Old Mar 19, 2007, 10:22 PM
maddmann is offline
Find More Posts by maddmann
maddmann's Avatar
USA, OH, Newport
Joined May 2005
4.5 ah Nimh 4.8v pack discharge rate
I've got two 4.5 ah 4.8v Nimh packs that I want to check. What is a good discharge rate to check the capacity? I've got a Triton to discharge them with but I need to know the best discharge rate to check these out.
maddmann is offline Find More Posts by maddmann
Old Mar 19, 2007, 11:23 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Some manufacturers use 0.2C when establishing capacity, but that would take forever and I suspect the Triton has a timeout feature. I would discharge at 1C, but I believe the Triton has a 3 Amp discharge limit, so I would go for the 3 Amps.
Bill
ebill3 is offline Find More Posts by ebill3
Old Mar 20, 2007, 05:24 PM
maddmann is offline
maddmann's Avatar
USA, OH, Newport
Joined May 2005
Anybody else have any thoughts? I discharged them at 1.5A but they only I only got about 1000 mah out of them before they hit 4.4v. Do you discharge Nimh down to 0.9v per cell?
Old Mar 20, 2007, 05:55 PM
ebill3 is offline
ebill3's Avatar
Sanyo uses 1.0 volts per cell for the end voltage.
Sanyo says 100% capacity when discharged at 0.2C, ~95% at 1C, ~85% at 3C.
Bill
Old Mar 21, 2007, 12:24 PM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
In order to compare to factory specs, discharge at 0.2C to 0.25C down to 0.9 volt/cell. If you discharge at a higher rate or to a higher low-end voltage, you will get a lesser value for the mah.
Rodney is online now Find More Posts by Rodney
Old Mar 21, 2007, 01:19 PM
ebill3 is offline
ebill3's Avatar
Never mind - deleted.
Sold (4) DS821 Digital servos with 1100 mah 4.8v pack, switch, and hardware phoneguy Aircraft - General - Radio Equipment (FS/W) 2 Jan 07, 2007 08:16 PM
2/3 AAA 4.8v pack source? Battleseed Batteries and Chargers 0 Sep 01, 2005 02:14 PM
Can I charge a 4.8v pack with a 7.2v charger? webnetxpress Batteries and Chargers 5 Jan 07, 2003 06:40 PM
