that's what these forums are for, to share ideas.But as Steve points out the bigger problem will be protecting the belly without adding too much wt. |
http://www.rcgroups.com/forums/showt...66686&page=193 I used carbon fiber tow which is basically long lengths of loosely bundled carbon strands. You lay down a thin coat if wbpu, lay down the fibers, and coat the top with more wbpu. Very similar to glassing. Makes for a very strong landing surface with not a lot of weight gain... |
Joined Jan 2013
SU-27 Test Pilot paint job
Well got the paint job done..... a little blotchy in places... ah well.
Decided to go with SU-27 Test Pilot demonstration Team colours. Here is the link http://www.mars.slupsk.pl/fort/sukhoi/big/su27pd[598].jpg Now I'll have to see if I can make some decals up.... How do you do that? Still a bit concerned about the power plant for this 43 oz !!!!! model. Using a Grayson Hobby Super Mega Jet, 50 Amp Esc and 2200 Mah Nano tech 25-50 C with a 6x4 prop. Only getting about 275 watts on WOT and fresh battery. Haven't received ordered 7x4 prop yet.... Anybody give me an idea what this 7x4 will do for performance? Will it give more thrust? What will happen to motor speed? I think the amps will go up, 50 amp Esc should handle that right? As previously posted, not looking for a rocket ship.... just a nice scale looking bird. Would a lower KV and bigger prop work better? Is it worth changing motor out for NTN 2826 (2200 or 2700 KV) or Graysons Monster Jet? When I hold the plane vertical just doesn't seem to have the power. Hold it parallel to the ground and it seems to want to go forward. Has anybody else had a bird this heavy and used something similar to power it? Any comments would be appreciated. Andy |
![]() For all my decals, i lift the highest resolution images possible from the Internet. All my decals are sized and arranged on 8x10 background in Photoshop. I then take the file to Kinkos and they do a color laser printing on a clear full page packing label all for $1.55 They stick amazing and when you spray over a sealing layer of water based polyurethane, they are permanent... Hope that helps! |
Limie99, amin2904:
Great job on both of your planes! Great paint schemes. |
Latest blog entry: RC Flight Log Update!
Nice work, amin2904! Your model looks really good. And I'm especially thrilled to see my design being built in Iran!
That prop looks quite big for that airframe, which makes me worry about prop torque effects. I'm not familiar with that motor, but if it can spin a smaller diameter prop efficiently it could reduce the torque effect and fly better. If you do fly with this setup, but sure to launch with half-throttle or less, and only give it full throttle once you have some airspeed. Steve |
hi m.r shumate
my name is amin Sorry if I bad speak English my dialog is not good I am glad to talk with you I love your designing. your drawing is very good. After I made the jet,Many friends were interested in making it. I always Protection that your designing in iran. about you comment I must say is quite true.i use a 800 gr trust engine. I have a flight video soon You have created a drawing of the shuttle? thank you |
Hi amin,
No worries on your English, I'm just glad you took the time to share your work. Thank you for the compliments, I'm thrilled to see guys like you enjoying my plans. No, I haven't created plans for a shuttle. That would be a fun project, though. I'd encourage you to give it a try! I look forward to seeing your flight video. Steve |
thank you steve
This is my jet topic http://www.r30.ir/thread-2878-page-3.html I sometimes drawing plans But the quality of your project does not design now. in iran, I will support it. I want to create an archive of your project. sure.i soon put the flight video. Amin |
You must be righteously proud Steve that your awaesome designs are held in such high esteem all over this globe? Talk about this hobby brininging people together!? Perhaps if all world leaders got into RC and shared on this forum, the whole mess would be improved (naieve I know) but astounding how so many different cultures are brought together over this hobby, your desins being a huge catalyst for this. And you just wanted to design good models? Just look at the knock on, positive affects these have had? The examples of the SU builds on this thread are truly wonderful. If there is ever a 'foamie Hall of Fame' you and H-J must be inaurgurated for your outstanding designs. 'Nuff said!! Any new projects on the go?
| Thread Tools | |
| Build Log Super Bandit Park Jet | jetset44 | Pusher Prop Jet Models | 1075 | Jun 01, 2013 03:03 PM |
| Discussion SU-38 super Flanker... pps/ going e-power | Insanety | Pusher Prop Jet Models | 2 | May 02, 2008 09:47 AM |
| Video Sukhoi Su-37 Maiden Flight | Nadim | Electric Plane Talk | 2 | Jul 12, 2007 04:41 AM |
| For Sale Walkera SU-27m/SU-35 Super Flanker $100 | skotbro | Aircraft - Electric - Jets (FS/W) | 3 | Dec 06, 2006 08:42 AM |
| Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? | ChrisK7 | Beginner Training Area (Aircraft-Electric) | 0 | May 14, 2005 06:15 PM |
