Old May 18, 2012, 09:30 PM
Hogwit is offline
Find More Posts by Hogwit
Joined May 2012
How about 24 stator teeth and 28 magnets? I burned my Turnigy Rotomax 1.60 and would like to rewind it...
Hogwit is offline Find More Posts by Hogwit
Old Jul 08, 2012, 05:03 PM
xener is offline
Find More Posts by xener
United States, GA, Alpharetta
Joined May 2011
where are you buying a wires for rewinding, please ?
xener is offline Find More Posts by xener
Old Sep 11, 2012, 08:09 PM
minimicrorc is online now
Find More Posts by minimicrorc
Joined Apr 2012
oooooooooooooookkkkkkkkkkkkkkkkkkkkkkkkkk
minimicrorc is online now Find More Posts by minimicrorc
Old Sep 11, 2012, 10:20 PM
Russ The Flyer is offline
Find More Posts by Russ The Flyer
It flies or it dies
Russ The Flyer's Avatar
Deville, Louisiana
Joined Sep 2008
If you're asking me then yes. It's here --->Right here
Russ The Flyer is offline Find More Posts by Russ The Flyer
Old Nov 03, 2012, 02:45 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Rewinding Scorpion SII 3020
I've got a Scorpion SII 3020 780kv that I want to rewind to be an 8turn 1110 kv motor for my Z2.
Anyone have experience with this? What type and gauge of wire should I use?
Here are the specs of the 1110kv:
Stator Diameter 30.0 mm (1.18 in)
Stator Thickness 20 mm (0.79 in)
No. of Stator Arms 12
Magnet Poles 14
Motor Wind 8 Turn Delta
Motor Wire 17-Strand 0.25mm
Motor Kv 1110 RPM / Volt
No-Load Current (IO/10V) 2.08 Amps
Motor Resistance (Rm) 0.016 Ohms
Max Continuous Current 60 Amps
Max Continuous Power 840 Watts
Is this a 12N14P?
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Nov 03, 2012, 09:34 PM
It flies or it dies
Deville, Louisiana
Joined Sep 2008
Now this is knowledge I'd like to have.
Russ
Old Nov 05, 2012, 03:06 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Magnet Poles 14
Is this a 12N14P?
A 10 turn Delta would be pretty close. Try using a single strand of 23AWG wire for this. It is dLRK.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 01, 2012, 04:05 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Ok, rewond, attached ESC and all it does it stutter. Everything checked out but I think I might have gone "backwards" when winding. So I used this pattern "AaAabBbBCcCcaAaABbBbcCcC" , but I went clockwise from the bottom view.
Do I need to redo all the wiring or is it maybe just the connections?
EDIT: Crap, I think I wound the second set of phases the same as the first.... that would do it.
brontide is offline Find More Posts by brontide
Old Dec 01, 2012, 09:34 PM
brontide is offline
Joined Sep 2012
Done. Rewound and tested. The radio shack 30 gauge magnet wire is really hard to solder right, had to do it twice before it took to the bullets. Thanks for this thread, lots of good info! Finished up this job with heat shrink, bullets, and a dab of hot glue to prevent movement.
Old Jan 10, 2013, 03:56 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Subbed for reference. Thanks to all for the great info!
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jan 28, 2013, 02:37 PM
Nashville TN.
Joined Mar 2006
I have a question on WYE termination.
Does it matter whether you join the beginning of the wire or the end of the wire to terminate?
And what are the consequences of joining the beginnings? (Yes....I just did.)
Got info back from Magnus that it does not matter. Just for info.
Old Mar 14, 2013, 12:29 PM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
is that what i need for wire ?
http://www.abra-electronics.com/prod...gnet-Wire.html
bakchos is offline Find More Posts by bakchos
Old Apr 02, 2013, 04:17 PM
Njoro is offline
Find More Posts by Njoro
Joined Jan 2009
Hi Alex
Wow I just found this thread while serching the web for more info on motor winding it's just what I was looking for thanks for the info, I shed a motor in flight and it ripped the rotor away from the stator. While reading about winding motors for camera gimbles on FPVUk-HUB I realised I could have a go.
I was lucky that the wire was easy to remove, I measured it at 36SWG 4 strands; I could only get 34 or 38. I used 38SWG 20 turns 7,7,6 Delta. I've been lucky in that I only had to rewind 1 phase which I started on the wrong stator, the motor is runing very well very smooth on Trunigy Multistar 30A Opto that I flashed with SimonK.
I'm riding FPV on a Quad that weighs in at 1.512Kg which is asking alot more than the motors are rated at which is 1,280Kg @ 980KV. I'd like to lower the KV to drive a 10x4.7 on all 4 motors but I'm not so sure what gauge to go for and turns. the motors are 2212/14. It was a great feeling to see a dead motor come back to life.
Pictures
Njoro is offline Find More Posts by Njoro
Old Apr 16, 2013, 10:45 AM
nothingman is offline
Find More Posts by nothingman
thump thump thump
nothingman's Avatar
Canada
Joined Oct 2012
HK NTM 42x38mm 750Kv `link wont paste`
I would like to rewind this motor or one of similar size to around 300-350Kv
12v 3s
As a spare parts learning project I plan on using a set of 450 blades to make a fan for my garage. This would be pwrd by excess power from my solar panels.
How does max safe power change when you rewind the same motor
Does the AWG of the wire dictate the max amount of Watts.
Is it best to pick the number of required turns and then the lowest gauge that will fill the stator for the most PWR
nothingman is offline Find More Posts by nothingman
Old Aug 05, 2013, 11:58 AM
disneytoy is offline
Find More Posts by disneytoy
Joined Feb 2012
Any rewinders here? I'm going to rewind a 5010 -360kv RCTimer motor. I've read to use .15mm wire. But all I can find here in the US is by guage. AWG. The closest I can find is 35 AWG which it says its like 0.14mm. Is that okay?
They also have solderable and non solderable, is one better than the other?
Finally how long of a wire would I need per motor? I ask because they sell from 75 feet to 5000 feet reels. I have no clue how many feet (estimate per motor). I don't want to buy 5000 feet if I just need 100 feet.
Thanks.
Can't wait to try this.
Is this good: http://www.ebay.com/itm/Magnet-Wire-...#ht_228wt_1157
disneytoy is offline Find More Posts by disneytoy
Mini-HowTo Brushless Motor with Convertible Delta or Wye Winding LBMiller5 Power Systems 7 May 29, 2015 10:27 AM
Question Brushless motors: Geared or Direct Drive? FirstShirt Beginner Training Area (Aircraft-Electric) 2 Jan 24, 2007 09:35 PM
Discussion Are brushless motors dc or ac? erfolg Electric Motor Design and Construction 39 Dec 26, 2006 06:37 PM
GBx Double..Wye or Delta..or what? -=SLaPPiE=- Power Systems 13 Apr 29, 2005 12:34 PM
Are AXI's wound wye or delta ? raymcm Power Systems 11 Feb 17, 2005 05:45 PM
