Old Apr 02, 2007, 04:23 PM
roosevelt is offline
Find More Posts by roosevelt
Make 'n Break!!
roosevelt's Avatar
Walled 'tucky, MI. USA
Joined Apr 2006
Never had a problem adding too little glue. For me if anything I add too much.
roosevelt is offline Find More Posts by roosevelt
Old Apr 02, 2007, 08:09 PM
crazy pilot is offline
Find More Posts by crazy pilot
Just checking gravity...
crazy pilot's Avatar
Farmington, MI, USA
Joined Jun 2005
Hey Abrams! Where do you live? I notice we should be close by each other, where do you usually fly?
Good luck on your built, looks great!
crazy pilot is offline Find More Posts by crazy pilot
Old Apr 02, 2007, 10:03 PM
Abrams is offline
Find More Posts by Abrams
Farmington Hills, MI
Joined Jul 2006
I'm glad I'm not the only one that had the glue issue. On my next build, I'm going to put in a weep hole. That might not much sense until I explain it. The weep hole goes along with another idea I've been kicking around to get the motor mount plate in perfectly straight. I'll take some pics when I get there.
More to come. I can only do so much at a time. My work schedule and everthing else has been crazy.
Abrams is offline Find More Posts by Abrams
Old Apr 02, 2007, 11:09 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I like the idea of a weep hole.
What i do to make my life simpler is to use the wiltons cake paper it is the paper that they use to make the paper funnels for decorating cakes.
It is siloconized and almost nothing sticks to it i put a wing bed down a layer of the paper the wing itself then another layer then the top wing bed and put wieght on it till it tries..
I get almost no exspantion over the wing surfaces but i notice the glue wicks into the wing farther..
pluse i know my wing is as stright as it can be while it is curing
PaulVi is offline Find More Posts by PaulVi
Old Apr 03, 2007, 06:35 AM
rwmson is online now
Find More Posts by rwmson
Uniblab
rwmson's Avatar
Cherry Hill, NJ
Originally Posted by Abrams
I guess the best way to start is a look over the kit.
My TL50 came with what seems to be a second spar hole near the trailing edge. I see yours doesn't have that. The kit came with only 3 spars, so I'm assuming that I should ignore the extra holes?
The thought of adding another spar behind the CG bothers me, but leaving the hole vacant also bothers me. Being bothered bothers me too.
rwmson is online now Find More Posts by rwmson
Old Apr 03, 2007, 08:00 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
One is for lite build and one is for heavy build and gives extra room ,depending on you bats and weight you are installing.
ck
klique is offline Find More Posts by klique
Old Apr 03, 2007, 03:15 PM
PlusRC is offline
Find More Posts by PlusRC
aka WarpedWingNut
USA, MI, Caledonia
Joined Dec 2004
Excellent idea !! I think I'll use that on my next build.
PlusRC is offline Find More Posts by PlusRC
Old Apr 03, 2007, 06:31 PM
Abrams is offline
Joined Jul 2006
I'm still kind of bummed that I've wasted time and money by making the mistake that I did, but the only way you learn is by doing. With all of the tips I'm going to get here on top of what I've learned, my second build should be pretty solid.
Old Apr 03, 2007, 06:53 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
shet happens.
you'll be GOLDEN.
punkrockd is offline Find More Posts by punkrockd
Old Apr 03, 2007, 07:40 PM
Make 'n Break!!
roosevelt's Avatar
Joined Apr 2006
With all the money I've now spent on this hobby I figure if I learn a lesson from each mistake it's worth it. If I don't learn a lesson it just plain sucks.
Old Apr 03, 2007, 08:05 PM
Abrams is offline
Joined Jul 2006
Step 2 - Spar Slots
The spar slots are pretty easy. The video does a good job. I used a 4" dry wall screw, so that only about half of the shank was threaded. I broke off the threaded part and insert the rest into a 30 watt soldering iron. CK got his at Harbor Freight cheaper than mine. I paid $6 at Aco hardware. Aco is a lot like Ace, same color scheme, different company.
The only thing I had trouble with was getting the iron too hot. If you let it sit too long, it almost melts the foam before the screw hits it. I bought the aluminun rule from Home Depot, cheap. Run the screw right against the ruler. I like aluminum because it desipates heat fast. It helps keep the top of the slot narrow to hold the spar it. I did a little practice run on a piece of foam free handed. The iron was too hot and I didn't use the ruler. The slot cross section turned out almost square and WAY too wide. I tried a one inch screw with a smaller head with the ruler and the slot turned out too narrow but the section looked great. I went back to the big screw and used the ruler. With a little adjustment for depth it turned out perfect. It's not perfectly symetric, but it worked great.
