Old Feb 14, 2013, 01:56 PM
Joined Jan 2013
Guys, thanks for the positive coments. its good to get some praise but much better and rewarding to inspire others to have a go at these amazing planes from Steve.....
As to the Maiden flight, it was a none event and it was done before it was painted The plane is such a dream to fly with cuise at 1/3 throttles and as for the vectored flips - it just makes me smile thinking about it
The best bit.. its so so smooth to fly and the profile as it passes with the drooped nose is fab.
In reply to the UK member who asked about equivalent motors to Steve's originals, mine has ones source from ebay from China/Hong Kong. Just enter 2200KV in the search engine then select the engine and ESP package (30amp). I think Steve suggested this motor size is a little over spec'd for the moter size but it works for me (£13) is a great price too. All my growing fleet run on this set up - F14, F18 &X29 (soon to be test flown when the gyro turns up)
So here's to you guys and keep up the great comments on the threads
Hopefully when the good old British weather breaks i will get some flying shots of the others , just like my F14..............
106flyer is offline Find More Posts by 106flyer
Old Feb 16, 2013, 04:03 PM
Rhys - Forever Learning
Rhondda. South Wales, UK
Joined Feb 2007
Thansk very much 106flyer for the info :-)
Question; in the build guide it says;
"Note that double thickness doublers are used throughout to allow sanding the forward fuselage to a rounded shape"
So does this mean that we make double the amount of forward fuse doublers on 6mm depron and single duse doublers on 12mm depron?
Cheers
rhysduk is offline Find More Posts by rhysduk
Old Feb 16, 2013, 06:00 PM
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
Cheers
Nope, plans are made for 6mm depron. Sometimes the plans will show one part, like a doubler, which is used on both sides and will be designated with an x2 so just cut out two, use one on each side...
Levictus is offline Find More Posts by Levictus
Old Feb 16, 2013, 07:35 PM
Joined Feb 2007
Thanks Levictus, so what does the actual sentence mean? Excuse the ignorance but I just don't get it.
Is it just explaining the fact that some parts consist of two doublers to increase the sanding area? IE one long doubler and one shorter doubler. Like the Fwd fuselage double top 1 and top 2 ?
Old Feb 17, 2013, 12:10 AM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Good question. I simply meant that two doubles are used in the corners instead of one (and both are already shown on the plans). All my previous designs used only one doubled in the corners--but they weren't as curvy!
jetset44 is offline Find More Posts by jetset44
Old Feb 19, 2013, 07:32 AM
Joined Feb 2007
Thanks jetset, much appreciated
Shall continue the build!
Old Feb 21, 2013, 01:42 AM
Joined Jan 2013
Thoughts on 39 oz. model
Hi Guys,
New to the forum.... been building this bird for awhile and finally got it together (wow, so many pieces to cut out and glue).
Will post pictures in the next couple of days, but the issue I have is weight. I'm already at 39 oz. and I haven't painted it yet!!!!
Using a single Grayson SMJ v2 for power with a 6x4 and 50 amp ESC and wondering if the bird will get in the air?
I'm Canadian and can't readily get 6mm Depron, so I laminated 4.5 and 2.5mm foam board and I think that's where my extra weight has come from.
I don't need 1:1 performance, I actually like to see a plane fly by me ..... not scream by me.
Any thoughts on a different power plant? Should I go with a different prop.... possibly a 7x4 or a 6x5 to get more performance? Would a 9x6 with a lower KV work better?
I'm really concerned about torque roll at full power with the launch and somebody suggested that I get a gyro for roll to help control that.... what do you think?
This has been a labour of love with this model and I would hate to screw it up on the maiden.
Any help you could throw my way would be appreciated.
Thanks..... Andy
Limie99 is offline Find More Posts by Limie99
Old Feb 21, 2013, 07:34 AM
Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
@Andy: If yours is full-size, I wouldn't worry about the weight. My 26" version was 32-33oz AUW. IMO, this plane flies better the heavier it is (within reason). Since you already have the SMJ, I'd try that with the 6x4 and see how it goes. The first 28" version I built used that power system with great success. If you really want to prop it differently, I would go more to the larger prop...not more pitch. Just make sure you check with a watt meter to make sure you're not exceeding the specs of the power system.
Good luck!
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: RC Flight Log Update!
Old Feb 21, 2013, 07:54 AM
Joined Feb 2007
What power setups are people using on the 22" wingspan versions? Can't find anything... my search skillz are poo!
Old Feb 21, 2013, 08:03 AM
Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I haven't seen a 22" version built. I would think that at that size, you might not be able to do the dual motor/TV setup. If you're going single motor, the 2212-06 motor would make it fly. If you want a screamer, you could use either the Grayson SMJ or the E-Flite Six 2700kv.
Old Feb 21, 2013, 08:23 AM
Joined Feb 2007
Thanks Dad... errr I mean... thanks t3ch i'll take a look around at those motors and see what's available here in the UK
In the scale picture the recommended motor is a CD-ROM motor but no specs are given.
Old Feb 21, 2013, 02:00 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Andy,
I'll second what T3chDad said--this design can easily handle weights that high. I would go easy on the paint though, to avoid getting too much higher (even a basic paint job can add 1-2 oz).
The SMJ motor can also easily handle that weight. Either the 6x4 or 7x4 should work fine, try both. I'd probably err toward the 7x4 if you're like me and prefer more vertical capability than speed.
Don't worry too much about prop torque, it's really minimal with a 6" or 7" diameter prop. You can safely launch at 3/4 throttle without worrying about torque (then throttle up to full right after the launch). Definitely don't need a gyro for torque effects.
As for the throw, just be careful to throw the model straight and smooth. That's harder than it sounds since you're hold the model off-center when you're holding the nacelle. Just remember if you're holding the left nacelle (i.e., you're right-handed) to impart a slight twist in your wrist to your left--that will keep the model from yawing/rolling to the right. Check out my flight video on the first page of this thread and you'll see I didn't quite do it right on that particular launch--the model rolled right 45 degrees right after I threw it! Easy recovery, but if you do it right no recovery is needed at all. It's not hard, you just have to stop and think about it carefully before throwing, and not just chuck it in the air.
Good luck with the maiden! And let us see how your model turned out after you paint it.
Steve
Old Feb 21, 2013, 05:58 PM
Joined Jan 2013
Thanks Bob and Steve for your replies.
I'll give it a go with SMJ and 6x4.
Any thoughts on Elevon throws and Expo's for that first flight?
CG is just about right on (6.1" from center spar) but I'm thinking of making her a little nose heavy.... going to reposition 2200 mah nano-tech a little more forward. Would 7.1" be better?
Andy
Old Feb 22, 2013, 12:31 AM
Joined Jan 2013
Just needs a paint job
Here is the bird to date..... it just needs a paint job!
Andy
Old Feb 22, 2013, 02:45 AM
Joined Feb 2007
Andy
I wouldn't go as much as an inch further forward. Take it in small increments, says 1.4" at a time and see how it behaves.
1" and it will be extremely nose heavy to that of the intended CG
Steve - any idea on specs for a motor for a 22" version? "CD-ROM" motor means little to me in terms of kv, Ah etc
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1075 Jun 01, 2013 03:03 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
