Old Oct 02, 2003, 12:50 PM
jnowell is offline
Find More Posts by jnowell
jnowell's Avatar
United States, FL, St Petersburg
Joined Sep 2000
And here is my solution to lightening servos. I removed all of the case and gears, and soldered a small control arm directly to the motor (all from an HS-50). I just glued the motor to the servo amp board and mounted the thing directly on the stab. If you use a LONG control arm on the control surface, the motor has enough to torque to give you positive control. Mine was literally about 1.5 inches, I didn't get a lot of throw, but it worked incredibly well.
The feedback pot was mounted to the stab, with the wipers connected to the control suface so that it moved with along with the rudder and elevator. You must use a fancy transmitter to get this to work, I had to set my throws to about 4% ATV or it would burn the motors up trying to push the feedback pot further than it mechanically could. It was a lot of effort, but at the time it was worth it
Jason
jnowell is offline Find More Posts by jnowell
Old Oct 02, 2003, 05:29 PM
Team Ireland is offline
Find More Posts by Team Ireland
Ireland
Joined Aug 2003
I have just been working with a multiplex ms-x1 and if you do the speed hack you can indeed use only 3 gears which brings the gear box weight down to 0.5g from teh origional 0.6g. But the includes the "ball race" (its not a actual ball race but its a kind of plastic thing) it also includes all of the out put gear so you could probably get it down to 0.3g with a bit of effort. a good saving in my opinion.
Regards
Ian Mc Donald
Team Ireland is offline Find More Posts by Team Ireland
Old Oct 25, 2003, 05:49 PM
Ireland
Joined Aug 2003
Did another weigh in simply by removing what would be the ball race the servo gear set is down to only 0.3g
A nice simple saving
Regards
Ian Mc Donald
Discussion New fast homebuilt - You can do it too if you miss your Projeti like I did !!! Meneer Pusher Prop Jet Models 15 Mar 09, 2007 09:39 PM
For Sale Hitec HS-56HB (X2), HS-81 (X1), Blue Arrow 3.6 and 4.3 gram servos don_craig Aircraft - General - Radio Equipment (FS/W) 5 Jan 28, 2006 02:43 PM
What You Can Do With Just a Little Imagination P. Tritle Dock Talk 5 Jun 01, 2004 08:17 AM
What you can do when bored... pcbytes Parkflyers 1 Nov 03, 2003 12:54 AM
GWS 3 gram servos? fritts Parkflyers 5 Nov 14, 2001 09:52 PM
