Old Mar 23, 2007, 10:29 PM
Geoff Woodward is offline
Find More Posts by Geoff Woodward
Electric's are cool
Joined Jun 2006
Wind on LRK
On a 38 Dia by 7 deep stator, I have 31 turns of .6mm wire on 1 tooth now , I reckon I could get 40 turns on it
Is 40 turns on an LRK equal to 20 turns on a DLRK
I run a 3S battery that can run at 16 amps constant
and a 9/4 APC / should I leave it at 31 turns or make it 40
Thanks a lot in advance
Geoff Woodward is offline Find More Posts by Geoff Woodward
Old Mar 24, 2007, 06:52 AM
Electric's are cool
Joined Jun 2006
Ahhha
I see now from another post you adjust the max current the motor pulls by increasing or decreasing the number of turns,,,,,, so I choose my prop, first ,, either a 9/4 or 10/5 and then adjust my turns using an amp meter to get 16 amps at WOT. This sounds easy now.
Old Mar 24, 2007, 01:19 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by Geoff Woodward
... Is 40 turns on an LRK equal to 20 turns on a DLRK ...
Almost, Kv will be 10% higher, roughly. To get the same Kv you'd have to use 2*22 winds in DLRK.
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 25, 2007, 05:02 PM
Electric's are cool
Joined Jun 2006
Ughh
Delamination across the nation , not good,, but I dont think it will matter the stator is 7 deep and the magnets are 6/6/1
the good thing is the shaft is rock solid the bearings are a 15 micron( 25 microns is 1 thou ) press fit in the bearing housing and the shaft is a slide fit in the bearings < Im pleased with it , 3 coats is nice and thick The paint seems good ,
My first motor the shaft was loose in the bearings 30 microns and the bearings were about 10 microns loose in their holders so when I fly I get a vibration in the airframe when I turn or pitch the model, just a slight buzz
Old Mar 25, 2007, 07:15 PM
Electric's are cool
Joined Jun 2006
I hit the big time
I borrowed a DVM from work that can measure 20 Amps so now I can check my first motor for volts and Amps
Im a bit worried about DVM's though when I checked voltage with my cheapDVM my ESC hit the soft LVC without the meter in place it didnt the meter must be using some juice ???
Old Mar 26, 2007, 04:12 AM
Electric's are cool
Joined Jun 2006
I measured my volts and Amps
I got a strange bad result the amps were not even 11 Amps around 10.5 and the ESC was surging ,I assume its the Soft cut LVC cutting in, this is with 2 batteries than can run at 16 Amps constant, I noticed that when I took the DVM out of the amp test circuit the motor did have more power so the DVM does drag the power down .
Next the volts , with the DVM in circuit for volts I was getting LVC also at around 9,2 volts and surging
I must have a cardboard stator or steel wire for winds, I would throw in the towel except for it doesnt fly too bad
The real long leads on the DVM must be a problem , but the basic motor, or the unknown hand me down ESC might have to go
DVM's are a pain ,they tell you things you dont want to Know
Old Mar 26, 2007, 05:12 AM
Electric's are cool
Joined Jun 2006
I can think of one thing that is bad news
Was holding the DVM probes against the connectors by hand,, I figure that is wasting about 1,5 amps , and long DVM leads are bad ,,I cant get 2.4 gold bullets from Aircraft world , I figure its about 12 amps with 9.5 volts in the air at WOT.If that ,
Old Mar 26, 2007, 09:34 PM
Electric's are cool
Joined Jun 2006
I had an idea
Used my lipo charge leads to do an Amp check ,they have 2.4 gold bullets on and short leads ,,, well 16.5 amps the motor is pulling at WOT, but with the DVM in circuit it still hits the soft cut of the LVC of the ESC ( surging ), with a full battery
( Why is it pulling the voltage down so low at WOT )
Thats pleasing,,,,, 9 volts at 16 amps is 144 watts that is why the model hauls OK
Im looking for some Loctite epoxy that is good for 90 C to glue my magnets in although superglue works I would like to try something else on the 2nd motor
Old Mar 26, 2007, 09:55 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
go for the loctite 480 known as black max.i use it for all .
