Old Oct 10, 2002, 08:56 PM
SmoothSL is offline
Find More Posts by SmoothSL
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
Super 77 And Zagi....
Got a new Zagi kit waiting to be assembled.. All I can find it the new Super 77.. From what I understand, if I spray it into a cup, and stir it around for a while, the acetone will evaporate and I can use it to join the two wing halves... can also use it the same way to install the spar.. Has anyone had any adverse effects from spraying the wing prior to the tape install?? I read to spray far away and in light coats... Please help.. I'm going to buy a big saw and chip California off the map for making us use this new junk.. THANKS!!!!
SmoothSL is offline Find More Posts by SmoothSL
Old Oct 10, 2002, 09:09 PM
seanpr123 is offline
Find More Posts by seanpr123
seanpr123's Avatar
United States, WI, Wausau
Joined May 2002
Ok, i reciently had this problem also... First, look at the hardware store for a smaller bottle of the old 77, it took me a while, but it was there. Also, if you just spray the new stuff from a good distance away, the acetone (i dont know to to spell it) will evaperate (like i said) and all will be well. Just test it on the extra piece first though, peace!
seanpr123 is offline Find More Posts by seanpr123
Old Oct 10, 2002, 09:29 PM
AirVenture is offline
Find More Posts by AirVenture
He wasn't always evil
AirVenture's Avatar
SW Wisconsin
Joined Jul 2001
Make sure also to look behind the products in front. Most large stores don't rotate their older products forward, so the old stuff is often in back!
-Brett
AirVenture is offline Find More Posts by AirVenture
Old Oct 10, 2002, 09:35 PM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
I've been all over, Wally World, a few Home Depots, and a couple Lowes.. K-Mart doesn't sell it here.. And all the new stuff.. Wish I would have known a long time ago... Oh well.. Thanks for the info though.....
Old Oct 10, 2002, 10:01 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Also check the fabric stores like "Joann's", and the craft stores like "Wagner's". I've found it at both places.
William A is offline Find More Posts by William A
Old Oct 10, 2002, 10:38 PM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
Wish me luck, here I go!!!!!
Ugh, this junk is sticky!!! Not sure how it will turn out.. But it's sitting there waiting for me to break it somehow... Anyhow, so far so good.. I did test it once and it was eating it up a little, but the next test proved ok.. So well see.. Would have been a lot easier had I been able to find the right stuff..
Old Oct 11, 2002, 10:02 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Why not use epoxy to join the wing halves and install the spar?
mkirsch1 is offline Find More Posts by mkirsch1
Old Oct 11, 2002, 11:43 AM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
I was under the impression that epoxy weighed significantly more than the Super77.... Maybe I'm wrong.. What kind of epoxy should I get, and what should I stay away from.. Thanks....
Old Oct 11, 2002, 01:36 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Put together a Zagi THL last week using the new 77 spray. Not a problem - just spray from a distance (2' should do fine, you'll just get the sticky stuff ALL OVER THE PLACE)
It's my 5th Zagi assembly, and I've used 30 min epoxy for all kits to join the wings. However, the THL does have a different foam from the LE & 3C kits, so you should experiment on the jig pieces first. For instance, the EPP section will take household goop, but this burns right through the other foam of the THL. Be careful or you'll end up with a shorter wing - actually, my second THL flew great w/ 1" melted from the roots.
Anyway, good luck in the construction. It may do you some good to use a silicone glue to join the nose and epoxy for the rest, as epoxy shatters when you crash enough.
ajroahkni is offline Find More Posts by ajroahkni
CactusJackSlade is offline
Find More Posts by CactusJackSlade
Whadda YOU lookin' at?
CactusJackSlade's Avatar
United States, CA, Folsom
Joined May 2002
3M spray on EEP OK! on EPS CAREFUL!
What kind of Zagi did you get? if it's the 3-C and all EPP you are fine, spray away! But if you have any of the others with the EPS leading edge bonded to the EPS (styrofoam) body, then yes, be careful.
Another place I found that has the OLD 3M is Mitchaels craft stores.
CJS
CactusJackSlade is offline Find More Posts by CactusJackSlade
Old Oct 11, 2002, 02:20 PM
bosley is offline
Find More Posts by bosley
bosley's Avatar
United States, SC, Beaufort County
Joined Jun 2002
I found a few cans of the old stuff in a small local hardware store. They seem to have a slower turnover of inventory and still had a few cans of the good stuff.
Boz
bosley is offline Find More Posts by bosley
Old Oct 11, 2002, 02:23 PM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
Hey guys, great news.. Went to Michaels craft store and they don't have the old can, but it's a new Purple & Black can.. It mentions on the cap that it contains less than 75% VOC's.. Now before you say this is the wrong one.. I have also seen the same can at Wal-Mart.. The one at wal-mart said it contained acetone, this one with the VOC warning does not contain acetone.. All components are:
Cyclohexane
2 - Methylpentane
Dimethyl Ether
Isobutane
Propane
3 - Methylpentane
2,3 - Dimethylbutane
2,2 - Dimethylbutane
n-hexane and other hexane isomers...
Can someone verify on the old can if this is the same?? Thanks!!!!
Old Oct 11, 2002, 02:28 PM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Pretty sure that's the old one, as the new one distinctly has acetone as the primary ingredient.
Old Oct 11, 2002, 02:48 PM
SmoothSL is offline
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
Great, now you guys have something else to look for when you go into the stores.. It distintly says junk about VOC's on the cap.... Good luck!! It comes in both small and big cans.. Both have the VOC warning..
Old Oct 11, 2002, 03:16 PM
mtayl is offline
Find More Posts by mtayl
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Although I historically use S77 for joining winghalves together, a Polyurethene glue called Elmers ProBond works great as well. A little bit on a slightly damp surface will cause the ProBond to foam like crazy and force itself into the foam for quite a ways. Also great stuff for glueing in spars with but you need to be careful about not forgetting to tape over the glued area to prevent the foam from going everywhere. It's sandable, just not much fun to do.
I went on a shopping spree when I found out they were changing the formula. Home Depot in Colorado still has the old stuff on the shelves as of last week. If you hunt around the shelves you can generally find it behind everything else.
Matt
www.yourzagi.com
mtayl is offline Find More Posts by mtayl
3M Super 77 Spray Adhesive culiv Foamies (Kits) 9 Mar 21, 2009 02:20 PM
Alert 3M Super 77 Spray Adhesive jimboyzguy The Builders Workshop 27 Apr 10, 2008 03:22 PM
New spray glue better than 3m super 77 kbstingwing Slope 10 Dec 22, 2002 01:06 AM
3M Super 77 Captain Carlton Foamies (Kits) 12 Jun 21, 2002 06:30 AM
