Old May 05, 2007, 11:01 PM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
turbojoe,
Scorpion is coming out with a series of High Kv 22mm motors specifically for helicopters, and there will be one for the T-Rex 450 size heli's. There will be 4 different size motors, a 2208, 2213, 2216 and 2221, and each of these motors will be available in 3 different Kv styles with Kv's of approximately 2500, 3000 and 3500 so you can find one to match the gearing of your particular helicopter.
The new HK series motors should be available by the end of May, so all of the helicopter flyers will soon be able to fly with Scorpion power too!
Lucien
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old May 06, 2007, 02:58 AM
ramovan is offline
Find More Posts by ramovan
ramovan's Avatar
United States, NV, Mesquite
Joined Aug 2004
Thanks everyone!
Thank you all! This gives me a lot more information to help me decide on a power system.
Lucien, I knew I could count on you to provide a ton of greatly detailed information. I'm glad you voted for the 3014 motor. I was thinking about going this large, but I wasn't sure if I was insane for even thinking it. I almost feel normal now.
I'm building a really HOT sport and 3D plane here so I think I want insane performance; therefore I am going to choose either the 3008-28 or the 3014-18 motor. With the 3014 the plane will have ridiculous amounts of power available, but will be heavier and require a 20C battery. The 3008 would save a little weight and I could use a 15C 2200 battery or a 20C 1800mah to save even more weight.
Like I said before, I like to over-power my airplanes. Building this airplane with the 3014 would be totally pushing the envelope and thats pretty attractive. It could be a little harder to pull it off, but it would be incredible to fly.
I'm going to think about it for the next couple days as I wait for the rest of the components to arrive. I've decided to use 4 Waypoint 6g/BB servos, a Hitec 05S receiver, and a Scorpion 35A ESC. I'll let everyone know the final decision on the power system and post a link to the build log for those that are interested in following the progress.
If anyone else has some thoughts on this please share more.
Randy Van Moody
Ramovan
ramovan is offline Find More Posts by ramovan
Site Sponsor
Old May 06, 2007, 06:19 AM
WACOFlyer is offline
Find More Posts by WACOFlyer
Keep it up, I'm reloading
WACOFlyer's Avatar
In my home
Joined Jan 2006
Lucien,
Do have any recommendations for prop size for the Scorpion 3008-28? Maybe expected thrust as well?
I'll be using a 35amp Scorpion ESC, Berg4L and 3 cell 20C 2100mah lipos.
WACOFlyer is offline Find More Posts by WACOFlyer
Old May 06, 2007, 07:06 AM
Yardbee is offline
Find More Posts by Yardbee
Yardbee's Avatar
United States, CA, Blythe
Joined Jun 2004
WACOFlyer: Iam Using the Scorpion 3008-28 With a 11X5.5 As Recommended By Lucien. The Specs Are: 35.4 Amps @ 371 Watts @ Full Throttle, & 52oz's Of Thrust With a Prop Speed Of 45 MPH. Hope This Helps You. Cheers:JP
Yardbee is offline Find More Posts by Yardbee
Old May 06, 2007, 10:11 AM
AirWolfRC is offline
Find More Posts by AirWolfRC
Joined Apr 2004
flux ring ?
You refer to the outer casing as a flux ring.
What is it made of ?
AirWolfRC is offline Find More Posts by AirWolfRC
Old May 06, 2007, 10:33 AM
WACOFlyer's Avatar
In my home
Joined Jan 2006
Thanks, Yardbee.
Old May 06, 2007, 01:41 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
That doesn't seem very efficient - that comes out at only ~3.98g/W - is that too much prop for that motor?
10.5v, 35.4A, 371W, 8650rpm, 45mph, 1476g, 52oz, 3.98g/W
I know this is a ridiculous comparison (apples to cucumbers or something) but I happen to have just run an 11x5.5 on a LightFlight 2T Long - geared 2.29:1 getting similar rpm figures.
Not really valid comparison since the LightFlight with TM 2800 is 130g, and the Scorpion is only 85g.
But the LightFlight got this:
10.5v, 28.7A, 300W, 8850rpm, 46.1mph, 1600g, 56.34oz, 5.33g/W
That's 2% higher rpm (neither here nor there) but, from 20% less input power.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 06, 2007, 02:21 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Has to be made of iron (not stainless steel).
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 06, 2007, 03:05 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi guys
If you take one prop (for example a 11x5.5) turned by 2 motors A and B
* If A weight is 85 g and overloaded relatively to its peak eff% (83%) you have an operating point could be at 72%
* If B weight is 130 g and selected to get its peak eff for the same prop (could be 81%)
The scientific comparison shows that B with 81% is better than A with 72%
It is not a proof that B is intrinsically better than A.
As a retired radar expert and specialist of DSP we have a word in this technical community that is:
"A matched filter is better when considering S/N ratio"
Louis
Fourdan is offline Find More Posts by Fourdan
Old May 06, 2007, 03:43 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I agree absolutely, Louis. I was interested in making the comparison, simply because of the coincidence in timing of my testing of the LightFlight with the posted numbers for the Scorpion.
