Old Mar 30, 2007, 07:51 PM
simo10 is offline
Find More Posts by simo10
Planes from 1oz to 55lb's
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
Alert
My new test stand measures effciency by using torque and rpm measurements.
I just built a new test stand that measures efficiency of the whole powertrain (including prop!!) by measuring torque and rpm. When all the units are converted to SI, Grams of torque to Newton/meter and rpm to radian/second (rad/s) all you have to do is multiply the revolutions by the torque and it gives you output in watts! Then just divide Output/Input and you will get a percentage.
I will get pics up in a few minute, let me find the camera.
simo10
simo10 is offline Find More Posts by simo10
Old Mar 30, 2007, 08:08 PM
simo10 is offline
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
Here are the pics. The entire motor rotates on an old crankshaft and 2 bearings. The connecting rod is used and that pushes down on the scale and measures torque.
RPM's, amps, volts, estimated efficiency, time, and watts are measure by the E-meter. Please realize it still needs a little more work and an extra scale so I can measure thrust as well. The pictured balance will eventually go between the support brace and the base and move with the stand.
simo10
Thanks for checking out my project,
If you have any questions please ask!!!
Old Mar 30, 2007, 08:11 PM
willhaney is offline
Find More Posts by willhaney
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
I don't think I've seen a test stand to measure torque before...intriguing.
Will
willhaney is offline Find More Posts by willhaney
Old Mar 30, 2007, 08:16 PM
simo10 is offline
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
Inspiration came from this guy
http://www.unitedhobbies.com/communi...ts.asp?TID=308
Old Mar 30, 2007, 08:18 PM
willhaney's Avatar
Joined Feb 2004
Nice. I look forward to your tests. Any chance there'll be a video?
Will
Old Mar 30, 2007, 08:27 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Very nice!
Though, but you can only get total system efficiency if you measure both thrust and velocity off the back of the prop.
jrb is offline Find More Posts by jrb
Old Mar 30, 2007, 08:38 PM
willhaney's Avatar
Joined Feb 2004
That motor is GINORMOUS! What was it used in?
Will
Old Mar 30, 2007, 09:42 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Assume you mean my motor?
Its used for prop testing – 22” shown.
Since its synchronous, its rpm remains constant!
Tells a lot about props (dia & PITCH) when run at constant rpm.
Old Mar 31, 2007, 06:51 PM
simo10 is offline
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
A few tests with a park 480 1020kv with a 10x7 prop, tested with a 3s 3300 20c pack and a CC60. Remember the efficiency is for the WHOLE power system, so naturally, it's a little lower than what it is spec'd at.
Have fun!
Old Mar 31, 2007, 06:58 PM
simo10 is offline
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
and i finally mounted the scale correctly. I have a lab quality 10kg 2gram resolution scale coming for thrust measurements.
Old Apr 07, 2007, 11:02 AM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
Will
Then you have not searched this website.
peterangus is offline Find More Posts by peterangus
Old Apr 07, 2007, 11:05 AM
willhaney's Avatar
Joined Feb 2004
Never thought to.
Old Apr 07, 2007, 11:07 AM
peterangus's Avatar
Joined Dec 2003
Have fun!
The efficiencies you quote in post #9 are motor efficiencies.
Old Apr 07, 2007, 11:32 AM
willhaney's Avatar
Joined Feb 2004
What's up peterangus?
Old Apr 07, 2007, 12:56 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Here is a picture of my thrust stand modified as a crude Torque Measuring rig.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Test flew my new Shrike XL jetset44 Ornithopters 10 Mar 14, 2004 10:15 PM
My new Classic cut from EPS using hotwire. IBrainstorm2 Foamies (Kits) 12 Nov 15, 2003 03:46 PM
Did I ruin my new NIMH's using Triton?? av8rOC Batteries and Chargers 16 Feb 22, 2003 11:09 AM
Test flight complete with"My new Toy" kushal_22 Foamies (Kits) 0 Oct 09, 2002 05:09 PM
