Old Aug 02, 2009, 08:25 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Great footage there, bannistator. You're getting the hang of it..
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: I've been flying!
Old Aug 08, 2009, 11:16 AM
gcook12 is offline
Find More Posts by gcook12
Joined Apr 2007
TV question
I am building one of your Su-37s and I have a question. I only have a 6 channel transceiver. Are there any control issues with just using a y connector to connect the elevon and tv servos to the same channel?
gcook12 is offline Find More Posts by gcook12
Old Aug 08, 2009, 04:43 PM
Nadim is offline
Find More Posts by Nadim
Nadim's Avatar
Linköping Sweden
Joined Nov 2006
First of, what is an transceiver? hehehhe
Just kidding I know what you mean.
I had the TV on the flaps channel and mixed it in with the elevator,
but by doing this the TV will only move in one axis
Hope this helps
Nadim
Nadim is offline Find More Posts by Nadim
Old Aug 08, 2009, 07:58 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I did the same. TV on the pitch axis with a switch to turn it on/off.
I take off and land without TV (That way I can 'feel' how fast the plane is going so I avoid stalling), but then once I want to kick some mean aeros, turn it on and away you go!
What radio do you have? We might be able to help you with the setup...
Odysis is offline Find More Posts by Odysis
Old Aug 08, 2009, 09:56 PM
gcook12 is offline
Joined Apr 2007
It is a JR Sport SX600. I guess I could just connect the linkages as is suggested in the plans but it would be nice to disable it until I fly it a few times and get the feel of the airplane.
Old Aug 08, 2009, 11:36 PM
Odysis is offline
Joined May 2007
So you've got 3 custom mixes? I used the Max 66, which hopefully is similar.
My setup had two custom mixes, turned on with the gear switch. They were elevator master, channel 5 slave and channel 6 slave. I also used the delta mix to make the elevons work.
That pretty much maxed out the old system. I now use a better radio, but still a 6 channel Rx, but with 4 custom mixes I have aileron mixed in too. If you have more mixes than the Max 66, you could do that too...
Old Aug 09, 2009, 01:41 PM
gcook12 is offline
Joined Apr 2007
It has 3 mixes, flaperon, delta, and v-tail so I don't see that I have the capability to use the other two channels except for flaps and gear. I think the easiest thing may be to connect the TV and elevons via mechanical linkage and do the first flight over tall grass.
I have a wrecked f-18 that is serving as an organ donor and it has two large servos so that should work. Thanks for the help.
Old Aug 11, 2009, 11:08 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Well, I finally started my Su-30MKI.. Not too much done to it, but it's got glue to foam.. LOL..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Aug 11, 2009, 11:12 PM
wilmracer is online now
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
Any day I glue two pieces of foam together is a good day.
My god, I have a problem
wilmracer is online now Find More Posts by wilmracer
Old Aug 11, 2009, 11:16 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, I keep trying to figure out the best way to warp in into the MKI..
Old Aug 12, 2009, 07:18 AM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Print out your profile of the MKI to roughly the size of the Su-37 plans, overlay them and cut your profiles accordingly....leaving tons of extra around the edges so you have plenty of extra so you can shape it right. It should only affect the two fuse sides and the canopy pieces.
Good luck man.
Old Aug 12, 2009, 10:26 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, that's the plan.. I've got the 30MKI printed out over the 37 and it looks pretty easy..
I think you are right, it should only affect the fuse sides, canopy pieces and maybe a touch of the build up pieces for the blending around the canopy.. Shouldn't be too hard..
Old Aug 12, 2009, 10:34 AM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
IMO, there's not enough build-up pieces in the original plans. I used 4 instead of 3 on each side. You'll probably want to cut them a little bigger too.
Old Aug 14, 2009, 03:26 PM
steven4601 is offline
Find More Posts by steven4601
steven4601's Avatar
the Netherlands
Joined Jul 2008
Did I just do a Landing Gear OOPS?
Ive started building a 137% version of this plan since ive completed the 100% scaled version quite some time ago now.
At this stage im at 70% of the build with my 137% scaled version.
And Today I was playing around with a flat digital scale that allowed me to measure each wheel load.
Front wheel 870 grams
Rear wheels about ~550 grams each
Uh ooh. What was I thinking
Somehow I thought like in the real scale birds , most of the weight would be over the rear wheels. But the gear possitions being a triangle with the center of gravity in the center makes this unfortunate outcome.
Best solution, Non-scale corrections on gear possitions or stronger nose gear?
steven4601 is offline Find More Posts by steven4601
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