Old May 06, 2007, 04:18 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
I think that a S3008-32 is better and more efficient this to propeller APC 11x5.5 and serious far better with a KV. slightly lower. A Kit of the S.3008 winded to kv. of 920-950 serious ideal for this prop. and the 12 x6. for applications of 3d. in 23-30 oz airplanes.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old May 07, 2007, 07:52 AM
Frojd is offline
Find More Posts by Frojd
Frojd's Avatar
Sweden, Västra Götaland, Goteborg
Joined Aug 2005
Hi Lucien!
My dad's got a Supra Star 25, which he never finished building. Today we're building with depron but I think it would be awesome to finnish this fantastic balsa kit. As we're only flying electric an electric-conversion is what I want to do.
According to the box (IIRC) the measurments are ~1,2m ws and 1,05m lenght. AUW should be 1400-1600g. The plane is designed for a .25 engine i think, but i've read that it flew better with a bit bigger.
Anyway, I played round in the scorpion calc and found some different combinations. Due to the landing gear i think a 9" prop is max, maybe 10" if i'm lucky. A graupner 9x6 gas prop or something like that is included in the box.
Lightest weight:
Scorpion 3008-28, 3s Lipo, 9x6 APC E: 26A, 1200g, 57mph
Scorpion 3008-28, 3s Lipo, 9x7.5 APC E: 30A, 1100g, 67mph
Light:
Scorpion 3008-28, 4s Lipo, 8x6 APC E: 33A, 1500g, 76mph
Scorpion 3008-28, 4s Lipo, 9x4.5 APC E: 34A, 1700g, 56mph
Scorpion 3008-32, 4s Lipo, 9x6 APC E: 28,5A, 1500g, 63mph
Scorpion 3008-32, 4s Lipo, 9x7.5 APC E: 32A, 1350g, 73mph
Heavy:
Scorpion 3014-16, 3s Lipo, 9x6 APC E: 30A, 1400g, 61mph
Scorpion 3014-16, 3s Lipo, 9x7.5 APC E: 36A, 1350g, 73mph
Heaviest:
Scorpion 3014-16, 4s Lipo, 9x4.5 APC E: 39A, 2050g, 61mph
Scorpion 3014-16, 4s Lipo, 8x6 APC E: 37,5A, 1800g, 82mph
Scorpion 3014-18, 4s Lipo, 9x6 APC E: 36A, 1950g, 72mph
Scorpion 3014-18, 4s Lipo, 9x7.5 APC E: 43A, 1875g, 87mph
That's about it, not going into anything bigger than 9". The problem is that i'm not sure how to decide which option to use. This plane is a sport/pattern plane and i guess it would need more than 1:1 to be happy. I've never built or flown any plane this big so I have nothing to compare it to. Also, my dad's built most of the fuse already and he often tend to build fairly heavy (too much glue ). Just guessing I would say that i can probably finnish the whole structure under 700g (24oz) but I really have no idea.
Also, the numbers in red are for when the motors exceed maximum A rating according to the website, how hard is this limit?
I hope Lucien or someone else here can answer this question, if not i guess I can ask a bit more about the plane in the appropiate forum.
Fredrik
Frojd is offline Find More Posts by Frojd
Old May 07, 2007, 08:48 AM
Innov8tive's Avatar
Joined Jan 2007
Frojd,
I will get back with you with some information later tonight after I have some time to look over your numbers that you have listed above.
Lucien
Site Sponsor
Old May 07, 2007, 10:21 AM
Frojd is offline
Frojd's Avatar
Joined Aug 2005
Thank you for taking the time, I'm not in a hurry!
It's not too many companies who offer this kind of advice the same day for sure,
Keep it up!
Fredrik
Old May 08, 2007, 07:55 PM
ramovan is offline
ramovan's Avatar
Joined Aug 2004
Decision made?
I think I have to decide on the Scorpion 3008 series for the Hyperion Yak-55. After checking the motor fit I discovered that it's going to be difficult to install even the 3008 motor without some creative cutting inside the airplane's mount. Either that or I would have to cut the excess shaft on what is going to be the back of the motor. Once the motor is in, there will be plently of room for it but Hyperion didn't leave enough room for installing it. I hate to do any chopping but there may not be any other way. I even took the motor apart to try fitting it in that way.... it was like a rubic's cube and I couldn't solve it.
Site Sponsor
zagi advice, questions, answers easy2fly Foamies (Kits) 61 Dec 11, 2009 04:38 AM
Question HB UG's - LiPo, Motors - Questions iparaglide Micro Helis 5 Nov 24, 2003 07:39 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Parkflyers 264 Dec 09, 2002 08:25 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Batteries and Chargers 2 Oct 31, 2002 11:28 AM
Didel Questions and Answers Gordon Johnson Scratchbuilt Indoor and Micro Models 2 Sep 03, 2002 01:31 PM
