Old Mar 23, 2007, 10:23 AM
DsWright is offline
Find More Posts by DsWright
ProBro #1889
DsWright's Avatar
United States, OH, Amelia
Joined Aug 2004
what is the difference between these 2 frames?
what is the difference in this one: http://www.deeteeenterprises.com/NS....UpG.HS1107.php
vs. this one?
http://www.deeteeenterprises.com/NS....HS1137T-00.php
Any major difference besides one is 1/2 the cost?
looking to get direct to swash going on my T-rex XL.
thanks
DsWright is offline Find More Posts by DsWright
Old Mar 23, 2007, 11:10 AM
discoboy is offline
Find More Posts by discoboy
Joined Sep 2004
Well, looks like the more expensive one comes with ali bearing blocks and tail supports as well as Aligns slightly changed ratio gears where as the cheaper one uses plasic blocks and doesn't have the gears, plus it's on sale.
Personally I've not got much experience in flying these as I've only just got a Falcon 3D but from what I've read the harder your heli is the more force goes into stripping servo gears. Points of weakness and flexability can be your friend...
discoboy is offline Find More Posts by discoboy
Old Mar 23, 2007, 11:13 AM
JKY is offline
JKY
Find More Posts by JKY
JKY
Berkshire, UK
Joined Jun 2006
One is SE, the other is S/SA
JKY is offline Find More Posts by JKY
Old Mar 23, 2007, 11:18 AM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
Am i better off just buying the S Metal frame kit then? it's about the same $$...
now... Do the metal frame refitting components they sell replace all the plastic in the cheaper frame if i want to upgrade that later?
Old Mar 23, 2007, 12:29 PM
geneween is offline
Find More Posts by geneween
Conformity Kill's
Mission Viejo, CA
Joined Nov 2005
IMO I would get the CF version over the alum. version. Yest the metal parts will replace the plastic ones if you want to upgrade later, but I think you save a few peenies if you bite the bullet and get the frame and alum bits together.
GW
geneween is offline Find More Posts by geneween
Old Mar 23, 2007, 12:41 PM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
I see you need to cut the CF frame for hs-56's and 65's...
do the 65's fit in the aluminum frame?
Old Mar 23, 2007, 01:10 PM
geneween is offline
Conformity Kill's
Mission Viejo, CA
Joined Nov 2005
you don't need to "cut", sometimes you need to file the rounded edges in the opening to fit the squared off edges of the servo, but you reall don't need to cut anything, a simple Xacto blade will shave the corners square. they will fit in the alum frame because thier stamped square.
GW
Old Mar 23, 2007, 02:35 PM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
GW
Good info, thanks!
What is the difference between these motors? louisd Power Systems 1 Sep 27, 2005 02:24 PM
What's the difference between these 2 batteries? Time Pilot GWS (Grand Wing Servo) 9 Oct 29, 2004 01:41 AM
What is the difference between these two GWS receivers ? robert harik GWS (Grand Wing Servo) 2 Mar 30, 2004 02:55 AM
what is the difference between these two GWS receivers? robert harik Radios 0 Mar 30, 2004 12:31 AM
What is the difference between these? Bill K. Batteries and Chargers 2 Nov 15, 2003 10:55 PM
