Old Dec 24, 2008, 09:05 AM
wilmracer is offline
Find More Posts by wilmracer
United States, VA, Herndon
Joined May 2007
Originally Posted by smkn951
hello everyone,
well here i go again, up on the chopping block is a 40 in w's version.
originally i planned on 2 70mm 6904, 2w het motors, but after much thought........
Carl
Thats funny... I've got that equipment sitting around and I just finished resizing everything to that same span so I can build this one for that gear. I've got a few other projects on the bench at the moment, but I hope to start this next month. I don't expect it to be a screamer, but it should be a nice home for those fans. I had this 4 cell setup in my old epf f14 and she moved pretty well...
-another Carl-
wilmracer is offline Find More Posts by wilmracer
Old Dec 24, 2008, 03:20 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Smkn' very cool! waiting for more pics and build progress... good luck!!! walt
Waltjg is offline Find More Posts by Waltjg
Old Dec 25, 2008, 12:27 AM
kaysee is offline
Find More Posts by kaysee
kaysee's Avatar
Kuala Lumpur, Malaysia
Joined Aug 2008
thanx nadim for the pictures. helps a lot.
here is my suke 28", end up auw of 26.5oz. is that heavy for this size? waiting for the right time to maiden.
questions:
1) where is the cog should be?
2) im using my tailerons and ailerons for controls as techdad did. do i need to use my ailerons as elevons as well or just let it function as ailerons and let my tailerons control the pitch.
3) if im planning on using my ailerons as elevons, do i need to make the pitch opposite to the tailerons or same.
tia.
kaysee is offline Find More Posts by kaysee
Old Dec 25, 2008, 08:20 AM
gdimonte is offline
Find More Posts by gdimonte
Canada, ON, Newmarket
Joined Dec 2005
FYI,
Here's a picture of mine. 60" long by 42" wing span. In the process of changing from two motor's to one large one. I run it with tailerons and ailerons/elevons all working in the same direction. You might be able to see it in the picture. All control surfaces are up.
The plane handles very well without thrust vectoring and the balance point is excactly the same as shown in Steve S's design.
gdimonte is offline Find More Posts by gdimonte
Old Dec 25, 2008, 11:07 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Awesome! It looks great. I can't wait for the video.
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: I've been flying!
Old Dec 25, 2008, 09:53 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
gdimonte,
what power system were you using and what are you planning on using?
what kind of performance are you expecting?
TIA
Carl
smkn951 is offline Find More Posts by smkn951
Old Dec 26, 2008, 06:39 AM
kaysee is offline
kaysee's Avatar
Joined Aug 2008
gdimonte, that's one big jet u have there. thanx for the tips.
however, i just reallise that my battery wont keep up with my motor amp needs. i'm planning on using a 2500kv apex 450 blm which rated 24A with 6" prop, but i just have 2 3s 15c 1550mAh which if im correct, will give me a peak amp of 22.5A. so got to postpone my maiden till my new battery arrive. 3s 20c 2200mah should do it i think.
Old Dec 26, 2008, 07:33 AM
gdimonte is offline
Joined Dec 2005
Carl,
The original 2-motor setup was a pair of Towerpro 2409-12a's running on two 2200 20c batteries each with 3-blade 8x4 prop's running close to the 25amp max rating. Measured thrust of the combined motors was around 1600gm. This is not a good power set-up but, I had the motors and it got me into the air to test things out.
The replacement motor is a Turnigy Aerodrive SK3536-1400 running a 9x5 3-blade prop. Measured thrust was around 2200gm on a 4s battery. Current UAW for the plane is 1800gm.
As far as performance goes, I prefer vertical climb over all out speed. The bigger motor should be close to unlimited vertical with the prop I have. There's alot more room for bigger props and batteries to use with this motor. I'll experiment once it's flying again.
Old Dec 26, 2008, 06:09 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
a little more progress
hello everyone,
well here's a couple more pics of the build.
power set up:
2 ea don's 2700 kx motors with 6x4 counter rotating props.
2 ea hs-81
2 ea 60 amp esc
1 bec
ar 6000
4s 2250
AUW with out paint sofar is 2 lbs 12.2 oz
do you think it'll fly with this set up?
TIA
Old Dec 27, 2008, 03:47 AM
steven4601 is offline
Find More Posts by steven4601
steven4601's Avatar
the Netherlands
Joined Jul 2008
Help!!! I cant stand it anymore so I decided to begin with the SU 37 as well.
Last night i cut all templates and all firstly required pieces from depron.
How bad is it when I'm going for ailerons and with twin TV. I realized that the ailerons are an Option when not using TV, feel a bit noobish having already cut them off now.
steven4601 is offline Find More Posts by steven4601
Old Dec 27, 2008, 05:33 AM
Nadim is offline
Find More Posts by Nadim
Nadim's Avatar
Linköping Sweden
Joined Nov 2006
simply glue them on again.....
Nadim is offline Find More Posts by Nadim
Old Dec 27, 2008, 05:37 AM
Nadim is offline
Nadim's Avatar
Linköping Sweden
Joined Nov 2006
nice planes guys
kaysee nice job shaping the plane, it looks real good
Carl she looks good...I have an request for you, please video the maiden
Nadim
Old Dec 27, 2008, 10:28 AM
steven4601's Avatar
the Netherlands
Joined Jul 2008
Ive changed my thinking.
Glueing them on again is not an option Nadim
i'm going for two 2212-06 with a 5.5x4.75 maybe 6x4's with TV and ailerons.
Is this going to be too heavy?
Old Dec 27, 2008, 11:39 AM
kaysee is offline
kaysee's Avatar
Joined Aug 2008
i now this thread started last year, and some of you guys have build it since. i wander how many of you guys still flying this jet regularly.
Old Dec 27, 2008, 01:26 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
I certainly am! I love both my Flankers!
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
