 60 Degrees: 4.8VDC: 0.17 seconds
Bearing Type: None (Case serves as bearing)
Case Size: 0.9"x .46"x .95"
Weight: .32oz
Wire Length: 6.5" (Includes plug)
this is the Cirrus CS 21BB=
Torque: 19.0 Oz per inch @4.8V
speed: .09 sec @ 60 deg.
Bearing: ball bearing
Case: .86 x .43 x .77
weight: .32 Oz
Wire length: unknown
it would appear the Cirrus servo blows away the Hitec as they are the identical weight and the cirrus is actualy a bit smaller, and has WAY more power and Torque.
does any one use cirrus servo's?
how do they operate, any problems?
do they center well after much flying time?
Do they get sloppy?
are they jitery?
any and all opinions are much appreciated.
LoneRanger
LoneRanger is offline Find More Posts by LoneRanger
Old Oct 15, 2002, 10:03 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Cirrus 21bb
Well I have some Cirrus 21bb servos and they seem to work very well for me. I am planning to install two in my T-33. I dont think that I would install them in my Jepe F16 But they have their place and work well when not put into super fast planes. That's just my opinion. But when I need really good servos like for my F16 I bought Volz Micro Maxx X's for the tailerons. Try em they work well.
Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Oct 15, 2002, 10:18 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Performance always has a cost. The high torque and speed of that Cirrus servo requires a large current. 3 of them have overloaded the BEC on small ESC's. Some people have added a resistor to slow them down.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Oct 15, 2002, 10:27 PM
sguty is offline
Find More Posts by sguty
Senior Member
sguty's Avatar
Redmond, WA, USA
Joined Oct 2000
The one problem I've had with the CS-21s is that they can draw a lot of current when working hard--that power and speed has to come from somewhere, right? Can be a problem if you're using a BEC circuit that can't keep up/is at the max cell count count. I had some thermal cutouts when using them in a Ky F-16 with the max cell count for the ESC (Dragon-35). Going to a separate Rx pack (and checking the charge before every flight) fixed the problem.
I've heard reports that they can draw up to an amp apiece when stalled, though if you're stalling them with flight loads you need to be looking at a higher torque servo anyway...
sguty is offline Find More Posts by sguty
Old Oct 15, 2002, 11:27 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
When speaking of micro I don't think the Cirrus are a slight bit smaller but rather a great deal smaller! I use to use nothing but Hitec HS-55's but since discovering Cirrus servos I will never go back! Just my opinion mind you!
John
http://www.aerc.biz
drbird is offline Find More Posts by drbird
Old Oct 16, 2002, 03:34 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Servo's
Cirrus is a good servo for a great price.And actually were all suckers cause were paying for a name!LOL Cirrus is Hitec. Break one sometime and call Cirrus customer service,you'll get Hitec on the phone!haha And break aprt a Hitec feather sometime then put a Cirrus MX-4 next to it and laugh at the similarity.
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Oct 16, 2002, 08:04 AM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I have the cs 21bb & cs20bb, ben using them since there intro.
I have the cs20's in my t-33( one in each wing panel) and have no problems to date. My balsacraft sea fury has the cs21's no problem. I would stress free moving surfaces, as much as possible
to lower current draw as much as possible. This is I feel relevent in all RC applications. Steve
St. Martin is offline Find More Posts by St. Martin
Old Oct 16, 2002, 09:54 AM
Ocala, Fl
Joined Jan 2002
wow, over night it would seem that every one realy sems to think they are pretty good servo's!
I guess I have to order a few and see how it goes!
I have a Hobby People catalog, is there any other shop or online store that you all use to get these servo's....?
thanks ,
LoneRanger
Old Oct 16, 2002, 10:01 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Get mine at the LHS. I try to use the HS whenever poss. Steve
Old Oct 16, 2002, 12:08 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
You might try http://www.aeromicro.com - I think thats where I got mine but I'm not for sure?
John
http://www.aerc.biz
Old Oct 16, 2002, 12:30 PM
Joined Aug 2002
You got it
St.Martin hit it on the head. Free surfaces. Heck I'm running about a 90 mph plane with GWS micros on it and i just did the surfaces correct, kept linkage at proper angles and no slop and this thing does snap rolls at speed like you wouldn't believe. When your dealing with mechanical leverage on short arms every degree of deflection counts. I'd like to do a test sometime to see on an average, how many of the advertised ounces in torque actually ake it to the surface in average applications.
Old Oct 16, 2002, 12:46 PM
Balsa Hound is offline
Find More Posts by Balsa Hound
SW Vermont
Joined May 2002
I have 8 CS-21BB servos. The youngest is three years old, the oldest is more than 6 years old. All have been in all manner of planes from little HLGs to a monster 6-foot 4-lb electric. And all have been through crashes that I figured shoud have been the end--but they're still running strong.
In my opinion, these things are among the best servo bargains on the market today. I *WILL* be buying more (as soon as I've laid aside enough spare change)!
Balsa Hound is offline Find More Posts by Balsa Hound
Old Oct 16, 2002, 03:38 PM
sguty is offline
Senior Member
sguty's Avatar
Redmond, WA, USA
Joined Oct 2000
servo load worksheet
Totally agree that energy lost in mechanical binding helps no one, but do wonder how well those GWS micro servos are going to hold up in a 90 mph plane with any serious control area or deflection. There was an article in RCM back, I think, in April 2000 or thereabouts, on servo loads with a full blow-by-blow on the equations. Author said he'd created a worksheet in Excel to do the calcs. In one of my geekier moments I tried recreating his results, came up with the following worksheet:
You need to know the area of the surface, location of its centroid (center of area) from the hinge line, desired deflection, and the moment arms of the servo arm and control horn--those are the fields in yellow--and it gives you servo force required for a variety of airspeeds.
Old Oct 16, 2002, 08:25 PM
Joined Aug 2002
cool spread
I like that program. Gives you a second opion at the least to make dure you've got the math right.
For Sale Hitec Park Flyer 3 Channel w/ RX and 2 micro servo's PRICE REDUCED !! Crash549 Aircraft - General - Radio Equipment (FS/W) 4 Sep 16, 2006 10:41 PM
WTB Sub-Micro Servo(s) T-Bo Aircraft - Electric - Airplanes (FS/W) 12 Feb 21, 2003 02:50 PM
mixing Hitec and GWS servo's beefa Thermal 5 Oct 31, 2002 10:22 PM
FS:Volz VS-100 Micro servo's (10nip) DesertRC Aircraft - Electric - Airplanes (FS/W) 5 Sep 27, 2002 02:59 PM
Used Micro Servo's strouse Aircraft - Electric - Airplanes (FS/W) 1 Sep 19, 2002 06:29 AM
