Old Jan 30, 2013, 01:53 AM
nossi is offline
Find More Posts by nossi
Joined Jul 2011
Hello Steve,
thank`s for your answer. But that srew that i mean is this one
which is inside the brasstube of the TV System (axis).
I'm not sur if 2mm is strong enough or if ishould use 3mm.
Greets Peter
nossi is offline Find More Posts by nossi
Old Jan 30, 2013, 06:38 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Originally Posted by nossi View Post
Hello,
i started yesterday building the 30" SU. I want to use 2 2212/6 motors for this plane.
Has everbody pictures of the modified motor mount for this type of motor.
And what diameter have the srews that used at the TV System. I am posting from Germany an we have no inches. We measure in Millimeter. Thanks for your reply.
Greets Peter
Look at this post. It's a 100% Su-37 and it has 2212/06 motors. It has some good pictures of the motor mounts. http://www.rcgroups.com/forums/showt...54#post9064296
Hope this helps...good luck with the build.
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: Latest Projects...
Old Jan 30, 2013, 01:46 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Hello Steve,
Greets Peter
Oops, I thought you were referring to the propellors...my bad! My hunch is a 2mm screw is probably strong enough. When you lay out the motor mount, just make sure to lengthen the sidearms to put the thrust line of the motor through the pivot screw. Simply holding the motor and mount up to the plans and hand drawing the extensions required should get you close enough.
jetset44 is offline Find More Posts by jetset44
Old Jan 30, 2013, 05:01 PM
nossi is offline
Joined Jul 2011
Aaaah,
thank`s for the link to the pictures ofe the motor mount.
I think the sideplates of the TV System should be OK for my motors.
(motoraxis is in line with the pivot srew). Tonight i found motors which
are better.
Look here:
http://www.modellco.de/motoren/motor...8-2600kv?c=187
Greets Peter
Old Feb 06, 2013, 02:41 PM
106flyer is offline
Find More Posts by 106flyer
106flyer's Avatar
Joined Jan 2013
Hi there, here is my offering for mounting my 2212/6 motors on my Su37. 1/8 ply motor plate butt glued to the 3/8 stick. Does not sound too strong but 1" counterhead screw does the trick down the axis of the 3/8 stick. Model has had many flights to date with no vibration or strength issues. As Steve says the motors are a little strong but a vertical take off on some times stops the guys in their tracks at the field !!
Im busy painting it at present, pics to follow and after those dreaded panel lines....
106flyer is offline Find More Posts by 106flyer
Old Feb 06, 2013, 05:50 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Keep an eye on it. I did sort of the same thing a while back with not so good results. Check out posts #1284 and #1288 at the link below. These motors are a little smaller, but not by much.
http://www.rcgroups.com/forums/showt...php?p=10419376
Old Feb 07, 2013, 06:58 AM
106flyer is offline
106flyer's Avatar
Joined Jan 2013
Cheers, thats a fair comment, will do. Hopefully a metal centre and expoxy will be Ok but i will check regularly. Flights to date is about 20 so I will think of an alternative and make some up
Old Feb 11, 2013, 03:46 PM
106flyer is offline
106flyer's Avatar
Joined Jan 2013
Hi all. Some pics of my Su37 finally all coloured up.
Hope orientation is not an issue with this scheme !!
Old Feb 11, 2013, 04:53 PM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
Anyone here in the UK built this bird? Seriously struggling to find anything half as close to the LSPJ motors
Eg: I found this: http://www.giantshark.co.uk/221206-2...-p-402397.html but it's WAY TOO HEAVY!
This is very similar to what 106flyer is using but doesn't specify a weight: http://www.ebay.co.uk/itm/A2212-6-Br...2486%26ps%3D54 but have a funny feeling it's near the 50g mark!
rhysduk is offline Find More Posts by rhysduk
Old Feb 11, 2013, 05:09 PM
Levictus is offline
Find More Posts by Levictus
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
This is a great motor for the dual engine setup and the ones I run on mine. It is a clone of the Suppo motor which is 47g but is way more powerful than the LSPJ at 220 max watts. Don't worry about the weight as it is fine, and as others will attest, it flies a little better with a bit more weight. You will need a 30 amp esc for each and I run APC 6x4 regular and pusher props. If you are using more than 4 servos, consider an external BEC as well. Good luck!
Levictus is offline Find More Posts by Levictus
Old Feb 11, 2013, 05:13 PM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
Looks really sharp! Congrats! Only for myself and own taste, I would be a little concerned about orientation with both sides pretty similar, but for some it is just a preference.
Old Feb 11, 2013, 05:58 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
That is one of the best looking Flankers in this thread! I LOVE that paint scheme and had considered it before. You did a wonderful job!
Old Feb 11, 2013, 07:56 PM
PhantomFlight is offline
Find More Posts by PhantomFlight
PhantomFlight's Avatar
United States, TX, Sherman
Joined Apr 2006
106flyer, that's a very sharp bird you got there! Excellent work.
PhantomFlight is offline Find More Posts by PhantomFlight
Old Feb 11, 2013, 11:04 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
WOW!! Beautiful model, 106! That paint scheme fits the Su-37 perfectly, and the detailing is superb. Good luck with the maiden flight, and let us know how it goes!
I'd be especially nice if you got some in-flight photos as good as your F-14 pics...
Steve
Old Feb 12, 2013, 10:33 AM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
i used 2 of those motors from giant shark on my Su37, it flew great. i have a video on my blog here on rc groups. mine was the slightly larger version can't remember how much bigger it was now.
peter24 is offline Find More Posts by peter24
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
