Old Mar 20, 2007, 08:33 AM
treehog is offline
Find More Posts by treehog
UN Earth peoples true enemy
treehog's Avatar
Euroland
Joined Jan 2004
A few guys in the marine boats enviorement also made a few home brew 12volt versions
A few guys in the marine boats enviorement also made a few home brew 12volt versions using old marine motors or lawnmower engines etc
From the other links supplied above found this one how to make a lawn mower engine version
http://theepicenter.com/tow082099.html
its seems to be do able
For field purposes where you can put it at the other end of the runway out of range noise from small engines going like the clappers might not be a problem
The big motor turning slowly can use so little fuel one guy was 1 litre per hour kero but the machine was like 200lbs or 100kgs
Does seem 8hp motor will probably give as litle as 2kw of power so losses seem to be big
But for modeling purposes the more noisy short life high fuel consumption two stroke types at cheaper prices lighter weight would be best solution to most modelers who can always put a big sound proof curtaian in front of it to send block upwind noise disturbing the glow heads with thier glow motors
any working desines let us know but figure most will find a 240volt/110volt 2500watt sub $500 second hand building site generator the easiest off the shelf solution and run everything like at home wall socket
Ralf
treehog is offline Find More Posts by treehog
Home made Brushless in scale boats? Dongledell Scale Boats 3 May 27, 2004 08:52 AM
Just got a Robbe Dash 7,also got a few questions..... bipeflyer Foamies (Kits) 38 May 02, 2004 02:27 PM
two guys in a bar epoxy4ever Humor 6 Aug 26, 2003 02:54 PM
Any F5B/Hotliner/F5J/F5D guys in Houston, TX??? bwaltz High Performance 0 Apr 10, 2003 02:30 PM
Ideas for directing the new guys in choosing a plane JTinCT Site Chat 0 Nov 17, 2001 10:46 AM
