Old Dec 24, 2012, 09:39 AM
delfin05 is offline
Find More Posts by delfin05
delfin05's Avatar
Joined Jan 2012
Sorry for my bad English
delfin05 is offline Find More Posts by delfin05
Old Dec 24, 2012, 12:45 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Looks great, Delfin! Thanks for sharing the video. I'm THRILLED to see my Su-37 design flying in it's homeland, Russia!
No worries on your English, we're glad you shared.
Steve
jetset44 is offline Find More Posts by jetset44
Old Dec 24, 2012, 11:50 PM
delfin05 is offline
delfin05's Avatar
Joined Jan 2012
Steve
Thank Stve, glad you enjoyed it, the next rise will be with retracts
Old Dec 25, 2012, 01:01 AM
delfin05 is offline
delfin05's Avatar
Joined Jan 2012
now begin to build SU 37 for 2 motors with prop for FPV and Su 37 with two Mercury Alloy 64mm 3700KV EDF Unit (3s ~ 5s)
Old Dec 31, 2012, 12:21 PM
XSTORM is offline
Find More Posts by XSTORM
France, RA, Saint-Cyprien
Joined Nov 2011
Your plane is built everywhere
On the French forum we are 2 persons has to build a model of 1400mm with the wing in profile
Still bravo for this beautiful model
XSTORM is offline Find More Posts by XSTORM
Old Jan 03, 2013, 12:36 PM
savall21 is offline
Find More Posts by savall21
Go Sabres!
savall21's Avatar
Laurel, MD
Joined Aug 2004
Your jet is awesome! Can you share the power setup?
savall21 is offline Find More Posts by savall21
Old Jan 05, 2013, 07:58 AM
delfin05 is offline
delfin05's Avatar
Joined Jan 2012
surely, EDF Ducted Fan there was this http://www.parkflyer.ru/46992/product/4238/ ,motors Turnigy Typhoon 450H 2215H http://www.parkflyer.ru/46992/product/9021/ ,Turnigy dlux 55A SBEC Brushless Speed Controller http://www.parkflyer.ru/46992/product/103859/ ,and 2 ZIPPY Flightmax 2450mAh 4S1P 30C
All this is on a hobby King At parameters, of motors you don't look, current big, but the motor can't burn down because of that that it has the cooling
Old Jan 05, 2013, 11:47 AM
savall21 is offline
Go Sabres!
savall21's Avatar
Laurel, MD
Joined Aug 2004
Sweet! How much flight time do you get?
Old Jan 05, 2013, 12:35 PM
delfin05 is offline
delfin05's Avatar
Joined Jan 2012
3-4 minutes on a maximum
Old Jan 05, 2013, 12:36 PM
delfin05 is offline
delfin05's Avatar
Joined Jan 2012
I don't love slow flights, speed I love
Old Jan 05, 2013, 03:57 PM
savall21 is offline
Go Sabres!
savall21's Avatar
Laurel, MD
Joined Aug 2004
Thanks! I hear ya, I, thinking about building it just can't decide EDF or pusher.
Old Jan 05, 2013, 11:57 PM
delfin05 is offline
delfin05's Avatar
Joined Jan 2012
you most should solve for yourselves, the high speed it EDF, a long time of flight is a pusher.
yes, and still, the drawing I did biger.wingspam 900 mm, is long 1300 мм.edf 64 mm it is necessary will work that install.and a little advice if after all decide to build edf, width of the channel make 5 mm wider and near edf it is necessary to cut out gills, the channel wrong, and gills will help
Old Jan 24, 2013, 08:22 AM
vlada is offline
Find More Posts by vlada
vlada's Avatar
Serbia, Central Serbia, Valjevo
Joined May 2011
These were made of imitation engine can now be entered into the final model and is working on the final finish.
vlada is offline Find More Posts by vlada
Old Jan 29, 2013, 02:41 PM
nossi is offline
Find More Posts by nossi
Joined Jul 2011
Hello,
i started yesterday building the 30" SU. I want to use 2 2212/6 motors for this plane.
Has everbody pictures of the modified motor mount for this type of motor.
And what diameter have the srews that used at the TV System. I am posting from Germany an we have no inches. We measure in Millimeter. Thanks for your reply.
Greets Peter
nossi is offline Find More Posts by nossi
Old Jan 29, 2013, 10:58 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Welcome nossi,
Yes, several guys have used two 2212/06 motors in this plane with good results. They're somewhat large for the standard size 100% model, but work. For better results, you might want to scale up the plans to around 120% or so with those motors. As for props, the 2212/06 works best with a 6x4 prop, which is 152mm x 102 mm.
Good luck!
Steve
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
