This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old May 27, 2007, 07:06 AM
UH-1H is offline
Find More Posts by UH-1H
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
Originally Posted by Hangar Rat
Glad it went well. You don't say wether you were using 2S or 3S packs. I'm interested because if they are 2S then your report on the motor you use, prop and performance would be the first for that pack voltage. I have a number of 2S packs and only one 3S which I bought specifically for this aircraft.
Ratty
Hi Ratty,
I m using Pulso 22A ESC
Motor 1050kv
Prop 9 x 4.7 APC
Batteries are TP Prolite 3s 2100Mah decom from my T-rex helicopters.
The aircraft was nose heavy badly, i had to put 30g of lead on the cockpit rear, maiden and landed safely, it was nose heavy. My friends strip the lead and re do my CG, some weights at the tail about 15g. And the aircraft flew well, everyone took turns to have a try. Landed on thick grass, so the left landing gears give way. Nothing epoxy cant fix.
UH-1H is offline Find More Posts by UH-1H
Old May 27, 2007, 09:32 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
I'd have been very surprised if it hadn't been nose heavy with a TP2100 3 cell up there. I use a variety of (3 cell) batteries but they're all in the 2.8 - 3.6 oz range with around 3.2 being optimum for my personal set-up and flying style. I'd say the TP 2100 would be closer to 5 ounces?
Roger Lombard is offline Find More Posts by Roger Lombard
Old May 27, 2007, 10:15 AM
UH-1H is offline
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
around 164grams
Old May 27, 2007, 10:23 AM
Confused? Who, me?
Joined Jan 2005
My three are in the 80-100g range and those all keep the CG in the nominal area without added weight front or rear
Old May 27, 2007, 10:50 AM
UH-1H is offline
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
I m gonna reinforce the landing gears and epoxy the lead. Quite a nice aircraft to fly, even in strong wind. Way way better than the zero fighter
Old May 27, 2007, 11:25 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi UH1H,
It seems yours is the first AT-6 in Singapore.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old May 27, 2007, 11:41 AM
UH-1H is offline
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
yup, the other 2 guys are kits bought from gws shop when they were on holiday. both have no maiden nor spoke about them in the forum. but mines the first to reach here and maiden. so will the F-15
Old May 28, 2007, 03:37 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Flew an AT-6 today. And I mean flew it, as in real.....full size!
It belongs to a group that travels the country and schedules stops at various smaller airports across the country. Sat, Sun, and Mon.(5/26-5/28) they had the plane at the Weld County/Greeley Airport in Colorado.
You pay an amount depending on how long you wanna go up.
15 mins = $195
30 mins = 365
45 mins = 495
60 mins = 595
Website here: http://www.geocities.com/wwiiwarbirdrides/index.html
Got some pics, havent downloaded all of them from camera yet.
kahloq is offline Find More Posts by kahloq
Old May 29, 2007, 11:25 AM
malibu43 is offline
Find More Posts by malibu43
malibu43's Avatar
Belmont, CA
Joined Jan 2006
Well, UPS says my T-6 will get here on Wednesday, so hopefully I should get a chance to start it soon!
I'm trying to decide if this should be a A/T/E only warbird like the other GWS planes, or if I should build it with a functional rudder. What have been everyone else's experiences so far? Are you using the rudder in flight? Keep in mind this will be mainly a hand launch/belly land plane.
malibu43 is offline Find More Posts by malibu43
Old May 29, 2007, 12:21 PM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Hi Malibu,
Rudder is required if you'd like to fly aerobatics more.
Chen
Old May 29, 2007, 12:27 PM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Originally Posted by GWS CHEN
Hi Malibu,
Chen
Only if you want to perform:
Knife Edge
Hammerhead stall
What else am I missing?
I've installed rudder on a few warbirds, and find I never use it...
Red 61 is offline Find More Posts by Red 61
Old May 29, 2007, 12:30 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
snap rolls, coordinated turns, slow rolls, 4 point rolls...
gunracer is offline Find More Posts by gunracer
Old May 29, 2007, 01:10 PM
malibu43 is offline
malibu43's Avatar
Belmont, CA
Joined Jan 2006
Knife Edge
Hammerhead stall
I installed the rudder on my Corsair, and other than when I used to ROG, I never use it. In fact, at the new field I fly at, I always seem to get severe glitching on my rudder, so it would almost be better not to have it. It's weird that it's only the rudder. I built my mustang w/o rudder, and don't really use it.
Anyways, to keep this post on topic, I'll probably pull the rudder servo out of the corsair, and build the T-6 with rudder just to try it out. Then, if I decide it's not necessary, I'll just pull the servo out and secure the push rod with something. That way I can always go back to having rudder just by putting a servo back in.
I went to Michael's this weekend and priced out some Craft Smart water based paint and foam brushes. I'll probably get some silver, green, and black. This will be the first time I've used this stuff instead of Testors Spray. I can't believe I didn't use it before; it's way cheaper, and I'll be able to brush it on instead of spay, so I'll have way more control and the ability to touch up.
Old May 29, 2007, 02:40 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
My GWS T-6 is nose heavy even with a rudder servo and linkage fitted. If the rudder servo was not fitted it would be even more nose heavy.
Ken
kensp is offline Find More Posts by kensp
Old May 29, 2007, 02:44 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Okay -- you can add snap rolls to the list.
Coordinated turns? Nah.
Slow rolls and 4-point rolls -- that's the same as a knife edge, but faster.
How to tell new gws 9x7" from old? DeaninMilwaukee Parkflyers 11 Aug 31, 2007 07:01 PM
New Product ****GWS-T6: A Classic From The Past**** RAY GWS Product Announcements 1 May 15, 2007 03:00 AM
a Blast from the past :p Thomas Manson Parkflyers 1 Sep 06, 2002 10:46 PM
Blast from the past- setting up a Kalt Whisper Paul Willenborg Electric Heli Talk 10 Feb 21, 2002 11:03 PM
A Blast from the Past? Dereck Sport Planes 2 Aug 06, 2001 02:42 PM
