Old Mar 26, 2007, 02:03 PM
burgermike is offline
Find More Posts by burgermike
Lindale TX
Joined May 2006
Graupner ASW 22
Picked up a partially finished Graupner ASW 22 off fleabay recently and justed finished getting it assembled. However it was missing the sheets pertaining to control throws and C/G. It has a full flying stab and one instruction refers to "cutting out the incidence gauge and setting the stab incidence" before flying-of course this guage is missing-any ideas?
Also, roughly what should the finished weight be?
burgermike is offline Find More Posts by burgermike
Old Mar 26, 2007, 05:24 PM
AirBornOne is online now
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
...My first scale plane.Still have whats left.
Let me dig around for the info.
Skies.
Jay.
AirBornOne is online now Find More Posts by AirBornOne
Old Mar 26, 2007, 06:23 PM
Lindale TX
Joined May 2006
Do you still have the stab pivot plate? Mines alittle brittle
Old Mar 26, 2007, 07:41 PM
Ranfred Radius is offline
Find More Posts by Ranfred Radius
Ranfred Radius's Avatar
Central Point, OR.
Joined May 2002
Wow,
The version with the full flying stab.. That's an oldie! I had one back in the mid eighties. I flew the heck out of it. I don't remember even using a incedence meter. Can't help ya there. As for the CG. Since it has a straight LE, 30% back is a conservative starting point. Keep an eye on the fuse. Over time, the plura material gets brittle from the UV rays. I miss my 22. I also had the second version which was electrified. It was a real screamer and thermaled well too. Unfortunately, It was lost in a mid-air with Larry Jolly's 1/3 scale ASW-27 at the Los Banos scale meet back in 97..
Randy
Ranfred Radius is offline Find More Posts by Ranfred Radius
Old Mar 26, 2007, 08:07 PM
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
I might have a spare.
I remember modding mine due to damage of some kind.
The CG is 65mm from the root LE.
What does the dihedral look like Mike?
I'll take a photo of the gage with a protractor and report the angle.This fits from the Vstab TE to the top of the pivot plate.
I can't believe the flying surface throws are no where to be found!I've checked the german build sheet & the multi language sheet and no joy
Hard to believe as these kits were very well documented.
Stay tuned.
Skies.
Jay.
Old Mar 27, 2007, 06:38 AM
Lindale TX
Joined May 2006
There were about a dozen little 6"x6" sheets -like note cards- with a different step of construction on each in German! There are several gaps in the number sequences and I am guessing those pertained to the control thows.
Old Mar 27, 2007, 08:53 AM
bie is offline
bie
Find More Posts by bie
bie
maidenflight-postponer
bie's Avatar
Germany
Mike,
after reading this thread I asked in the german messageboard RC-Network and got an answer by a user named Steve, that he owns this model and is going to search for the data you’re looking for this evening.
He asked for the wingspan. Is it 2,60 Meter (about 102'')?
Andy
bie is offline Find More Posts by bie
Old Mar 27, 2007, 09:27 PM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
MIke,
I don't know if this will help but I have the I-Care ASW-22BL model (2.8 meter) and here are the recommended throws... I realize it's different than what you have but these throws may serve as some baseline values.
Ailerons 12mm up and 6mm down
Elevator 6mm up and 4 mm down
Rudder 25mm each side
...bob
bobthenuke is offline Find More Posts by bobthenuke
Old Mar 27, 2007, 09:29 PM
Lindale TX
Joined May 2006
Thanks for the input guys!
bie- yes it is about 102"
Old Mar 28, 2007, 03:32 AM
bie is offline
bie
bie
bie's Avatar
Germany
Mike,
please have a look at this.
Steve Egger put a drawing in.
Andy
Old Mar 28, 2007, 06:43 AM
Lindale TX
Joined May 2006
Thanks bie.
Is that metric or standard degrees!?!?!?
Old Mar 28, 2007, 07:06 AM
bie is offline
bie
bie
bie's Avatar
Germany
Mike,
what’s the difference?
From that sketch I would say the incidence is 2,5 degrees.
Andy
Old Mar 28, 2007, 08:58 AM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Thanks bie.
360 degree's are in a circle......metric or standard has nothing to do with it.
SZD16 is offline Find More Posts by SZD16
Old Mar 28, 2007, 11:39 AM
70 is the new 50
bobthenuke's Avatar
Joined Feb 2005
I believe that burgermike was asking the degree question "tongue-in-cheek".
...bob
Old Mar 28, 2007, 10:49 PM
Lindale TX
Joined May 2006
I appreciate all the help guys- I will try and post some pics if anyone is interested. I hope to fly it this weekend
For Sale Graupner ASW 22 102" burgermike Aircraft - Sailplanes (FS/W) 1 Apr 23, 2007 05:21 PM
For Sale Graupner ASW 22 Elektro fuselage. bgriggs Aircraft - Electric - Airplanes (FS/W) 0 Apr 04, 2006 08:29 AM
Electric ASW-22 B270 from Graupner Thomas Nelson Scale Sailplanes 6 Sep 29, 2003 06:20 PM
Motor/cell/prop recommendations from those flying the Graupner ASW-22 B270 or similar Thomas Nelson Electric Sailplanes 0 Sep 18, 2003 01:32 PM
HELP! How do I set the Correct CG on my ASW-22? marmal43 Electric Sailplanes 0 Aug 08, 2001 02:33 AM
