Old Mar 26, 2007, 05:15 PM
mike5656 is offline
Find More Posts by mike5656
mike5656's Avatar
san antonio texas
C.G. on the Dragonfly Strong
i went out last week and did some test glides. i started looking for that sweet spot. you guys who fly flat land t.d. know what it is. jack said his dragonfly was up to 72 oz. well i found the sweet spot on both my dragonflys. my c.g. is now set back 4 and 3/8 inches from the l.E. my tow hook is 1/8 of an inch in front of the c.g. and the weight is down to 67.5 oz. on the high start or the wench the dragonfly stands on its tail and goes straight up. it feels more alive now and points out thermals like an old hunting dog. hope this helps some of you guys flying the dragonfly strong. you will not belive the way this changes the way the bird flys.
mike5656 is offline Find More Posts by mike5656
Old Mar 27, 2007, 09:43 AM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Dragonfly CG
Mike;
thanks for the info.
so many times I see the manuf. suggested CG to be very conservative. A little "tweaking" and the plane takes on a whole new personality!
The reports we have say if flew good at the recommended, I can imagine what you are getting now....
Happy Landings!
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Oct 15, 2007, 10:19 AM
ajbhatta is offline
Find More Posts by ajbhatta
Lexington, KY
Joined Jul 2003
I have mine set up at about 107 mm from the LE with a IB3800 NiMH 5 cell pack and no additional nose weight.
AJ
ajbhatta is offline Find More Posts by ajbhatta
Old Oct 15, 2007, 08:18 PM
schrederman is online now
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Mine's at 112 mm from the leading edge. It's a bit twitchy, like I like it. Shows lift well, and stays in it.
Jack
schrederman is online now Find More Posts by schrederman
Old Oct 16, 2007, 09:58 AM
ajbhatta is offline
Lexington, KY
Joined Jul 2003
Cg
Looks like you both have it a little more aft than I have mine. Will try it with the CG further back, but will have to change out the IB3800 pack for a smaller one. Thanks
AJ
Old Oct 17, 2007, 02:51 AM
Jurgen is offline
Find More Posts by Jurgen
Europe - Belgium
Joined Mar 2005
Jack, are you still lowering the ailerons (instead of rising) for landing approach?
Congrats with your result!
Jurgen.
Jurgen is offline Find More Posts by Jurgen
Old Oct 18, 2007, 01:50 PM
Joined Nov 2002
Jurgen...
Yes, I still lower them. I am going to set up another program in my 9303 for this glider and fly with them raised slightly so I can fly it both ways in the same day. I'll report back.
Jack
Old Oct 18, 2007, 03:28 PM
IBWALT is offline
Find More Posts by IBWALT
W0X0F
IBWALT's Avatar
Joined Nov 2005
Originally Posted by ajbhatta
Looks like you both have it a little more aft than I have mine. AJ
AJ, ever since I have know Jack he has always flown his C/G back in the danger zone. So be careful. You might work your way back a little at a time but I bet you stop before you get as far back as Jack.
Walt
IBWALT is offline Find More Posts by IBWALT
Old Oct 18, 2007, 04:01 PM
Jurgen is offline
Europe - Belgium
Joined Mar 2005
Thx Jack, curious for your findings, I gonna check the lowering out too my models (no DFS), weather/family/available stick time permitting.
What's your reason for far aft CG's? Performance? Signalling? Both? Where is the limit for you?
Jurgen.
Old Oct 18, 2007, 06:38 PM
Joined Nov 2002
Reason for aft CG... Both... I find that models signal lift much better and cruise flatter at as near zeroed out (my term) as possible. My limit is where the model begins to tuck if I add more than half down trim. I have to be careful with reflex, and make sure I add a touch of up trim with it, so it won't speed up and tuck in that mode. It all varies - model to model - due to airfoils, moments, etc.
To set a model up, I balance it where it is recommended, or where I've calculated it to be. I then set the stab at 1 to 1.5 degrees positive pitch (depending on the airfoil). I remove weight until it gets squirriley, and add 1/4 oz. back. I double check everything to see if I can take more out. My "dive test" consists of adding 1/2 down trim and watching for tuck. If she moves out smartly without trying to scratch her tow hook with her tips, I'm there. If not, I double check everything again.
This doesn't work for everyone, but I've been doing this since I was a lowly Legionair builder back in the '70s. It hasn't failed me yet. My unballasted Dragonfly moved out nicely in the wind at TNT... with my reflex settings and aft CG, she ran very well with the slick-winged wonders.
Jack
Old Oct 19, 2007, 06:00 AM
Jurgen is offline
Europe - Belgium
Joined Mar 2005
Thanks Jack, although the terms are open for interpretation (but this is inevitable the peculiar limit of forum communication and individual judgement). For example what is "squirrely", "move out smartly", "1/2 trim" if you don't have a clue of the total travel.
Anyway it gives us the philosophy you're following and the proof that it works. Not everyone is that open book
Jurgen.
Old Oct 24, 2007, 03:50 PM
ajbhatta is offline
Lexington, KY
Joined Jul 2003
DS CG position
Thanks Walt. I will probably stay at close to present setting and see how it goes, but may move it a couple of mm back and check the response. Don't want any drastic changes. I have a beat up Amethyst 3.7 m that likes to fly on with the aft CG.
Cheers
AJ
Old Oct 24, 2007, 04:16 PM
Joined Nov 2002
Flew the Dragonfly with both programs... drooped ailerons and reflexed. It flys slower with them drooped, but has only slightly better control reflexed. That could be due to the higher speed. I am just as accurate with them drooped a bit, and the landing is slower. I did notice that I use more rudder in the drooped mode. Probably more of a personal preference thing than anything else.
It's still for sale if anyone wants a good one.
Jack
How do I C of G on a GWS Tiger Moth olly49 Parkflyers 3 Nov 12, 2003 04:44 PM
C of G on a delta Normg002 Foamies (Kits) 8 May 15, 2003 10:47 PM
C.G. on a litestick? John2549 Scratchbuilt Indoor and Micro Models 2 Jun 22, 2002 09:31 PM
C of G on the Tipsy kist2001 Foamies (Kits) 6 Feb 15, 2002 12:35 AM
