Old May 15, 2011, 08:22 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
As far as replacing the spars, if you're using WPBU, I wouldn't count on it being any stronger than plain foam. I kept my carbon rods. WPBU/glass isn't particularly strong.
The weight saving over epoxy isn't that great once you know how to work with resin. Strength/weight is certainly better with epoxy.
Don't bother watering the WPBU down, after all, most of it is water as it is. It flows out very nicely.
When shaping the fuse, use blue masking tape to protect the parts that are already glassed. 3/4oz glass doesn't protect very well, and when the tape starts to fray, you can just pull it off and put a new strip down.
Odysis is offline Find More Posts by Odysis
Old May 15, 2011, 08:41 PM
T3chDad is online now
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
As Odysis says, keep the spars. It's not going to add enough weight to make it worth the sacrifice in strength.
T3chDad is online now Find More Posts by T3chDad
Latest blog entry: Latest Projects...
Old May 15, 2011, 08:44 PM
JMSR is offline
Find More Posts by JMSR
JMSR's Avatar
Dunedin, New Zealand
Joined Dec 2010
Thanks guys, I'm dedicated to the WBPU because I'd already got it in preperation for the build. Still yet to start (kit should be here this week), so I'll continue to keep the ear to the ground before the final decisions are made. I'm not sure if the 'additional' spars will be included in the kit, but keeping/adding them would be fine, they would help it balance too. Will certainly be taping to protect when shaping. This is good stuff, keep it coming.
JMSR is offline Find More Posts by JMSR
Old May 15, 2011, 11:42 PM
Odysis is offline
Joined May 2007
Stock up on microbaloons. Makes a very nice slurry for filling rather than talc.
Old May 16, 2011, 08:18 AM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I discovered this late in the construction of mine. If they are available to you, microballoons are WAY better than talc/baby powder for mixing with WBPU. It is SO much lighter. Arguably, it's more dangerous for inhaling than talc, so if you go that route be sure to do your sanding outside with a mask.
Old May 16, 2011, 02:26 PM
thaltis is offline
Find More Posts by thaltis
North weald Wing
thaltis's Avatar
Åfjord, Norway
Joined Jan 2010
A video of me catapulting my Su-37. It's my first time using a catapult, and it was å sucsess. I have a error in the text, I use two GH micro parkjets. Not two parkjets. It have the speed,and lands like a trainer. I simply love this plane.
Enjoy
http://m.youtube.com/?client=mv-goog...?v=wvlPjq4zY7U
thaltis is offline Find More Posts by thaltis
Old May 16, 2011, 02:41 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
That's great! She does get nice and slow for landing.
Old May 16, 2011, 05:19 PM
simonslim is offline
Find More Posts by simonslim
simonslim's Avatar
United Kingdom, England, Northd
Joined Nov 2005
Mine is nearly ready for fitting out with electrics. Looks rather menacing.
simonslim is offline Find More Posts by simonslim
Old May 16, 2011, 07:08 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Looking good slim! Of course, almost anything would look menacing next to an F-22.
Old May 17, 2011, 04:17 AM
simonslim's Avatar
Joined Nov 2005
Cheers bud, the sanding is a chore but with this one being a bit bigger than standard, I can get in with a orbital sander.
Old May 17, 2011, 03:14 PM
5jays is offline
Find More Posts by 5jays
United States, WA, West Richland
Joined Jul 2010
I am looking at building one of these and I was wondering how much of the mixing I could do with a dx7 for the thrust ventoring? And would I be able to switch it on and off with the mix switch?
5jays is offline Find More Posts by 5jays
Old May 17, 2011, 04:54 PM
simonslim's Avatar
Joined Nov 2005
Don't know much about the DX7, this one's just having tailerons with perhaps ailerons retro fitted if I think it needs them.
Comin on slowly but surely.
Old May 17, 2011, 05:33 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I think you can do everything but yaw thrust vector control if I remember correctly. I didn't set that up in my DX7 and it was probably a limitation of the radio.....just didn't have enough mixes available.
cmala is offline Find More Posts by cmala
Old May 17, 2011, 08:49 PM
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
It's looking great simon. You work fast!
According to Steve's original controls post WAY back in the thread, you need seven mixes. I think the Dx7 only has six...
Old May 18, 2011, 05:57 PM
simonslim's Avatar
Joined Nov 2005
Not much done today, fitted the elevators and sanded some more Not to worry, it'll be worth it in the end.
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1093 Apr 25, 2015 03:34 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 10:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 05:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 09:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 07:15 PM
