Old May 27, 2011, 03:31 PM
JMSR is offline
Find More Posts by JMSR
JMSR's Avatar
Dunedin, New Zealand
Joined Dec 2010
Congrats on the maiden simonslim. Nothing better than a bit of fine tuning between flights.
THE KIT HAS ARRIVED!!! Safe and sound from half way around the world. And its as beautiful as it is big! You can see precision all over this kit. Here are the generic box/kit pics.
JMSR is offline Find More Posts by JMSR
Old May 27, 2011, 04:15 PM
simonslim is offline
Find More Posts by simonslim
simonslim's Avatar
United Kingdom, England, Northd
Joined Nov 2005
Thanks JMSR, see your going for the full TV set-up, nice.
I have just tuned mine up today, going from 350 watts to 525 watts so it should be a bit more spirited.
simonslim is offline Find More Posts by simonslim
Old May 27, 2011, 04:43 PM
JMSR is offline
JMSR's Avatar
Joined Dec 2010
Yeah, I can't deny the gyroscopic stability of 2 counter rotating props. I'm only going to be using 2 servos with Tailerons mechanically linked to TV. No yaw either. I've got a GWS P-38 with no Yaw or rudder and it flies sweet. Sure it'll call for a bit more precision and mechanical tuning to get it right, but I prefer that over digital tweaking. Plus the lack of all this means a lighter plane for glassing. Good luck with the 525W!
Old May 30, 2011, 04:27 AM
simonslim's Avatar
Joined Nov 2005
Well the new motor has been a success. It has given the plane a bit more top end speed and a new sound too, it has a bit of a whistling howl to it now.
I'll try a get some vid in the next day or two.
Old Jun 07, 2011, 12:04 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Which motor is it?
rcjim11 is offline Find More Posts by rcjim11
Old Jun 08, 2011, 02:34 AM
simonslim's Avatar
Joined Nov 2005
It is a Giantcod custom wind E-power 2815 1400kv it cost an arm and a leg £12.73 Ha.
Old Jun 13, 2011, 12:11 AM
JMSR is offline
JMSR's Avatar
Joined Dec 2010
10 days in and she's starting to look like a plane.
Old Jun 13, 2011, 12:49 AM
CBflyguy is offline
Find More Posts by CBflyguy
6mmFlyRC
CBflyguy's Avatar
Joined Aug 2005
Always nice to see a kit arrive safely! Looks great so far!
CBflyguy is offline Find More Posts by CBflyguy
Old Jun 13, 2011, 01:15 AM
JMSR is offline
JMSR's Avatar
Joined Dec 2010
Hats off to you at 6mmflyrc! This has been a lot of fun so far. Fantastic kit.
Old Jun 13, 2011, 11:13 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Giantcod is very good, are you using an 8inch prop by any chance?
Old Jun 13, 2011, 04:39 PM
simonslim's Avatar
Joined Nov 2005
I am using a 9x7.5 pulling 525watts at 51amps. I'll get a vid up on you-tube soon.
Old Jun 15, 2011, 12:53 AM
JMSR is offline
JMSR's Avatar
Joined Dec 2010
Motor mount position tuning. French style.
Old Jun 15, 2011, 06:44 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Nice!
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: I've been flying!
Old Jun 19, 2011, 10:41 AM
jdgto is offline
Find More Posts by jdgto
Joined Jul 2010
Hi all,
I hope you don't mind an oddball question thrown in here ??
I recently bought bannistators old fleet (he has built new), including the SU-37 which I love. I have already had a mishap on landing & pulled both stick mounts out of the back & with it being a well used model, i don't think sticks are going to be strong enough.
Could I get away with mounting solid panels to cover the open holes in the tail & mount the motors on these ?
Presumably having a "tube" then creates a big air dam, so was thinking of blocking the front edge with depron.
Will this create too much lift on the nose ?
Silly idea ??
thanks for any advice
John
jdgto is offline Find More Posts by jdgto
Old Jun 19, 2011, 11:27 AM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
I've heard of people blocking the intakes on Steves F-14. The result as I remember was it helped keep the nose up in turns.
alpea 41 is offline Find More Posts by alpea 41
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
