Old Apr 01, 2011, 03:49 AM
Alex1754 is offline
Find More Posts by Alex1754
Украина, Киев, Киев
Joined Jan 2011
Originally Posted by Torsten288
Hi Alex,
in most cases I use small magnets and matching counterparts (magnets too or small pieces of iron like drawing pins or nail heads).
Torsten, thank, who has other ways, tell…
Alex1754 is offline Find More Posts by Alex1754
Old Apr 01, 2011, 07:45 AM
wilmracer is online now
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
I also use magnets, but some use velcro. I've also had a few that use a male/female plug end and a slider switch at the other.
Some people just use tape each time they change the battery. It all depends on how much detail and time you want to put in...
wilmracer is online now Find More Posts by wilmracer
Old Apr 01, 2011, 09:38 AM
Torsten288 is offline
Find More Posts by Torsten288
Germany, SN, Dresden
Joined Nov 2008
Originally Posted by jetset44 View Post
Torsten, have you flown that beauty yet?
Unfortunately I have to take patience. This weekend we have spring cleaning at our airfield and I hope the Su-37 will get airborne next weekend.
Bye,
Torsten
Torsten288 is offline Find More Posts by Torsten288
Old Apr 01, 2011, 03:50 PM
Alex1754 is offline
Украина, Киев, Киев
Joined Jan 2011
Wilmracer, thank
Old Apr 12, 2011, 04:29 PM
Alex1754 is offline
Украина, Киев, Киев
Joined Jan 2011
Originally Posted by T3chDad View Post
Nice job there so far! I mix WBPU and baby powder at about 50/50 ratio. I then use a big brush to apply it over several coats. Then most of it get sanded-off leaving a very smooth finish.
Bob, hi. I very much like quality of finish (first coat) of your model. I can not understand, what is WBPU? Either I poorly English, or it for us was not present in the market. If it is possible, put a photo of packaging WBPU. If it is possible, more details and photo about know-how of processing. Thank.
Old Apr 12, 2011, 05:25 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
WBPU is water based poly urethane. Clear floor wood sealer. Don't know what makes you have over there but I have found that some have a slight milky or tan finish whilst others are crystal clear. Maybe someone local to you will let you know what makes are the best.
clive45 is offline Find More Posts by clive45
Old Apr 12, 2011, 06:27 PM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
As Clive said, Water-Based Poly Urethane. What I use is Minwax matte-finish. It's milky in appearance with no tint (white). It dries perfectly clear. Mix that about 50/50 ratio with baby powder or talcum powder. I apply it in a very thick coat and then sand most of it off. It leaves a very smooth finish ready for priming and then painting.
I hope that makes since.
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: Latest Projects...
Old Apr 12, 2011, 06:50 PM
Zaurak3 is offline
Find More Posts by Zaurak3
Gravity-Compliant User
Zaurak3's Avatar
Nebraska USA
Joined Mar 2008
Alex,
Here is a photo of a popular brand available here in the USA, and what I use. It's available in a matte, gloss, or satin finish.
Zaurak3 is offline Find More Posts by Zaurak3
Old Apr 14, 2011, 04:58 PM
Alex1754 is offline
Украина, Киев, Киев
Joined Jan 2011
Originally Posted by Zaurak3 View Post
Alex,
Thank who has answered to all for the help, specially behind a photo. I shall search in our market
Old Apr 16, 2011, 12:23 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I finally started working on mine again. I have both engine nacelles/exhaust shaped and sanded....now for the fuse. I'm going to try to finish the shaping and sanding this weekend.
Old Apr 17, 2011, 01:28 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Are the nacelle sides strong enough to hold the motor/mount or do you need to put some Cf reinforcement. Mine feels a bit flimsy but I haven't glued it onto the fuse or glued on the doublers
Any thoughts?
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Apr 18, 2011, 07:20 AM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I would say if you're not comfortable with it, you should reinforce it. Better safe than sorry.
Old Apr 18, 2011, 08:29 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Ok I'm going for it
Old Apr 19, 2011, 05:56 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Ok...it's official! After three days of it, I HATE SANDING!
At least I should be finished (sanding) tomorrow...
Old Apr 19, 2011, 09:14 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Yep, I went through that phase, too.... It'll be worth it in the end, though!
jetset44 is offline Find More Posts by jetset44
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1093 Apr 25, 2015 02:34 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
