Old Oct 20, 2012, 10:20 PM
Levictus is offline
Find More Posts by Levictus
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
So following along on that motor question, in a dual motor setup, just to verify again, the Grayson Hobby Microjet v3's should be good? Tough to beat 25oz of thrust on a 6x4 from a 34g motor! If not is there a better power plant combo I should be looking at? All my electronics should be arriving this week, but I haven't ordered the motors yet... Thanks guys!
Levictus is offline Find More Posts by Levictus
Old Oct 21, 2012, 09:15 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I had the v2's on a full size flanker. They did great. Just be prepared to get your battery pretty far forward to compensate for the weight on the tail.
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: I've been flying!
Old Oct 21, 2012, 09:50 AM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
T3chDad...the V2's you had, were they the Super Mega Jet V2's?
Old Oct 21, 2012, 10:15 AM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
No, they were the 2212-06. I've had three flankers.
1) 28" Initially powered by a Grayson Super Mega. Once that died, it was powered by the EFite "Six" 2700kv
2) Full-size powered by two Grayson 2212-06 v2 motors with thrust vectoring. Originally built by cmala.
3) 26" powered by the "Six".
Old Oct 21, 2012, 10:49 AM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
I think I may go with the Suppo - A2212-6 Gold. Similar to the Grayson SuperSonic v2, but slightly lighter and more thrust on a 6x4. Vs the Microjet V3, the Suppo would provide max 1674g of thrust vs the 1338g of the MJV3. Only disadvantage is the Suppo's add a full 34g extra weight to the rear which is basically what a whole MJV3 weighs. The additional thrust is is more than enough to make up for this but I would also want to be sure I had enough room to move the battery forward for CG without adding ballast as you mentioned. Also, two Suppo's are $30 vs. $48 for two Grayson MicroJet V3s.
Ps, that info is based on tests from flybrushless and Dr Kiwi
Old Oct 21, 2012, 10:55 AM
vlada is offline
Find More Posts by vlada
vlada's Avatar
Serbia, Central Serbia, Valjevo
Joined May 2011
I for my model will use TURNIGY D2826/10 1400KV, 7x4 propeller. I get about 1500g of thrust, so I have 300g more thrust than model weight.
vlada is offline Find More Posts by vlada
Old Oct 21, 2012, 11:15 AM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
Uggh, why are there like infinite choices for motor and prop setups?! Vlada, that looks like a real interesting combo, however, I already have my 30a esc's and don't want to move up to the 40a in the current interest of added cost and weight but may try on a future build. I did recently order a Tunigy D2826/6 motor with 40a esc and 6x4 prop for my Shumate F15. Haven't flown it yet but interested to see how it compares as all my other motors have been Grayson Microjet V3's...
Old Oct 21, 2012, 02:03 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Levictus,, stick with the 2212-06 and ur 6x4 props, best setup for these park jets from steve.. Good luck! W
Waltjg is offline Find More Posts by Waltjg
Old Oct 21, 2012, 02:20 PM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
Thanks Walt... How's that wicked F-4 flying!
Old Oct 21, 2012, 06:50 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
It's flying great! I really need to stop, slow down and do panel lines on it.... But, too much flyin lately getting in my way!!!! . Thanks for the comment and asking! W
Old Oct 27, 2012, 02:50 PM
muznik is offline
Find More Posts by muznik
Czech Republic
Joined Aug 2009
Hello, boys after the success of the F22, I built SU - 37 schedule Steve Shumate. The building itself was quick, the longest lasted preparation electronics. Many suitable engines, and their installation. Battery is thrust into the toe and regulators are away from her almost 70 cm. The power cord is 16 cm in the parallel capacitors. The solution I have used in F22. The receiver is powered from both controllers - work well! .The front part of the model is to canaries laminated thin cloth around the engine is too thin fabric. Weight of the model has increased, but the model is stronger. Center of gravity the plan got moved back about 3 cm .Our weather has been bad, but together with my wife, I made a short video.
weight 896 gram / RC Hobbies 2200KV Brushless Motor (2212-6) + ESC 30 / propellers 6x4
SU37 by Steve Shumate (3 min 31 sec)
muznik is offline Find More Posts by muznik
Old Oct 27, 2012, 06:24 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Sweet! Nice build and great flying!
Old Oct 27, 2012, 07:18 PM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
Nice muznik...sweet flying... Thanks for posting!
Old Oct 27, 2012, 11:31 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Nice work, muznik! Great looking model and nice flying. Thanks for posting!
Steve
jetset44 is offline Find More Posts by jetset44
Old Oct 28, 2012, 12:26 AM
Levictus is offline
Crash Test Pilot
Levictus's Avatar
Joined Jul 2012
So when I am routing wires from one nacelle across the bottom to the other side, can I run the servo wires next to the power wires and signal leads from the esc's? Too much interference or will it be ok? It sure looks neater going through one hole...
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
