Old Mar 23, 2007, 01:57 PM
kentuckyglider is offline
Find More Posts by kentuckyglider
and proud of it!
kentuckyglider's Avatar
Northern Kentucky
Joined Jan 2007
World Engines
Hello everyone,
Has anyone heard of World Engines, based out of Cincinnati, OH? I have an 15- year old ASP .40 from World Engines and was wondering how common they were. This isn't my preferred RC line...
KG
kentuckyglider is offline Find More Posts by kentuckyglider
Old Mar 23, 2007, 06:52 PM
gzkpez is offline
Find More Posts by gzkpez
Joined Jan 2006
Does it have a two piece crankcase? If not it is just about the same as tne current Magnum. New Magnums and ASP engines are made by the same people, also SC. I am currently trying to fix mine, it has a loose needle valve and just needs the little O Ring I hope. I belive World Engines was sold to ISD then ISD to Hobbico. I learned this here, that Hobbico does not have many ASP parts; but there is no need to wory in that Hobby People sell the Magnum, have alot of parts and good info on their website.
If it is like mine most parts would not be available, except for the ones that are used on the more current Magnum, carb muffler. Bearings are just about always available from bearing vendors.
When I first got the engine I took it apart (it rattled) removed the loose piece of metal, cleaned the crank pin, then my dad cleaned up the porting a little. It is a very powerful engine, but if memory serves the engine drank a bit, used it for two year on a QB 40; which was made in the other china. I plan on using it this year.
Greg
gzkpez is offline Find More Posts by gzkpez
Old Mar 23, 2007, 10:21 PM
benlo2d is offline
Find More Posts by benlo2d
Aberdeen, WA
Joined Sep 2001
actually, I believe World Engines was sold to
Horizen Hobby.
Ben
benlo2d is offline Find More Posts by benlo2d
Old Mar 24, 2007, 03:47 PM
and proud of it!
Northern Kentucky
Joined Jan 2007
Greg
To be honest, I have no idea whether it has a two piece crankcase or not. It looks like it comes apart, so you might be right.
I've never built a fuel plane before, my dad had a trainer kit and this engine in the garage for 15 years. He finally just let me build it, but I'm having a heck of a time getting it to start. I'm using the sticky at the top of the forum on the subject, but I still managed to flood the crankcase and damage my prop. Off to the hobby shop...
KG
Old Mar 25, 2007, 09:46 PM
gzkpez is offline
Joined Jan 2006
Do you have the instructions that came with the engine? If you do there is an error (at least in mine) in a diagram that reversed the "idle needle valve" and the "throtle stop". If you do not I recomend downloading a PDF of the new Mag. 40 (it is a different engine but the same carb). http://media.hobbypeople.net/manual/210756.pdf
The props suggested in the ASP manual that I have are 9x8 to 10x6 which is a little different. (no 11 inch prop)
Greg
Old Mar 27, 2007, 05:52 PM
and proud of it!
Northern Kentucky
Joined Jan 2007
I have the original instructions, but the diagram was alright. This is really pretty old. I'd scan the instructions for those of you who are curious, but I don't have a scanner.
Thanks for the info, everybody!
KG
Old World Engines INC. Expert 7 Channel Help Cymbilant Radios 36 Jul 04, 2015 04:01 PM
World engines Expert TX- pos or neg? KeithK Radios 6 Aug 18, 2009 09:21 PM
Alert World engines .40 "Como" 78starfire Engines 9 Jun 11, 2007 06:28 PM
ROBINHOOD 80 KIT [World Engines] gneely Aircraft - Electric - Helis (FS/W) 0 Aug 06, 2003 01:29 PM
