Old Apr 01, 2007, 03:35 PM
Kingpeg is offline
Find More Posts by Kingpeg
Nova Scotia
Joined Feb 2005
Zenoah G-38 Tuning/Run Trouble
I have a G38 with little run time on it. It will hand start after 10-12 flips and only stay running for 30 - 45 seconds. It will start to die earlier and I can prolong the run time by closing and opening the choke. Also this is at less than 1/2 throttle. It doesn't like to transition beyond 1/2 throttle. I have the HS at 1 1/2T and LS at 1 T. I have also tried both at 2T with the same results. When it quits the plug is dry. The only mod I have made is the installation of the easy link carb adapter. Any suggestions??
Rob
Kingpeg is offline Find More Posts by Kingpeg
Old Apr 01, 2007, 09:52 PM
Tcrafty is offline
Find More Posts by Tcrafty
Joined Sep 2006
We had simliar problem with our G38 in a Rascal 110 ARF. Turned out that the carb needed rebuilt, the pump diaphragm was hard and not working properly. Now, one flip and it's running. Hope it helps.
Tcrafty is offline Find More Posts by Tcrafty
Old Apr 02, 2007, 06:42 AM
Kingpeg is offline
Nova Scotia
Joined Feb 2005
Will check this out . Thanks
Rob
Old Apr 02, 2007, 01:29 PM
Athlon-DHU- is offline
Find More Posts by Athlon-DHU-
Joined Feb 2007
Ya the gas engines use eather wallboro or tillison carburatiors they have built in fuel pumps and check valves in them-little flapper valves. And work buy the pressure in the crank case pressure,every time the piston goes up and down in the cyclinder it creates a positve and negitve pressure in the crank case. Useing this pressure-A pulsateing pressure thru a port to the dieafram in the carb, moves it back and forth creating the fuel pump in the carburatior with the flapper valves letting it in and sealing the fuel off from back flowing and forceing it forward to the jet to be sprayed into the venturi. Alot of time what happens is the rubberized seal gaskets that contain the flapper valves dry rot and have to be replaced.
Athlon-DHU- is offline Find More Posts by Athlon-DHU-
Old Apr 02, 2007, 02:19 PM
mtwister is offline
Find More Posts by mtwister
Salem, Or.
Joined Jul 2006
I'd start by opening both needles to 2 turns, and recheck from there.
mtwister is offline Find More Posts by mtwister
Old Apr 02, 2007, 07:30 PM
Kingpeg is offline
Nova Scotia
Joined Feb 2005
T crafty and Athlon-DHU I believe are on the right track. I took the carb in to a friend at the small engine shop. He said it needed a carb kit bad including the diaphrams(hadn't been run in over a year). Just got it back and won't get to try it until tomorrow evening. Results later Thanks fellows
Rob
Old Apr 06, 2007, 09:35 AM
Kingpeg is offline
Nova Scotia
Joined Feb 2005
Lined up the carb gasket, put in a $12. carb kit(wasn't run in over a year) and the G38 is now singing like a bird. For Cold start I use 1/4" rope around the prop hub. 1st pull choke on, she pops, 2nd pull choke off, and she's away. Also is an easy hand start when warm. LS at 3/4T and HS at 1T gives 7500RPM with a 18x10 MasterAir
Thanks fellows.
Rob
Alert Zenoah G-38 For Sale Dan Matheson Aircraft - Fuel - Airplanes (FS/W) 10 Mar 22, 2005 08:01 PM
Zenoah G-38 w/ Bisson pitts inverted muffler jameshow Aircraft - Fuel - Airplanes (FS/W) 2 Feb 19, 2005 10:10 AM