olmod is offline Find More Posts by olmod
Old Mar 27, 2007, 06:25 PM
Electric's are cool
Joined Jun 2006
Yes
The loctite 480 superglue looks good for magnets ,,, 100C
Had 2 flights this morning , Im thinking that a higher C battery will fix my voltage drop problem on this little power hungry sub 2Oz motor , Im pleased as its only .5mm laminations, but it has got a low carbon flux ring on Im sure the soft iron I used has a lower carbon than mild steel , I dont know what oridinary piping is these days in the carbon range , but I may look it up
With these state of art .2 laminations, that are around the place looks like the best ones are the ones with the lowest carbon mainly and sulphur and oxygen, and other things, to a lesser extent , that is determined by how well the heat treat process was done in each case ,
So its a sort of guessing game as to how good your electrical steel is,,, that is at the core of your motor , they are definatly not all equal
I saw the test result of some steel few weeks back and it was not quite what the manufacturer claimed in his specifications
Old Mar 27, 2007, 06:54 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
I know what you mean about not up to spec's,the flux ring iron is the hardest to scource if you want the best,the only scource i have is made to order and comes only in solid round bar ordered by the ton.
Old Mar 27, 2007, 07:26 PM
Electric's are cool
Joined Jun 2006
By the ton
Gee thats a lot of motors
So seeing that carbon has such a big influence over the way your stator works( how efficient its is) maybe you could add it to your list of important things, in order of their importance , I saw a few weeks back
1 Carbon content of steel in Stator
2 Lamination thickness
3 Winding technique
4 Stator , magnet gap
5 And so on
Old Mar 27, 2007, 08:44 PM
Electric's are cool
Joined Jun 2006
Something else
That Im in the dark about too
Is the tooth thickness , when I cut my first stator I just took a guess , about what looks right , so my teeth might not be a good thickness
And also I was thinking of .;,, seeing that the magnet is flat,, of making the top of the hammerhead flat too
I reckon that outrunner design is too static, and unchanging at the moment and that something else is needed ,maybe a cross between and innrunner and outrunner , thats if I knew how an outrunner works , I dont have the faintest , nobody talks about them
Old Apr 17, 2007, 04:12 AM
MD_Pepe is offline
Find More Posts by MD_Pepe
Budapest, Hungary
Joined May 2005
I made my first LRK motor, from a HDD stator, 25.6 mm OD, 3.67 mm height, 5x5x1 N50 magnets, 25 turns of 0.5 mm diameter copper wire. I expected a slow rotating, high tourque motor, but I am dissapointed for several reasons:
1. According to my measures, it runs at 20000 rpm (measured with DPR tachometer), which is higher than my previous CD-ROM motors.
2. The current draw is 2 A, which also looks high.
3. The CC Phoenix 10 ESC stopped sometimes, which I have never epxerienced before.
I am not sure that the winding is correct, but I wound only every second tooth, the first clockwise, the second anti-clockwise. I connected the coils into a star configuration, i.e. I connected all the ends together, and I connected all the starts to the ESC.
What could be wrong?
Thanks.
Peter
MD_Pepe is offline Find More Posts by MD_Pepe
Old Apr 17, 2007, 04:47 AM
Electric's are cool
Joined Jun 2006
Yo MD
Mine is connected Delta , like 99% of LRK motors also the thin depth stators apparently go better with a DLRK wind, dont understand the 20000 RPM and 2 Amps , thats propless I suppose
How does it go on an 8/4 prop ?
That motor in picture has 2 flights and really hauls good
Discussion 160" Dynamic blown by wind on highway and crushed John Kim Korea 0 May 05, 2007 02:40 PM
wind on friday Mr. Innocent Slope 38 Jan 03, 2005 08:29 PM
FS: Graupner Cosmic Wind on Ebay ends Sept. 10 TurboFanElectric Aircraft - Electric - Airplanes (FS/W) 0 Sep 09, 2004 10:48 PM
F2G Super Corsair on LRK Kimble_Schmitz Scale Kit/Scratch Built 13 Jun 20, 2002 10:22 AM
FMA Razor + 15mph wind on the ground = WOW! uglyplane Foamies (Kits) 1 May 18, 2002 01:21 PM
