Old Oct 11, 2002, 02:22 PM
rian.mullins is offline
Find More Posts by rian.mullins
Joined Jun 2002
use Polyurethane glue Not Epoxy
Someone mentioned using epoxy, use Polyurethane glue, Elmer's makes some. It foams up ( particularly with moisture added ) filling rather large gaps ( like a round spar in a rectangular hole )so is much lighter than epoxy, is quite tough ( non-brittle ), is strong ( much stronger than the foam you will be using it with ), and is 100% solids - meaning is doesn't have solvents that will dissolve foams.
Once you use it, you will be wanting to use it for all situations.
Really, if you're not familiar with it, go get some. Drip a little water on it to make it cure faster and expand more.
rian.mullins is offline Find More Posts by rian.mullins
Old Oct 11, 2002, 04:40 PM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Just bought 2 bottles of the Elmers Probond PolyU. I personally do not like 3M-S77 and have a huge can right here. It doesn't work so hot when gluing large 2" lengths of foam together. I'm going to give the ProBond my first try either later tonight or tomorrow. I'm glad to hear that it's so light, that's great!
Hawker is offline Find More Posts by Hawker
Old Oct 13, 2002, 05:39 PM
Glen-LV is offline
Find More Posts by Glen-LV
Las Vegas, Nevada
Joined Nov 2001
I was looking at the Grizzly Industrial catalog today and saw a spray adhesive that looked like 3M-77. It is made by Loctite and is designed for foam, carpet, fabrics, plastic and rubber. Has anyone tried this?
Glen
Glen-LV is offline Find More Posts by Glen-LV
Old Oct 13, 2002, 05:49 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Ok, I used ProBond Poly-U by Elmers. Man this stuff is strong and very light! I'm very happy with it. I glued 2 long planks of 2" blue foam together, put weights on it and let it sit for about 2 hours. Then I started cutting it and it was no problem. Had to go a little slower cutting than when using 3M spray, but this just has a much tighter bond.
Old Oct 13, 2002, 09:26 PM
mtayl is offline
Find More Posts by mtayl
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Yea, neat stuff. Once I figured out that it needs to covered with tape, it is great for all sorts of things. Here is a picture of a TE that I just glued at CF rod onto and taped with ProBond. It might be hard to see in the pictures but the arrows point to some of the foam and expansion points. This is a great way to stiffen up a TE on thin wings by the way. The CF rod with the ProBond pushing into the foam really makes a difference. If you try this, don't forget the tape!
Matt
www.yourzagi.com
mtayl is offline Find More Posts by mtayl
Old Oct 14, 2002, 01:23 PM
Glen-LV is offline
Las Vegas, Nevada
Joined Nov 2001
If you need to fill in some gaps in foam, try mixing some baking soda with the Probond. It dosn't weigh much more and sets up rock hard. Mist the surface with water, put in the Probond mix, mist with water again. I have used it to fill large gashes in my Zagi and Wedgie and it works very well.
Glen
Old Oct 14, 2002, 03:55 PM
Pacoson71 is offline
Find More Posts by Pacoson71
6 planes 2 jets 2 helis
Pacoson71's Avatar
United States, MA, Charlton
Joined Sep 2002
At Wal-mart they had a can of Elmers Extra Strength Spray Adhesive.
Order #E-456 at Elmers.com
the ing contains inorder isohexane, acetone, propane.
and at the bottom reads
no fluorocarbons,methylenechloride,haxane,methoxyor ethoxyethanol or their aceatates.
( wow that took 5 min to type)
I don't know if its good or noAnybody try this yet?
Pacoson71 is offline Find More Posts by Pacoson71
Old Oct 14, 2002, 04:08 PM
SmoothSL is offline
Find More Posts by SmoothSL
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
Acetone is the problem.. So no go on EPS foam....
SmoothSL is offline Find More Posts by SmoothSL
Old Oct 14, 2002, 04:35 PM
Pacoson71's Avatar
Joined Sep 2002
trying to find the "old" stuff sounds too hard and long drives spending $$ on gas also.
Sounds pretty reasonable to use the probond.
