Old Feb 11, 2008, 02:08 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Originally Posted by Smiky
Truth be told the limiting factor for motors is how much heat they can dissipate.
But with low amps. there is little heat. Run a 500 watt motor prop at 100 watt using 10 volts and 10 amps.. Next run it at 100 watts using 20 volts and 5 amps. Next try 500watts using 20 volts and 25 amps. and last 10 volts and 50 amps..
Charles
Old Feb 11, 2008, 02:56 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
Charles
..and if it survives the above, time to stand behind the shed and give her 100 volts at 5 amps .!!!
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Feb 11, 2008, 03:43 PM
Southern Pride
The point I was trying to make is that volts does not mean heat. How many volts travel through the spark plug wires under the hood?
The trends is to higher cell counts / more volts and HV ESCs. Much easier to deal with higher voltage than higher amperage to get the same power.
Charles
Old Feb 11, 2008, 03:57 PM
Smiky is offline
Find More Posts by Smiky
I do it cause it's FUN!
Oak Ridge
Joined Jun 2007
Charles
I understand the point you were making and I agree with you. If only battery pack were cheaper (regardless of chemistry) our choices would be so much easier. I'd much prefer to run a 6s pack at 1/2 ~ 3/4 the Amps and reap the benefit of extended pack life.
They're are and I think always will be trade offs and choices to be made regarding Efficiency/Cost/Weight, what works for one is not necessarily the best for others.
Mike (who hates making decisions)
Smiky is offline Find More Posts by Smiky
Old Feb 11, 2008, 06:05 PM
Joined Apr 2002
Charles
..exactly my point..and why this year most of my 3S stuff will go to 4S..what an easy way to get a 40% power gain.
The thing to watch though is at what point the increase in motor rpm will bite you.
Bill
Old Feb 13, 2008, 09:29 PM
bladebogger is offline
Find More Posts by bladebogger
Joined Aug 2007
is scorpion working on any new more efficient motors? From what I read your motor can achieve max efficiency at 12volts...and under normal operating voltages that are common say 22.2 (6s lipo) only about 70%. This seems pretty low, or maybe im just spoiled by using kontronik inrunners which are about 89% efficient.
bladebogger is offline Find More Posts by bladebogger
Old Feb 14, 2008, 03:18 AM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
bladebogger,
I am not sure which motors you are refering to, but many of the scorpion motors achieve very high efficiency ratings.
Most of the 22mm series motors have peak efficiencies of a little over 80% when running on 3 Li-Po cells. The operating efficiency at max power output is around 70%.
For the 30mm motors, most of them have a peak efficiency of over 80%, with operating efficiencies in the 74%-76% range
The larger 40mm motor, when run on 4. 5 or 6 cells have a peak efficiency of between 88% and 89%, and have operational efficiencies in the 80-85% range depending on load.
The new HK-3026 helicopter motors have a peak efficiency of around 85-86% and operate above 80% efficiency over the entire useable power band of the motor.
Some newer developments at Scorpion will produce the next generation of outrunners that will operate at over 90% efficiency, rivaling the best inrunners.
Hopefully that clears things up a bit for you.
Lucien
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old Feb 14, 2008, 04:05 AM
prinz is offline
Find More Posts by prinz
Joined Nov 2006
edited
prinz is offline Find More Posts by prinz
Old Feb 14, 2008, 04:13 AM
scultura44 is offline
Find More Posts by scultura44
Joined Feb 2008
Hey,
im completely new to scorpion motors and have heard some great things about them.
I am about to put a scorpion 3026-10 motor with 70amp esc running a 14x7e prop on an Aj Extra 330s made by Fliton.. Im sure you all know the one! Im running it on thunderpower extreme 2200mah 11.1 3s!!!
Will let you all know how it goes! Should be better than the hacker recommended setup from what i've heard!
Mickey blue eyes!
scultura44 is offline Find More Posts by scultura44
Old Feb 14, 2008, 07:56 AM
Albig is offline
Find More Posts by Albig
Das Universus Elektrikus
Albig's Avatar
NM, USA
Joined Mar 2002
Mr Bogger,
I'm using a 4025-10 as a replacement for an Actro 32-2 Heli which is rated at 89% max efficiency. I'm getting similar flight times and slightly better power from the Scorpion and it weighs 2 ounces less and costs about a third.
Any word on when the 4035s will be available Lucien??
Al
Albig is offline Find More Posts by Albig
Old Feb 14, 2008, 08:53 AM
Skylar is offline
Find More Posts by Skylar
我爱飞行 . . . I love flying
Skylar's Avatar
South Africa, GP, Pretoria
Joined Jul 2003
Originally Posted by Albig
...Actro 32-2 Heli which is rated at 89% max efficiency.
It is futile to even look at Max. efficiency ratings, since the motor will never achieve that under load. So, I wouldn't recommend choosing a motor based on that.
Skylar is offline Find More Posts by Skylar
Old Feb 14, 2008, 09:35 AM
Albig is offline
Albig's Avatar
NM, USA
Joined Mar 2002
I'm not recomending the 32-3. I'm giving a comparison of the Scorpion which has lower adveritsed efficiency than what is the most popular large helicopter motor. But it performs at least as well.
Old Feb 14, 2008, 09:52 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Lucien , I am using two Scorpion ESC's joined together with a "Y" connector as you suggested , the set up is working fine , my question is , does this set up allow the use of more servos ?
Two Scorpion 15 amp ESC's with a Thunder power 3S2100 battery.
lake flyer is offline Find More Posts by lake flyer
Old Feb 14, 2008, 10:02 AM
prinz is offline
Joined Nov 2006
edited
Old Feb 14, 2008, 11:42 AM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
I forgot to mention the successful flight of PaulVi's 36" Demon with a newly wound 3014 motor that didn't burn up at all. It ran right at 575 Watts with 4S and came down nice and cool and I even temped the windings which came out luke warm. How does a 7x7 prop sound?
I'm very confident that this setup can take 5S and it can probably take 6S with the appropriate prop and stay below 800W.
I've never seen a wing go straight up at 1/2-3/4 throttle and show no signs of slowing down:
http://www.rcgroups.com/forums/showt...684818&page=72
B
fly_boy99 is offline Find More Posts by fly_boy99
zagi advice, questions, answers easy2fly Foamies (Kits) 61 Dec 11, 2009 04:38 AM
Question HB UG's - LiPo, Motors - Questions iparaglide Micro Helis 5 Nov 24, 2003 07:39 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Parkflyers 264 Dec 09, 2002 08:25 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Batteries and Chargers 2 Oct 31, 2002 11:28 AM
Didel Questions and Answers Gordon Johnson Scratchbuilt Indoor and Micro Models 2 Sep 03, 2002 01:31 PM
