Old Apr 18, 2007, 07:19 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
yeah i know what you mean.
the TL40 lite that adam has i've flown and i love the way it flys. bit more floaty and still has great power.
havent flown the fity yet but i've watched adam fly his a couple times and its much different.
i'm ordering a medusa 28-40-2500 for my demon and the HET 4W is goin in my fity.
i want to start my mini demon but i'm soooo unsure of how far to cut the motor in and where to put the spar. i am using a arc motor and i'm' not sure of the batteries. i have 2 910 3s i could parallel but i'm not sure if that would be to heavy. otherwise maybe a couple 800 3s parallel. dunno its an older core and i want to keep some meat under and over the batteries.
punkrockd is offline Find More Posts by punkrockd
Old Apr 19, 2007, 03:45 PM
john wing is offline
Find More Posts by john wing
just winging it
john wing's Avatar
Fairfield, CA 94533
Joined Oct 2006
i have the mini demon ready for glass.i made a motor mount with a 20mm clam shell bracket. i cut it in the center of the wing fa lade it.i moved the cf rod glued it to the bottom of the motor mount.using 81 mg servos,25 cc esc,1320 tp 3cell lipo.i glassed the bottom so the battery is sitting on the glass about 4 layers just were the battery is.the chloroplast i use the heat gun to get to form. i like the shoe glue and hot glue combination on the lids.shoe glue then tack the corner with the hot glue.i have started the 40 inch demon the bays cut in and i am going to flush mount the servos and ad a servo bracket to remove them with a chloroplast lids for access.
john wing is offline Find More Posts by john wing
Old Apr 19, 2007, 03:59 PM
Purples a fruit
punkrockd's Avatar
Joined Aug 2006
nice john,
hey i ran up my arc motor with a 4.2x4 prop and it drew 16.4 amps at 24,500 rpm static.
finally got to play with my tach.
let me know how the plane balances. i was planing on using lighter gear along the lines of hs55's or gws pico bb. i ran 55's in a funjet and a projeti that adam gave me and i've never stripped one (knock on wood)
but my battery will be different i'd like to use the 2 910's in parallel but i was just looking at weight on hobby lobby and the 1320 is not much heavier then one 910 so i think that route will be abandoned.
910 2.3 oz's
1320 2.99 oz's
so mine would have another 1.6 oz's
Old Apr 19, 2007, 04:23 PM
just winging it
john wing's Avatar
Fairfield, CA 94533
Joined Oct 2006
if you are looking at a 2cell what about Thunder Power Pro Lite 2-cell (7.4 V) 2000 mAh Li-Po Pack with 4-pin balancer connector.
* Rating: 10-12C continuous, 20C (40A) burst
* Output: 7.4 V Nominal, 2000mAh
* Dimension: 1.97 x 2.56 x 0.51 in (50 x 65 x 13 mm)
* Weight: 2.82 oz (80 g)
Old Apr 19, 2007, 04:39 PM
Purples a fruit
punkrockd's Avatar
Joined Aug 2006
no i want a 3 cell. if i gotta buy 2s batts i'm doin a 4s mini demon and that is done already. i'd rather build it with what i've got.
Old Apr 23, 2007, 05:52 AM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Demon Video on 4s 2500kv
Shot a little video of the Demon.
Camera Man had a hard time keeping up.. But we did get a few good shots.
DEMON 4s 2500KV
Let me know what you Think....
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Apr 23, 2007, 10:02 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Very nice work Tas!! That plane gets real small real fast!! You got a good run out of those batts, what mah were they?
Charger is offline Find More Posts by Charger
Old Apr 23, 2007, 11:56 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Thanks, Charger.... They are 3800mAh TPs
Old Apr 23, 2007, 05:20 PM
Purples a fruit
punkrockd's Avatar
Joined Aug 2006
nice video TAS.
i ordered the 28-40-2500 a few days ago from randy.
cant wait. HET4W is movin down the line to the tl 50.
Old Apr 23, 2007, 11:28 PM
just winging it
john wing's Avatar
Fairfield, CA 94533
Joined Oct 2006
great music and great flying i like the pass at 3:22 it look so fast and smooth and banking the corner the colors jump out at you.
Old Apr 24, 2007, 05:42 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Thanks John....
I needed the bright colors my eyes are not as good as they once were
If it was a slowflyer it could be about any color But you can tell it's not a slow wing at all
Old Apr 29, 2007, 12:12 AM
just winging it
john wing's Avatar
Fairfield, CA 94533
Joined Oct 2006
the demon 22"
Old Apr 29, 2007, 02:42 AM
Purples a fruit
punkrockd's Avatar
Joined Aug 2006
cool, good to see her ready to go.
looks good
Old May 01, 2007, 11:29 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Got a little more done on the 40" Demon with outrunner motor mount.
I was gone to SEFF wed-sun so didn't work on it at all...
Just a few days And I should be through.
The Bottom will have a big Logo on the black in white. And I will be doing Red on the top with yellow flames...
The small electronics bays are for the RX and speed control on each end. I have a hole cut in the small doors to install an air scoop to keep things cool.
Old May 02, 2007, 06:44 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Originally Posted by john wing
the demon 22"
Looking very good John...Lets us know how it flys...
Pictures of my new Omega 1.8 !!! jshelton Electric Sailplanes 17 Aug 20, 2002 11:29 PM
Pictures of My New ELMH (redone gasser) Acer Electric Heli Talk 5 Feb 14, 2002 11:12 PM
Pictures of my CP Piccolo flying Eco8gator Electric Heli Talk 12 Jan 11, 2002 01:51 AM
Pictures of my X10 video setup (trying again) BEC Power Systems 0 Sep 16, 2001 01:59 AM
Pictures of my newly re-taped Zagi 177ichael Foamies (Kits) 7 Jul 31, 2001 03:52 PM
