Old Dec 11, 2010, 02:00 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Originally Posted by Innov8tive View Post
tuppertn,
...If you intend to do IMAC type flying with snap rolls and other abrupt maneuvers, it can be hard on the bearings in the motor...If you do run the motor on 12 cells, you should be fine. Just be careful and keep an eye on the bearings if you do a lot of hard snap type maneuvers.
Thanks, Lucien. It's on a Sr Telemaster tow plane, so no such gobbledegook. Just looking for ways to work with the prop clearance issue.
kendall
tuppertn is offline Find More Posts by tuppertn
Old Dec 14, 2010, 04:45 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
Can i run a 12x10 apc-e prop on a 3026-890 on 4 s ? ...Dennis
Dennis Everett is offline Find More Posts by Dennis Everett
Old Dec 14, 2010, 06:58 PM
jollyroger is offline
Find More Posts by jollyroger
Central Lake, Michigan
Joined Dec 2002
Dennis, according to the Scorpion catalog the 3026-890 is rated to 70A.
the cell count/ prop chart suggests 4S with 12X6 prop as ok.
Ran this through S Calc: Version3.43: input volts- 14.8
Current: 68A
Input power: 1006.5W
Power Out : 773.6
motor/prop speed: 11217 RPM
Pitch Speed : 63.7
Thrust: 112.8 oz.
prop Torque: 93.27 oz.in.
Efficiency : 81.9%
Of course your readings will vary but hopefully this will be close enough.
Louis: Is this close to your calcs?
Good luck.
cheers
jollyroger is offline Find More Posts by jollyroger
Old Dec 14, 2010, 09:56 PM
Joined Mar 2002
I didnt think it would work , ordered the 710 already ... Thanks
Old Dec 14, 2010, 10:01 PM
Jim Varley is offline
Find More Posts by Jim Varley
Glitch Master
Jim Varley's Avatar
USA, AZ, Mesa
Joined Apr 2007
Dennis, that was wise anyway, 2 amps of headroom isn't enough IMHO.
Jim Varley is offline Find More Posts by Jim Varley
Old Dec 16, 2010, 11:19 PM
soft2 is offline
Find More Posts by soft2
Vermont
Joined Apr 2007
Lucien, when is Scorpion going to release those cool generators and wind turbines they're working on? Will you be a dealer for those?
soft2 is offline Find More Posts by soft2
Old Dec 17, 2010, 06:02 PM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
soft2,
The Generator and Wind Turbine prodict lines are still in R&D for the time being. It will still be a while before they are available for sale. As far as distribution goes, I really do not know if Scorpion will use the current hobby product distributors or use new distributors in the commercial sector.
Lucien
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old Dec 17, 2010, 10:16 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
I've been away...did the Inrunners ever come to America..?
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Dec 17, 2010, 10:55 PM
Joined Mar 2002
And when they do will they be available with gearboxes ? Dennis
Old Dec 18, 2010, 08:42 AM
Joined Dec 2002
Would be nice to see some Scorpion inrunner motors.
Been thinking about building ZippKits JAE .21 for electric. Most guys right now are using UL-1 motor.
Old Dec 18, 2010, 02:47 PM
Joined Mar 2002
I received my scorp 3026-710 in the mail today
I had a problem with a earlier motor having the magnets chipped out of the box so i took this one apart , it also has small chips in the magnets , WTH ! its hard to get a clear picture , maybe you can tell if this is gonna be a problem ?
The last one i flew before looking inside , power was way down .......
black dots are where chips are ..
Old Dec 19, 2010, 04:54 PM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
Warbird racing
I race warbirds. Usually a 40 size mustang. Looking to turn a 14x14N APC prop at 10,500 rpm or so. Does Scorpion make a motor capable of this?
Thanks, Terry
still4given is offline Find More Posts by still4given
Old Dec 19, 2010, 08:52 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Thanks, Terry
Absolutely, but frankly I don;t know exactly wich one,
The 4025 series would be my starting point.
Also they are incredibly helpful with a phone call.
they also have a motor calc program if your into that.
mikeruth is offline Find More Posts by mikeruth
Old Dec 20, 2010, 11:05 AM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Thanks, Terry
Hi Terry First, Look up Innov8tive Designs.com, download the Scorpion Calculator. You will have all the info you need to make a possible selection.
Second: In order for anyone to help you, we will need far more info than general specs of a nitro engine! What nitro engine do you have now that can spin this 14x14N @ 10500rpm? I'm pretty sure it won't be a 40 sized engine!
Expected AUW, wingspan, plane manufacturer. What cell count do you want to use, or is it wide open? How fast do you think your plane should go? Can the plane be easily converted to electric - some are really poor choices do to weight, setup. if the plane doesn't have a battery hatch, they can be real bears to convert!!
I have a Kelly Racer (Kyosho), it weighs 6lbs,6ozs RTF with a Scorpion 4020-12 on 6S/5000/25C spinning a 12/12 Apc E prop. It goes 124.6 mph according to GPS. prop is spinning @ 10200 rpm. Just an example of what to expect! Doug Bartley
Doug Bartley is online now Find More Posts by Doug Bartley
Old Dec 20, 2010, 09:09 PM
Edgar Perez is offline
Find More Posts by Edgar Perez
Joined Aug 2005
3032-690 Or 4020-10 or what?
Hello All,
I have an ASM B-17 for which I want to use Scorpion motors. I already got a pointer to the 3032-690 or 4020-10 (thanks Doug!). I want to figure out which one is better.
I ran Scorpion Calc on both of them, using 4S I got the following:
with 12X8, 3 Blade:
3032-690 :
Peak: 80% 38A OutPw 451W
WOT: 78% 56A OutPw 618W
4020-10:
Peak: 87% 34A OutPw 442W
WOT: 86% 53.5A OutPw 655
With 13X8, 3 Blade:
3032-690 :
WOT: 76% 69A OutPw 724W
4020-10:
WOT: 84% 69A OutPw 808
Seems to me the 4020 has an edge because its more efficient and has more power for this setup. Am I understanding it correctly?
I will need between 500-550W per engine for good performance (say 32Lbs @ 60-70 Watt/Lb). Seems to me that I'm very overpowered...
Your input is appreciated..
Edgar
Edgar Perez is offline Find More Posts by Edgar Perez
zagi advice, questions, answers easy2fly Foamies (Kits) 61 Dec 11, 2009 04:38 AM
Question HB UG's - LiPo, Motors - Questions iparaglide Micro Helis 5 Nov 24, 2003 07:39 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Parkflyers 264 Dec 09, 2002 08:25 PM
Tiny-X Building - Tips, Questions, Answers, and Pictures Manchild Batteries and Chargers 2 Oct 31, 2002 11:28 AM
Didel Questions and Answers Gordon Johnson Scratchbuilt Indoor and Micro Models 2 Sep 03, 2002 01:31 PM
