Old Mar 19, 2012, 07:00 AM
Biffda is offline
Find More Posts by Biffda
if its not broke,fix it anyway
Biffda's Avatar
United Kingdom, England, Coventry
Joined Jan 2012
A bit like my F15 then duffed a landing yesterday , not impressed the week before it got attacked by a dog
Biffda is offline Find More Posts by Biffda
Old Mar 19, 2012, 10:54 AM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
Originally Posted by Biffda View Post
Nice looking jet peter24,,, How much you got left to do?
i just need to seal the paint, then im good to go, how is your build coming on?
Jetsett am i correct in thinking the cg should be 7.32" on my 36" span jet, oh if i havent said all ready, thanks for the plans. awesome designs as usual.
peter24 is offline Find More Posts by peter24
Old Mar 19, 2012, 04:54 PM
Biffda is offline
Biffda's Avatar
Joined Jan 2012
mines coming on ok a bit slow due to my f15 that i repaired and painted then crashed on landing just need to order escs fit nacelles,shape the rear and paint im just making motor mounts to finish the servo fitting
Old Mar 19, 2012, 05:35 PM
Shane Sunday is offline
Find More Posts by Shane Sunday
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
Peter your model looks lovely. I don't know if you've sealed the paint yet or not but if you take floor wax in a spray bottle and mist it from a distance of say 2 feet then use a hair dryer to dry it then mist again until you feel comfortable you have complete coverage this will keep any paint from running and will seal it all in. also make the model completely wipe-able.
I had a torque roll issue with mine about a month ago. Of all my models I've only had 2 or 3 real issue and all were my own fault. This is a fantastic model to build and fly. Now it's back to putty filler, sanding then painting to get her back to new again. But she is worth it.
Shane Sunday is offline Find More Posts by Shane Sunday
Old Mar 20, 2012, 01:00 AM
peter24 is offline
Joined Sep 2007
Thanks Shane, do you mean put varnish in an atomiser type spray bottle, or a proper spray gun, i have an atomiser bottle, although they do have spray guns at work, sounds like an excellent idea.
All steves models are awesome, i have built several now, they all fly great. you cant beat a bit of sanding..
Old Mar 21, 2012, 04:35 AM
Joined Jun 2011
exactly just a regular spray bottle with floor wax in it and then a few coats from a distance until she is covered. I use to do this all the time on the street. Ya us punks wanting to vandalize but weren't old enough to buy spray cans so we took tempura ( water based) paint and mixed it in with floor wax and sprayed our tag templates all round the town. They stayed for months! Walk on em all you like it's floor wax. Rain, snow, hail give her nails it's tough as.
A bit of sanding is right I did a bit of sanding on his tomcat then a bit more on his SU-37 now I plan on a bit more on the F-5 then when I'm done that I'll probably do some more sanding in my sleep. Hahaha
Good luck
Old Mar 21, 2012, 04:32 PM
vicentel is offline
Find More Posts by vicentel
vicentel's Avatar
United States, CA, San Diego
Joined Aug 2010
Originally Posted by T3chDad View Post
She is still down for "repairs".
Breaks the heart. Your Yellow 13 scheme always impresses. After a couple of hard landings I finally had to glass the nacelles on my edf powered 34" wingspan Su-37. At nearly 60oz the bottom of the plane was taking a beating from the all the wear-and-tear of belly landing. Fiber glassing the nacelles really strengthened them and added very little weight. Had a lot of flights on her and she's still going strong.
Vic
vicentel is offline Find More Posts by vicentel
Old Mar 21, 2012, 05:18 PM
Biffda is offline
Biffda's Avatar
Joined Jan 2012
Description:
Description:
Description:
Description:
Description:
Description:
Description: so here we are then my motor mounts, not bad for my first go heres some pics of how i made them
Old Mar 21, 2012, 05:21 PM
Biffda is offline
Biffda's Avatar
Joined Jan 2012
Vic that looks real good how did you do the panel lines
Old Mar 22, 2012, 12:25 PM
vicentel is offline
vicentel's Avatar
Joined Aug 2010
I took a technique from t3chDad and used Chartpak tape 1/16", 1/32", and 1/64" sizes.
Old Mar 22, 2012, 12:40 PM
Biffda is offline
Biffda's Avatar
Joined Jan 2012
Vic how long did it take, and also can you post pic of tape or a link to get it
Thanks cliff
Old Mar 22, 2012, 01:00 PM
vicentel is offline
vicentel's Avatar
Joined Aug 2010
Cliff, you can go to this link for a picture:
http://www.rcgroups.com/forums/showt...66686&page=138
post 269
I bought mine on Amazon.com
Vic
Old Mar 22, 2012, 01:05 PM
vicentel is offline
vicentel's Avatar
Joined Aug 2010
As far as how long it took...well you're going to have to make sure your seal the foam to create a smooth surface for the tape to adhere to. I used a water based acrylic clear coat mixed with talc (50/50). Sanded it down and repeat. Applying the tape did not take that long but it is a labor of love. Overall, applying the panel lines took several nights of work. Also, if it does not stick properly you're going to need to re-apply it, a coat of the clear coat (no talc) over the tape will help it stay down.
Vic
Old Mar 22, 2012, 01:19 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Many different ways to do panel lines, this is one, another is use a soft lead pencil and a straight edge. for the weathering, rub the line some,, do a little practice on scrap, you'll be surprised how easy it is.. Also they can be done with an airbrush, light and easy does it... good luck. w.
Waltjg is offline Find More Posts by Waltjg
Old Mar 22, 2012, 02:03 PM
Biffda is offline
Biffda's Avatar
Joined Jan 2012
Cheers vic,,
Cheers waltjg
Going to give this a go on a scrap piece if I can do it with out it looking crap then panel lines it is
Thanks cliff
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
