Ultra Light 3 Gram!!! Servos. You can do it!
Looking for alternative light servos (similar to the ultra light Westechnik 2.4's) that I could use in indoor models in the under 20" span and 4 ounce range, I decided to take two inexpensive HS-50 servos and perform some surgery.
I know this is nothing new, and we've all seen, from time to time, people doing similar things to lighten up existing components in order to make it work with smaller and lighter models. But I decided to go further and even lighten the tiny gears by drilling lightening holes in them also. What I ended up is a servo that weighs 3.0 grams !!!, this also takes into account that I had to replace the potentiometer and servo plug wires with much lighter ones. Here is what my servos ended up looking at 3 grams. The photos show the servos prior to replacing the wires with lighter ones and covering them with scotch tape, but you'll get the idea. TO GWS CEO: I really believe GWS is capable of doing similar and better as a package with their exisiting Pico servos to cut down weight. Cost could be kept the same, but would sure love to see something lighter. Manufacturing would require some additional pins on the injection molds to create the lightening holes both in the gears and cases and perhaps offer the servo only without the PCB, Offer the PCB (One board ONLY) with the Micro Chip programmed to work with up to 4 or more servos, for instance. Perhaps marry the receiver with the servo motor drivers, all in one board, to minimize having dedicated boards to each servo, a good weight saving and perhaps manufacturing costs as well. An 8 wire flex thin copper cable with an ultra light connector similar to that used in todays computers devices like CD Roms would be ideal for lightness and this would connect direct to the brain module (Receiver with servo driver circuitry). I wish I was in the manufacturing of servos, but since this requires machinery which I don't have, I am passing my wishes and peraps those of a thousand other people to the Servo manufacturers. I am addressing GWS directly because I know they listen to people and have grown fond of their direction with model products. They also make excellent stuff at reasonable prices. I'd like to hear GWS commetns. Do we have some hope? ______________________ ______ Meantime, if you care to take the time and become a "plastic" surgeon for a couple hours, you can do as I've done. You don't need a drill press or similar, a sharp Exacto hobby knife works if you take your time and plan the lightening hole arrangement and start with small holes and enlarge them little by little. Later on if I have some time, I will talk about how I modified the GWS servos and did away with all but 1 gear and How I am planning on using the elelments from a precision multiturn potentiometer to build the feedback control on the model itself. Comments are welcome. Mario I. Arguello www.micro-flight.com |
Yes, all the wires from the pot and 3 pin connector were replaced with magnet wire. No connector used, the hook up to the receiver is direct soldered. I know my servo lightening holes look "cheesy"
and although I have the machines to do perfectly spaced and drilled holes, I forced myself to do the holes with the tip of an Exacto hobby knife so that I could relate the experience to others with no special tools. It works and don't be afraid to dive into this project, the most you could loose is the cost of the servo if you do something crazy like using a soldering iron to drill the holes and you miss and mess up the circuit board instead, and perhaps a bloody finger if you are not careful with the Exacto knife. Nothing will happen if you take the time, approach the project with a good attitude, choose a day when you are in good standing with your wife, or partner, sweetheart, dog, cat whatever, it helps use common sence, but just as a disclaimer, I am not responsible if you get hurt or loose warrantee on your servo (given), so let's be clear on that .Dave, You got the most obvious idea after seeing a Westechnik servo, the question is, hey just take the motor and use a precision pot, but the precision pots (normally blue in color) I have found are not quite as smooth as the ones in the Westech 2.4 servos. But they are not as fragile either. I have not looked hard enough, I am sure I would find the right ones if I put the effort into it. Maybe someone already has it here in the US and we just don't know it. I think we can essentially arrive at some compromise with a similar precision linear pot (The blue ones) and motor configuration as you show for about maybe the same weight if not lighter weight. Anything that has a true servo with feedback control is got to be better than actuators, but I don't want to discredit actuators as these can work extremely well in some applications. The point here is working with an existing inexpensive servo and simply make it lighter. Servo manufacturers have the capacity, it is just a matter of time. I just can't understand why it is taken them so long to produce 1/2 size/weight HS-50 servos when Westeck has had already done the 2.4 servos for a while now. I mentioned cost could be kept the same as for existing GWS Pico or HS-55 servos, I would not mind and I don't think people would either, so long as we reduce the weight by 50%, ideally. What do you alll say? Mr Linn? Mario I. Arguello www.micro-flight.com |
| Thread Tools | |
| Discussion New fast homebuilt - You can do it too if you miss your Projeti like I did !!! | Meneer | Pusher Prop Jet Models | 15 | Mar 09, 2007 09:39 PM |
| For Sale Hitec HS-56HB (X2), HS-81 (X1), Blue Arrow 3.6 and 4.3 gram servos | don_craig | Aircraft - General - Radio Equipment (FS/W) | 5 | Jan 28, 2006 02:43 PM |
| What You Can Do With Just a Little Imagination | P. Tritle | Dock Talk | 5 | Jun 01, 2004 08:17 AM |
| What you can do when bored... | pcbytes | Parkflyers | 1 | Nov 03, 2003 12:54 AM |
| GWS 3 gram servos? | fritts | Parkflyers | 5 | Nov 14, 2001 09:52 PM |
