O.K. Just want to get this straight on plugging in to program.
Plug battery into ESC, plug ESC into card at "ESC Connection", then from "Aux. Battery Connection" to receiver with a servo lead? Then program throttle as described on page 1. In that order, or not? Sorry, but these electrics are new to me. Thanks. |
Backwing,
To program the ESC, follow these steps. 1. Hook up a motor to the ESC output leads. 2. Hook the programming card to the receiver lead on the ESC. Use the plug closest to the DIP switches with the brown wire towards the edge of the board closest to the DIP switches. 3. Set the DIP switches to the proper positions as outlined on the programming instruction sheet that came with the controller. 4. Plug a flight battery into the input leads of the ESC. You do not need to use the auxillary battery connection for the current model Scorpion ESC's. That is there for future Opto-Coupled ESC's that do not have an on-board voltage regulator. 5. After the battery is plugged in, the motor will beep 3 times to let you know that you are in the programming mode. 6. Push switch SW2 down for a second. The red LED will blink and then the motor will give a single "Beep". 7. Push switch SW4 down for a second. The red LED will blink again, and then the motor will give a single "Boop". This completes the programming of the ESC. Pretty easy! 8. Unplug the Flight battery from the ESC. 9. Unplug the programming card from the ESC. 10. Plug the receiver lead from the ESC back into your throttle channel on your receiver. 11. Hook up the battery and you are ready to fly. That is pretty much it as far as the programming goes. Let me know if you have any questions. Lucien |
Couple of questions.
I am looking for some high current controllers for hotlining and 7cell glider so the 110 comes immediately to mind as a "handy" controller. First: Any testing in regards to operation with 36/35Mhz - Seems these frequencies are a little more susceptable to controller noise than say 72Mhz (CC controllers as an example) Second: Are you planning to introduce some optically isolated controllers? and lastly - for the 110, 110A is the noted continuous capacity - any thoughts in regards to what they can handle burst wise (say 5-10 secs). - although I understand if you may not want to comment publically in this regard. cheers, Shawn |
Shawn,
The controllers are tested overseas using 35MHz and 40MHz radios, and as far as I know, there have been no reports of any glitching problems. Scorpion is working on a series of ESC's with built-in switching regulators for higher cell count operation. The sizes will run from 25 amp up to 110 for now. The 25 and 35 amp models will have a 3 Amp Switching BEC, and the 45 amp through 110 amp sizes will have a 5 amp switching BEC. Once these are introduced, Scopion has mentioned producing a series of Opto-Coupled ESC's in the higher higher current ratings. The Over-Current protection on the ESC's is set to go off if there is a 20% overload for more than about 8-10 seconds. When this happens, the ESC throttles back to 50% power to keep you from burning up the FET's. So in short bursts, the 110 amp unit would be OK for about 132 amps for 10 seconds. Any longer than that, and it will current limit, unless of course you have turned off the current limit feature with the programming module, in which case you could burn it up. Hopefully that answers your questions. Lucien |
Thanks for the feedback Lucien, answered my questions exactly
From what you are telling me these look like they will do what I want. 110amps certainly isn't high for some guys, but thats the area I generally dabble in - upto around 120amps from 2-4S setups. I think I will get one ot two and try them out. cheers, Shawn |
Alabaster AL
Joined Aug 2006
| Thread Tools | |
| zagi advice, questions, answers | easy2fly | Foamies (Kits) | 61 | Dec 11, 2009 04:38 AM |
| Question HB UG's - LiPo, Motors - Questions | iparaglide | Micro Helis | 5 | Nov 24, 2003 07:39 PM |
| Tiny-X Building - Tips, Questions, Answers, and Pictures | Manchild | Parkflyers | 264 | Dec 09, 2002 08:25 PM |
| Tiny-X Building - Tips, Questions, Answers, and Pictures | Manchild | Batteries and Chargers | 2 | Oct 31, 2002 11:28 AM |
| Didel Questions and Answers | Gordon Johnson | Indoor and Micro Models | 2 | Sep 03, 2002 01:31 PM |
