Old Oct 06, 2008, 11:04 AM
T3chDad is online now
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I hope you didn't misunderstand me...I use program mixes in the Tx, not external mixers on the servos.
Anyhow, good luck with the build. Are you doing the TV version or a single motor config?
T3chDad is online now Find More Posts by T3chDad
Latest blog entry: I've been flying!
Old Oct 06, 2008, 12:14 PM
Gandalf_Sr is offline
Find More Posts by Gandalf_Sr
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
I didn't misunderstand but thanks for the concern. Given my desire to add gyro stabilzation, I have to move the mixing onto the airframe.
RX >> Gyro >> Mixer >> Servos
Gandalf_Sr is offline Find More Posts by Gandalf_Sr
Old Oct 07, 2008, 02:03 PM
kscbob1 is offline
Find More Posts by kscbob1
Semper Fi, Do or Die
kscbob1's Avatar
Titusville, Fla
Joined Jan 2003
Hey Ted.
Answers:
1) Four servos. One for each aileron surface and one for each elevator surface. The elevators work independently of each other. I have two mixes that allow them to function as elevons as well as just elevators.
I'm wondering if you could get the same end result with only one aileron servo and two elevator servos. I have a DX-7 and am not a fan of its 3 position flap switch. I only use flaps now on my F-14 for wing sweep. Never used my flaps that much on my old Eclipse 7 so it would save me one servo for rudder which I do use. I'll have to experiment but at the moment I don't have a bird with dual elevator servos other than the F-14 and that won't help as it has no ailerons.
BB
Semper Fi
kscbob1 is offline Find More Posts by kscbob1
Old Oct 07, 2008, 04:51 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Sure...I just didn't want to do it like that so I had the option to mess with flaps if I wanted to. I also have a plethora of other mixing options with one independent servo for each control surface.
I don't think this model is suited for one servo for both ailerons if you wanted to do that. Where would you put it? How would you link to the control surface?
Old Oct 07, 2008, 08:17 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
hello everyone,
i finally mustered up the nerve to buiold one. from the initial cutting of parts i almost got frustrated due to the number of pieces, then i said to my self, i didn't have to finish it in one day.....so i took my time and finished it in a week
AUW 24 oz
power set up: grayson smj, 40 amp esc, 6x4 prop, 2000mah 25c 3s and 2 9g servos
a bit of concern arose after reading through, would elevons as the only control measure pose a problem? would i need to install ailerons too?
TIA
Carl
smkn951 is offline Find More Posts by smkn951
Old Oct 08, 2008, 01:23 AM
Nadim is offline
Find More Posts by Nadim
Nadim's Avatar
Linköping Sweden
Joined Nov 2006
Ohh man she’s going to be really fast at 24 oz with the mega jet… you don’t really need ailerons elevons is just enough. Try it out with only elevons you could always add the ailerons later if you’d want to. Now how about some pictures.
Nadim is offline Find More Posts by Nadim
Old Oct 08, 2008, 02:19 PM
kscbob1 is offline
kscbob1's Avatar
Titusville, Fla
Joined Jan 2003
=T3chDad ...
Pretty much the same way Steve configures his rudder servos on the twin vertical stabilizer designs. Just behind the battery compartment and then run pushrod wire through the flexible antenna/pushrod tubing. I have plenty of aileron torque rods left over from departed GWS warbirds that work very well or I make my own out of brass rod and sheeting.
BB
Semper Fi
Old Oct 08, 2008, 02:29 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Ah...I understand now. Not a bad idea.
Old Oct 09, 2008, 01:12 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
soon as i get home today i'll post some. please be gentle, i 'm not quite as an artist like you. shhot, i can't even do a stick figure.
TIA
Old Oct 12, 2008, 05:13 PM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
Finnally some flight pictures
Beautiful NE fall afternoon and one of my flying friend took a few pictures.
DAF
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old Oct 12, 2008, 07:08 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Smkn51: Awesome job. She looks great. Have you had your maiden yet?
Ralph: Very nice bird. Great pictures.
Old Oct 12, 2008, 08:56 PM
tomcat600 is offline
Find More Posts by tomcat600
Align EP Helis
Joined Mar 2008
I was wondering will there be a building tips for this Park Jet? Really interested in getting one but how do you get those characteristic scale look of this SU-37 what tools and tricks to get it properly shaped and aerodynamic?
Thanks.
tomcat600 is offline Find More Posts by tomcat600
Old Oct 12, 2008, 09:35 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Tips and tricks are all through the thread. The assembly instructions located at 6mmfly.com are also very helpful.
Old Oct 12, 2008, 11:14 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Thanks.
Here's a link to the scratchbuild version of the Su-37 construction guide, with everything you need to know to build this bird. The manual at 6mmflyrc.com covers the kit version, which is similar to but slightly different from the scratchbuild version.
http://www.parkjets.com/Su-37_Constr...ratchbuild.pdf
Steve
jetset44 is offline Find More Posts by jetset44
Old Oct 13, 2008, 09:23 AM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
T3chDad,
maiden was successful, very stable plane. now time to put a lil more paint on her.
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