Old Apr 04, 2007, 04:59 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I have a trick I like to use. After marking the batt bay, I draw another box around it, 1/4" larger on all sides. This is the shelf where the coro lid will sit.
Before melting out the bay I run my router/dremel set a 2mm depth, 1/4" around the bay. After that I will melt out the bay.
I find it easier to do this before the bay is cut then after. If you do it after your dremel is always tetering on the edge and the cut can be to deep.
I also don't like to melt out the shelf as it would take a steady hand and a sharp eye to do this with precision.
I am extremly picky so this helps make my build cleaner.
Atom1025 is offline Find More Posts by Atom1025
Old Apr 04, 2007, 08:35 PM
Abrams is offline
Joined Jul 2006
Excellent tip on the dremel. I used an interest method to do this, but it's not as good as yours.
As for the spar slot, I really like CK's method, but I wouldn't attempt it if I were not running to soldering iron right against the aluminum rule.
How do you cut the spar? Do you have a method that allows the spar to snap into the slot?
Old Apr 04, 2007, 11:46 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
I burn em' in like CK,
I use a crappy Ratshack 25w soldering iron with a socket cap screw that I customized. I grinded it till it was round. I then run it against a 1/8" thick by 1" flat aluminum stock from the hardware store. The spar snaps in and is level with the the wing plane.
I use this same soldering bit and technique to make the slots for the golden rod as well. Only thing I do different is use a scrap of golden rod under the strait edge at the trailing edge as a spacer. This way it'll taper off towards the end of the cut. Get my drift?
Adam
Old Apr 05, 2007, 09:13 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
More tips.
#1
Get some 1/16" x 3/4" x 3' aluminum stock from the hardware store. Use this as a flexible strait edge! I have mine bent to the shape of the airfoil. It works in either axis. I use this to mark my bays, and make marks where a solid strait edge makes it difficult.
#2
After the coro lid is glued in place it can become difficult to find the center/root of the wing. What I do is take my trusty flexy strait edge and lay it tip to trailing edge on the exposed centerline where the cores are joined. Take a ballpoint pen and make a mark all the way down the center, from the tip, across the coro, and to the motor. Now you have an easily visible centerline to mark out your servos and golden rod.
#3 IF YOU RUN A 7" PROP ON THE 50
Before cutting your servo holes, make sure you keep in mind where the linkage will attach to the elevon. If you run a larger prop on the TL50 your prop cutout will be larger. You'll have to move the servos out towards the tip about an inch more then usual. Basically what I am saying is you don't want the control horn sitting on the very inside edge of the elevon.
#4
When it come time to install the golden rod. sink your servos into the cutouts. Measure from the root to the center of the servo horn. Go to the trailng edge and make a mark at the TE the exact same dimension. Use your trusty flexy strait edge to draw a strait line from mark to mark. You will follow the center of this mark when your cutting the slot for the golden rod.( I use the same soldering iron for the golden rod as I do the spars. Just use whatever method you are comfortable with.)
#5
Always be sure to cut your golden rod down to size before you glue them in! It can be a real pain to cut them after the fact! Things can get ugly! The Goldenrod should end anywhere from 1.5-3" from the point it crosses the TE. In the video CK says 3" but I know he goes as little as 1.5" from the TE. I guess it would all depend on what your after, if you wan't huge throws you would prolly wan't more room. But with your average recommended setup 40 or 50"wing I set mine at 1.5-2" from the TE.
More to come!
Adam
Rave Ritewing Tl 50 Pilot Tim Nunn Flying Wings 11 Jul 08, 2007 09:32 PM
Question Ritewing TL 50 ordered! Have a powerplant question EdBall Flies! Flying Wings 47 Mar 08, 2007 11:57 AM
Yippee! Ritewing "TL 50" Build pics, Maiden and 3 Videos post #57 Newest TaSaJaRa Flying Wings 56 Mar 01, 2007 11:42 AM
newbie on a raptor 50??? needs advise gta18 Fuel Heli Talk 9 Jul 31, 2005 06:57 PM
WingWarrior/ritewing lightning 50? raptor22 Slope 0 Apr 26, 2005 03:40 PM