How do you apply it? brush, finger or stick? How thin?
Old Oct 14, 2002, 06:48 PM
mtayl is offline
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
It has the consistency of your normal Elmers white glue, looks kind of golden and comes in a squeeze bottle. The thing that is tricky about ProBond is that 1) it needs water and 2) water makes it foam up.
So what I do is:
  • wet a Q-tip
  • run that around where you are planning on glueing the stuff (you want it barely moist, not soaking)
  • run a small bead of ProBond
  • tape over it with some strapping tape.
  • wait 12 hours.
If you lightly moisten the foam then it tends to push into the foam about 0.25" inches or so and sometimes much further. Great behavior for putting spars in, etc. as long as you control the foaming action on the top with tape. Lots of people use the misting squirt bottles to kind of kick in action. I found that a Q-tip works nicely and provides enough moisture.
It will take roughly 12 hours to fully dry. After I apply it and tape it up, I'll check it every hour and wipe of any excess foam that has pushed itself out.
Matt
www.yourzagi.com
Old Oct 14, 2002, 07:08 PM
Pacoson71's Avatar
Joined Sep 2002
great site you have and thanx for the tip.
I'll be needing many more in the future just give the UPS the week to bring it to me
Old Oct 14, 2002, 08:37 PM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
The zagi manual says to spray a light coat of S-77 before taping.. What do you guys use if you don't use Super 77?
And Pacoson71, this can be found in most ALL craft stores.. Once I found it, I see it all over the place...
Old Oct 14, 2002, 08:44 PM
Pacoson71's Avatar
Joined Sep 2002
I have that elemers spray and i did see that other s77 in a small can but not sure if it was the low voc stuff.
What if I spraed the stuff from a distance Some people say it works or just scrap the can?
Old Oct 14, 2002, 09:01 PM
mtayl is offline
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
You can still use it (see http://www.yourzagi.com/s77.htm) but as other people have mentioned you need to spray into a cup or something to allow the acetone to off gas.
I have covered wings with zero S77 when I was too lazy to drive to the hardware store Although film or tape won't stick as well without it, it will stick to the foam if you lightly sand (at least 220 grit) and then clean it with some Windex or other window cleaner with ammonia in it. Make sure you lightly sand all of the strapping tape to get rid of the anti-stick coating on the tape. I put some more covering tips up at http://www.yourzagi.com/covering.htm
As far as a replacement for S77 goes, I have yet to find one but then again I have not really tried that hard. I suppose one of these days my supply of S77 will run out and then I'll be forced to experiment! Seriously though, my thought on not having any is to simply sand it, clean it, then either use the supplied tape or if you are looking for a film covering to use Ultracote. It works fine without it, just sand and clean it well.
What if I sprayed the stuff from a distance? Some people say it works or just scrap the can?
If I had some I would first try it out on the wing bed that came with the wing and see what happens to the foam but if it has acetone in it then it will eat the EPS portion of the wing. Sounds like it's about time for me to experiment a bit and update the http://www.yourzagi.com/build.htm#adhesives page. Glen-LV mentioned that loctite stuff that sounds interesting as well.
Matt
www.yourzagi.com
Old Oct 14, 2002, 09:18 PM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
Although the spraying in a cup and letting the acetone evaporate worked for joining the two halves.. It's not going to work well for placing tape on the wings.. Once the acetone had evaporated, it was all I could do to get a thin coat and not glob it on.. Matt you have a wonderful site and I think I've read every word on it.. I hightly reccommend it to everyone with a Zagi, or a flying wing for that matter.. But being that I've found the good S77 in a new can, seems to me it may be around a little while longer..
3M Super 77 Spray Adhesive culiv Foamies (Kits) 10 May 22, 2016 04:15 AM
Alert 3M Super 77 Spray Adhesive jimboyzguy The Builders Workshop 27 Apr 10, 2008 02:22 PM
New spray glue better than 3m super 77 kbstingwing Slope 10 Dec 22, 2002 12:06 AM
3M Super 77 Captain Carlton Foamies (Kits) 12 Jun 21, 2002 05:30 AM
