Old Nov 06, 2007, 10:50 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Originally Posted by klique
Yep you can it just wont have the major speed.I would use a 7/4 slowfly e prop it will be a blast.That is what I ran on my tl 50 lite and it was awesome.
ck
7x4 prop on a 2500KV long can? I'm thinking this will be well over 35 amps with 3S lipos. My 2200KV motor pulls over 50 amps with a 7x5e and quality 3S lipos.
Just a guess.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 06, 2007, 10:53 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
The motor needs to be 1600 to 1800 kv.
ck
Just a guess.
Mark
klique is offline Find More Posts by klique
Old Nov 07, 2007, 01:11 AM
prop_nut is offline
Find More Posts by prop_nut
Munster, IN
Joined Nov 2004
CK-
I think I am looking for LiPos to work with a Castle Creations Pheonix 35 and a Medusa Afterburner 28-40-2500kv. I believe that it should be a 3S setup. I think the CC35 will only handle a 3S configuration Voltage wise and be able to use the BEC. What do you think?
Tom
prop_nut is offline Find More Posts by prop_nut
Old Nov 07, 2007, 10:52 AM
klique is offline
Mum is the word!
Joined Jun 2003
It will be pushing the cc 35 with the medusa.A 3s 3700 or 4350' would be a good choice.
ck
Originally Posted by prop_nut
CK-
Tom
Old Nov 07, 2007, 12:30 PM
prop_nut is offline
Munster, IN
Joined Nov 2004
Ok, how about new batteries and a new ESC? Any suggestions on both with the Medusa Afterburner 28-40-2500kv?
Thanks.
Tom
Old Nov 07, 2007, 12:42 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
i suggest castle creations. i have a phoenix 60 in my fifty and it is a great esc. good service from castle, and awesome programmability with the castle usb link.
now that i've been using a123 batteries in my ritewings, i have also used the suppo esc from www.lightflightrc.com/ 24 bucks for a 60amp esc. i prefer castle for using lipos. programmable cut off voltage is great.
punkrockd is offline Find More Posts by punkrockd
Old Nov 07, 2007, 12:57 PM
klique is offline
Mum is the word!
Joined Jun 2003
Tom I sent you a pm ,I have a cc 60 used that is in great shape,I also sent you prices on the battaeries.
ck
Old Nov 08, 2007, 06:53 PM
Abrams is offline
Find More Posts by Abrams
Farmington Hills, MI
Joined Jul 2006
You'll have exacty the setup I have, 3s battery, Medusa Afterburner 28-40-2500kv and Phoenix 60 ESC. I used a 6x4 prop and so far that has been my favorite.
A 2-2s setup would be nice. As a beginner, I've had some flakey launches. A little more take-off thrus might make the toss a little easier. But if I had a 4 cell setup, it would crash harder and the plane wouldn't have lasted as long.
I'm working on replacing my beat up TL-50 with Demon 40. That 50 has taken a few beatings. I am REALLY impressed with how resilliant these planes are. You've made a good choice in the TL-50.
Abrams is offline Find More Posts by Abrams
Old Nov 09, 2007, 06:57 PM
prop_nut is offline
Munster, IN
Joined Nov 2004
Medusa 2500 guide
Here is a snip from the Medusa 028-040-2500 spec sheet...
It says that if I use a 3S batt and a 6x4 APC prop, that it will max out at 33 Amps.
Does that sound right?
If so, then I could still use my Castle Creations 35 Amp ESC, and the BEC. [Castle says not to use the on-board BEC with 4S and above.]
Medusa also has a Motor Calculator on their site.
If I need to reduce current, then I can change the prop to a 5.5x4.5.
Abrams, do you know how many Amps your 3S configuration draws?
Thanks.
Tom
Old Nov 10, 2007, 03:50 PM
prop_nut is offline
Munster, IN
Joined Nov 2004
mrforsyth-
I plugged in a 2200 motor, 3S, and 7x5 prop into the motor Medusa motor calculator, it shows 49 Amps. Nice when the equations match reality. It also shows you get 56 oz (3.5 pounds) of thrust for your setup! It must really move.
Old Nov 10, 2007, 04:20 PM
So. Cal.
mrforsyth-
It definitely moves along quite nicely. The 7" dia prop gives some impressive vertical. I run 3S 5000's so I get great flight times as well.
Mark
Old Nov 11, 2007, 08:15 AM
roosevelt is offline
Find More Posts by roosevelt
Make 'n Break!!
roosevelt's Avatar
Walled 'tucky, MI. USA
Joined Apr 2006
I used a 6x4 apc on a warp 4 3 turn which I believe is 2560 kv. The static amps were between 33 and 38 depending on battery C rating and such. I use a cc35 as well. Although the CC's are underated and can take more amps than specified I limited my wot runs. Never had an issue with heat or anything. My meager 25 oz. wing screamed bloody murder when I did hit wot..
roosevelt is offline Find More Posts by roosevelt
Rave Ritewing Tl 50 Pilot Tim Nunn Flying Wings 11 Jul 08, 2007 09:32 PM
Question Ritewing TL 50 ordered! Have a powerplant question EdBall Flies! Flying Wings 47 Mar 08, 2007 11:57 AM
Yippee! Ritewing "TL 50" Build pics, Maiden and 3 Videos post #57 Newest TaSaJaRa Flying Wings 56 Mar 01, 2007 11:42 AM
newbie on a raptor 50??? needs advise gta18 Fuel Heli Talk 9 Jul 31, 2005 06:57 PM
WingWarrior/ritewing lightning 50? raptor22 Slope 0 Apr 26, 2005 03:40 PM
