Old Jun 19, 2008, 10:00 PM
MTXMUGEN is offline
Find More Posts by MTXMUGEN
Electron Abuser
MTXMUGEN's Avatar
Akron, Ohio
Joined Aug 2006
Originally Posted by kdahlhaus
I'll have to measure it. Just rewound with 20 turns of 26 gauge. Will have to wait until tomorrow to try it out.
20 turns sounds more like it but still a little high. 21 is the most number of turns that i have ever seen in a motor, and that was on a 10 gram from lazertoys. most my lower kv motors depending on size, are 6-15 turn wye, usually with 24 awg
MTXMUGEN is offline Find More Posts by MTXMUGEN
Old Jun 20, 2008, 06:42 AM
kdahlhaus is online now
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Thanks. 20 turns of 26 wasn't much better. I'll give it a go with 24 awg, maybe 10-12 turns.
kdahlhaus is online now Find More Posts by kdahlhaus
Old Jun 20, 2008, 02:50 PM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Less turns = higher speed = higher Amp draw. For a motor this small you are going to need a gearbox if you want to spin a 9" prop efficiently.
You want more turns to spin a bigger prop. However, If the iron is getting hot, you are likely pushing the motor into saturation, which I would expect from such a small motor and big prop. You might need to go to a smaller propeller or put on a gear box. Small motors are very inefficient where torque is needed.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Jun 20, 2008, 03:33 PM
kdahlhaus's Avatar
Joined Mar 2002
Thanks Alex - I was beginning to suspect the need for a gearbox.
Old Feb 09, 2009, 07:31 AM
congcon97 is offline
Find More Posts by congcon97
Joined Jun 2007
Hi!
I recently saw ur thread abt making or rewinding brushless motor. I got a brushless but it becomes too hot. 2800kv running with my trex450 heli ESC. The heli motor is stock Align430 size. That motor is my spare motor. Could u pl tell me how to rewind this motor? Someone said there might be short in the coil. What u say. Anyway it was like this since I bough it.
congcon97 is offline Find More Posts by congcon97
Old Feb 09, 2009, 07:48 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
First test the motor for a short. To do this use a ohmmeter (or multi-tester) and check for continuity from any motor lead to the motor shaft. If there is continuity, you have a short and the motor needs to be rebuilt.
In any case, the wind on that motor is ABCABCABC, just as the motor I rebuilt in this thread. Count the number of turns as you unwind it. If you want to change the motor's kV the formula is:
old kV/desirded kv * old #turns = new # turns.
That motor rewinds well with 24 AWG wire.
-Alex
Old Feb 09, 2009, 11:22 AM
MTXMUGEN is offline
Electron Abuser
MTXMUGEN's Avatar
Akron, Ohio
Joined Aug 2006
Originally Posted by congcon97
Hi!
those motors are tricly to get apart. you have to lightly heat the back of the motor wth a torch to deactivate the glue. after it gets ~220*f try unscrewing it wth pliers in the 2 little holes. the stator should come out with the bearing tobe right after you get the back off the motor. if it doesnt come out easily just heat it up a little bit more and twist the backplate back and forth.
putting a old screw in the front of the motor and puting the screw and shaft in a vise is the best way to hold the can from spinning. one you get to removing the stator from the backplate, simply put the sator in the vise. be sure to put a couple pieces of wood on either side of the stator to prevent damage
Old Feb 09, 2009, 08:22 PM
NanoSio2 is offline
Find More Posts by NanoSio2
Remember the 131st TFW MO ANG
NanoSio2's Avatar
USA, MN, Apple Valley
Joined May 2005
FYI Episode #79 of the ATTF podcast had a good description of the differences between WYE and Delta motor winds...
NanoSio2 is offline Find More Posts by NanoSio2
Old Feb 10, 2009, 07:27 AM
Joined Jun 2007
This is what I got from the motor. I'm sorry I was not able to unwind the stator as a result I had to destroy it. But the can, rotor magnet, bearings, bottom cover is still ok.
That coil was too messy to unwind actually. That's why maybe it used to get extremely hot. Now I need to purchase the stator(that broken part in pic) to rebuild this motor. This motor had 16 peice of extremly powerful magnets inside the rotor.
