Or, you could go all out with this, but I don't think any of us need this for the SC... ![]() http://www2.towerhobbies.com/cgi-bin...?&I=LXPTU8&P=0 Hope that helps! |
Oh, c'mon... what's stopping ya?
![]() Well, if I were you, I'd personally go a bit over the $125 and go with the DX6, which is great because you don't have to worry about the frequencies, since it's a 2.4Ghz radio. A lot of people are moving toward that right now, so if you're thinking of staying in the hobby, that would be your best bet. You can find it new for as low as $180 shipped (with four servos and receiver included) , but you might be able to find one for less than that used. Then the only other thing you'll need would be an ESC, and there's a WIDE array of choices out there, depending on whether you are using brushed or brushless. Tower Hobbies has some GSW brushed ones for as low as $10-$15. But there are tons of them out there (and plenty of used ones, of course...). If you want a 72Mhz radio, though, there are plenty of choices out there. A lot of people like the Hitec stuff, and of course there's always Futaba. You can't go wrong with either of them, and they're probably the two most popular ones out there in the 72Mhz stuff... Hope that helps! |
flydiver |
Not that I'm really interested, but I'm just of the curious kind...
Hey, has anyone put a prop adapter or prop saver on their SCs? I was looking at some different props today at the LHS, but they wouldn't work with the stock setup, which involves the lock nut and all that stuff.
So, what options are there out there if you want to use something different? |
I get around!
Joined Oct 2006
![]() Fun and safe flying ~Tim~ (TheDustyPagan) |
![]() So, how do you attach your prop to your brushless motor? Prop adapter? And I take it you don't have a gear set then? |
I get around!
Joined Oct 2006
Hopefully someone else in the forums can shed some light on those prop adaptors...... Fun and safe flying ~Tim~ (TheDustyPagan) |
I think there are two bearings, then the washer. And, if I'm not mistaken, there's some sort of plastic tube there, too. I'm nowhere near my plane right now, otherwise, I'd tell you... |
| Thread Tools | |
| The Ultimate Slow Stick Help Thread - Part 6 | Ron H | Beginner Training Area (Aircraft-Electric) | 544 | Feb 16, 2005 09:59 AM |
| The Ultimate Slow Stick Help Thread - Part 5 | boomerace | Beginner Training Area (Aircraft-Electric) | 793 | Sep 13, 2004 08:01 AM |
| The Ultimate Slow Stick Help Thread - Part 4 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 824 | May 31, 2004 01:00 AM |
| The Ultimate Slow Stick Help Thread - Part 3 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 639 | Apr 11, 2004 11:17 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
