Hi Sid
Don't forget that watts are corresponding to the product of two factors depending of rpm and the prop ** Static thrust ** Pitch speed For the same power you could increase one and decrease the other For acro flight increase the static thrust against the pitch speed For a racer do the contrary. Your choice (flight mission) These two factors are clearly showed in "Scorpion Calc Wizard - generic" http://www.rcgroups.com/forums/showp...&postcount=368 Down-list "user basic ratios" in the field "User/pilot" Louis |
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
Also there are times that I have fitted one of those small plastic spacer rings into the prop hole to size it properly for the prop saver. (they come with APC props) Take a closer look at the hub and you may have to remove it, flip it over, and reinstall it for the GWS prop to fit properly. If it is the same size on both sides....then a spacer is the way to go. In the picture you can see that the "hub" size is different on each side....one side fits the GWS props better than the other side. Bill |
Joined Apr 2002
Ok...that's a nice motor from Scorpion and they will stand behind it...
The Scorpion S-2503-1610 F3P Special motor is designed to be the ultimate competition motor for the indoor F3P planes. This motor is designed to run on a 2-cell Li-Po battery pack, and when teamed up with a Scorpion 11 amp ESC, provides a potent power system for your indoor model. The S-2503-1610 motor features a Titanium Main shaft, and tips the scales at a scant 20 grams (0.69 ounces). This motor was optimized to work with props such as the GWS 8x4DD and 8x4.3SF, which are so popular with the indoor fliers. If your having a problem with the recommended GWS prop not fitting securely....contact Lucien Miller at Innova8tive Designs.com for a replacement. He's a great guy..! Bill |
United States, NC, Asheville
Joined Nov 2010
Prop saver
Thanks for the help Bill & DavidN I did find a previous post where Sid suggested putting a nut in the GWS prop. I found a nut that fit and opened the hole up to 3 mm . Seems to work good now I will find out when I madin this SU-29 in the Gym this morning. Thanks again Randy
| Thread Tools | |
| zagi advice, questions, answers | easy2fly | Foamies (Kits) | 61 | Dec 11, 2009 04:38 AM |
| Question HB UG's - LiPo, Motors - Questions | iparaglide | Micro Helis | 5 | Nov 24, 2003 07:39 PM |
| Tiny-X Building - Tips, Questions, Answers, and Pictures | Manchild | Parkflyers | 264 | Dec 09, 2002 08:25 PM |
| Tiny-X Building - Tips, Questions, Answers, and Pictures | Manchild | Batteries and Chargers | 2 | Oct 31, 2002 11:28 AM |
| Didel Questions and Answers | Gordon Johnson | Indoor and Micro Models | 2 | Sep 03, 2002 01:31 PM |