Now asking u, is this motor can be rewind? Can I buy this stator? This is a 400LF Align motor. Rewinding is a great knowledge and fun I believe .
Old Feb 10, 2009, 07:48 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I forgot to mention that many motors are varnished or epoxy dipped to keep the wires in tight. This makes them a pain to unwind. The best way to unwind them is to put the stator in the oven at 200-250 degress for 10 minutes. This loosens the varnish so the motor may be unwound. Unfortunately, you'll need to wear gloves, which makes it hard too since the unwinding must be done while the motor is hot. Do not put the rotor in or the magnets will be damaged.
As for that motor, good luck finding another 6 pole stator. You might need to get a 9 pole to replace it. The original appears to be a 6N8P. The magnets in the can are arranged in either a Halbach array, or a double pole pair. In the case of a double pole pair, you have 16 usable magnets. If they are a Halbach array (which would be my guess) you only have 8 usable poles since 8 of the magnets are magnetized through the side rather than the top.
What you'll need to do is measure diameter and length of your old stator and the check around to see if someone carries a stator that will fit. Perhaps GoBrushless 20mm 9 pole stators would fit? The pattern for a 9 pole stator with 9 magnets is: AaABbBCcC. Always terminate this as a WYE or it will vibrate badly.
Good luck,
-Alex
Old Feb 10, 2009, 08:20 AM
Joined Jun 2007
Alex,
That's what happend. I tryed to unwind but I was stripping the wires. I couldn't even imagine that is due to glueing over the coil. Then insistly I broke it down.
However, what is gone that's gone. Now why not looking for 6 poles stator. 9 poles might need reformation/rearrangement of the rotor magnets.
The other thing to mention I'm brand new in BL motor. I don't got any preknowledge abt AaABbBCcC. I'm a grade 1 student in BL motor tutorial .
Old Feb 10, 2009, 08:33 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
And I just got done with explaining orientation and a Halbach array and Delta/Wye terminations which is college level physics!
6 pole stators are rare. They are very hard to come by. However, 9 pole stators can be found all over the place. They are very common. I suggest changing to a 9 pole simply for parts availability.
With the 9 pole stator, you can keep your current rotor and magnets. You must change your winding pattern to AaABbBCcC. The capital letters are wound clockwise and the lower case letters are counter clockwise. Basically you wind the first pole forward, the one beside it reverse, then the next forward again (and that completes A phase). The you get another wire and do it again on the next 3 poles (B phase) and a thrid wire on the last 3 poles (C Phase). The 3 ending wire leads get soldered together, and the three beginning leads get connected to your ESC.
You might want to do some reading here too: http://www.rcgroups.com/electric-mot...struction-361/ There is a lot of information there.
-Alex
Old Feb 12, 2009, 09:58 AM
Joined Jun 2007
Alex,
Just wish to how was ur feeling when ur very fast rewinding motor started turning? I guess u didn't start from the expensive kits or prebuilt one.
I will start from the cheapest one.....once I see I can make it turn I will be able to be a harcore motor guy I got that confidence.
Old Feb 17, 2009, 09:49 AM
Joined Jun 2007
In the picture, is it the right config of the 9 pole,16 magnets motor ? It looks easy but is there any English translator of this pic? Waiting for ur reply.
Old Feb 24, 2009, 09:01 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Alex,
My first motor was a BP-21 given to me by critterhunter. Yes it was an incredible feeling when it first ran... then I proceeded to burn it up If anyone wants to learn the basics of rewinding, get a BP-21 (BM2408-21T). They're cheap and simple to rebuild. At $6 new, how can you go wrong?
Mini-HowTo Brushless Motor with Convertible Delta or Wye Winding LBMiller5 Power Systems 7 May 29, 2015 10:27 AM
Question Brushless motors: Geared or Direct Drive? FirstShirt Beginner Training Area (Aircraft-Electric) 2 Jan 24, 2007 09:35 PM
Discussion Are brushless motors dc or ac? erfolg Electric Motor Design and Construction 39 Dec 26, 2006 06:37 PM
GBx Double..Wye or Delta..or what? -=SLaPPiE=- Power Systems 13 Apr 29, 2005 12:34 PM
Are AXI's wound wye or delta ? raymcm Power Systems 11 Feb 17, 2005 05:45 PM
