Old Apr 01, 2007, 07:25 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Yep this is the hard part.
I believe most manufacturers terminate wye because it's easier.
I'll try and get a close to the same Kv and let her rip!!! Of course this
would be an outrunner experiment for now.
Originally Posted by jfinch
Flyboy, just be sure to wind to the same Kv and fill the stator slots with wire.
I have found though (this is totally antadotal) that on very high Kv outrunners the Y terminated motors are more stable then the deltas but I wonder if it has more to do with the ESC then the motor. But for modest Kv (900 - 1800) I've not noticed any real difference between Y and delta and will wind based on the wire I have available.
fly_boy99 is offline Find More Posts by fly_boy99
Old Apr 01, 2007, 08:05 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Delta winds are easier--after making just a few motors I am pretty sure I am right. With low turn Y motors you have to deal with a rather massive bundle of wire.
Deltas are far more common than Y terminations.
Your "test" is not needed--there is enough info in the text books.
Steve
sneu is offline Find More Posts by sneu
Old Apr 01, 2007, 09:26 PM
fly_boy99's Avatar
Thanks Steve but I'll do the test anyway thanks. You can keep
your books as I've seen enough myself to do the tests.
Books are not always right:
The description on the Aveox site includes a big mistake: the oversimplified text claims that Kv doubles delta vs wye. This is simply not true. Kv increases as sqrt3, it is not just theory but measurements result too.
I agree with Aveox in the claim that wye - considering proper load - slightly better in efficiency.
Most motors I see coming out of China which of course include some of your bretheren motor makers like Hacker, et all are mostly terminating Wye. Take a newbie in a factory and try and teach him wye versus delta termination. Guess which one will win?
Some more interesting reads for ya Steve:
http://www.rcgroups.com/forums/showt...t=delta+easier
Have fun!
B
p.s. When I speak of max current I mean max current a motor can take. Yes this will be past the max eta of any motor but for example a motor wound with 2T of 16G/wye wire and a motor wound with 4T of 18G wire/delta the delta will carry more max current than the wye. As for any motor that stays within it's current carrying capacity delta vs wye is a moot discussion and only relates to Kv.
Steve
Old Apr 01, 2007, 11:06 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Have fun!
B
Come back when you have been to school! The text books were written by people that have just a bit more knowledge and experience than you
Steve
Old Apr 01, 2007, 11:38 PM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
And we digress...........
Hey guys,
I enjoyed reading all the input about the Wye versus Delta theories, many good points were made. However, to fulfill my promise that I made when I started the thread, I think it's time to steer this thread back on track to it's original purpose, which is to ask questions specifically pertaining to the use of Scorpion Motors and Speed Controllers.
For those of you that have been waiting for the 30mm motors, they are now in stock! Woo-Hoo! I just got back from the RCX show a few minutes ago, and we had a great time. Now that the show is over, I will have to take some time to post the motors up on our website. It looks like I have a BUNCH of prop testing to do!
Talk to you all later.
Lucien
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old Apr 02, 2007, 12:43 AM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
Steve
Where are your references? Even the 1st years here, know you have to reference.
Eagleburger is offline Find More Posts by Eagleburger
Old Apr 02, 2007, 07:23 AM
ukpaul is online now
Find More Posts by ukpaul
ukpaul's Avatar
Joined Aug 2006
Lucien,
What is your closest motor to a Precision Aerobatics Thrust 10 motor?
It's Specifications are...
Weight: 46g (ex bullet connectors)
Shaft diameter: 3mm
Dimensions: 26.5mm length x 28mm Diameter
KV rating: 930kv
Continues amp: 12A (ventilation is required)
Max amp: 15A /60 sec.
14 poles
ESC required: 18A
Performance with an APC 10x4.7 SF
12.1A
141W
6,825 RPM
900g / 31.8oz thrust
Link to it here
I bought one of PA's Electric Shock kits, this thing , from PA's UK dealer. The dealer does not stock the Thrust 10 motors though, so it ended up with an Axi 2212/26 on it I had spare.
The Axi lacks the impressive thrust that the Thrust 10 seems to produce in PA's vids of the Electric Shock, so I want to swop motors for one with more 'grunt', without weighing any more.
ukpaul is online now Find More Posts by ukpaul
Old Apr 02, 2007, 07:49 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
And you believe these posted numbers? The Axi lacks the impressive thrust that the Thrust 10 seems to produce in PA's vids of the Electric Shock
Alleged Performance with an APC 10x4.7 SF
12.1A
141W
6,825 RPM
I have tested the Axi 2212/26 and found it produced ~940g thrust at slightly higher rpm (7050rpm) with that prop. It needed a lot more input power though (169W) so one can only assume that this Thrust 10 is a far better made and more efficient motor than an Axi (yeah, right!). If however we take the Thrust 10 figures with the necessary grains of salt - the Axi will actually power your aircraft better!
The Scorpion 2215/22 produces numbers which are comparable with those for the Axi 2212/26, so, yes, there is a Scorpion which will do the job.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 02, 2007, 09:00 AM
ukpaul's Avatar
Joined Aug 2006
12.1A
141W
6,825 RPM
Am I correct in thinking you are saying that PA are lying about the Thrust 10's performance figures?
Old Apr 02, 2007, 10:10 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I can't say that definitively, but I would just be surprised if the Thrust 10 were a far more "efficient" motor than an Axi. If it can get 7000rpm/900g from 140W, when an Axi needs ~160-170W, that indicates that the Thrust 10 is a lot more efficient.
I am only skeptical because I have seen too many "optimistic" thrust figures from manufacturers and distributors but, if you can prove to me that the Thrust 10 really is that much better than an Axi, I'm ready to be impressed.
Old Apr 02, 2007, 02:28 PM
fly_boy99's Avatar
Sorry Lucien-
We'll put this thread back on track and let Steve have his usual arrogance.
B
Old Apr 02, 2007, 02:30 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Sorry Lucien-
B
And your usual uninformed views
Steve
Old Apr 02, 2007, 02:33 PM
fly_boy99's Avatar
For posterity... by the way it's your
p.s. Besides I have no idea why you care if I conduct experiments
at all? You never wrote any books so who are you to talk theory?
And you usual ignorance
Steve
Old Apr 02, 2007, 02:41 PM
bsc is offline
bsc
Find More Posts by bsc
bsc
Royse City, TX
Joined Jan 2003
Just ordered a 2515-18 and 25amp ESC this morning, going to try it out on my Airfoilz Edge.
bsc is offline Find More Posts by bsc
Old Apr 02, 2007, 03:19 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
All you need to do is a Google search--you will find that one of the best books is : Brushless Permanent Magnet Motor Design It does cost real money($150)!
Your "tests" will only prove that you can generate heat
Steve
zagi advice, questions, answers easy2fly Foamies (Kits) 61 Dec 11, 2009 05:38 AM
Question HB UG's - LiPo, Motors - Questions iparaglide Micro Helis 5 Nov 24, 2003 08:39 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Parkflyers 264 Dec 09, 2002 09:25 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Batteries and Chargers 2 Oct 31, 2002 12:28 PM
Didel Questions and Answers Gordon Johnson Scratchbuilt Indoor and Micro Models 2 Sep 03, 2002 02:31 PM
