Old Oct 10, 2002, 07:46 PM
SpaKack is offline
Find More Posts by SpaKack
SpaKack's Avatar
United States, CA, Brentwood
Joined Oct 2001
Stick plane with plastic shell
Why cant someone out there make a basic plane like the light stick that has different shells to fit over it making it into any kind of plane..You could keep all your electronics in the base unit and add on the outer shell and control surfaces and make it into whatever you feel like flying..then all you have to buy is the different outer covering and wing kit and you have a whole new plane..I just think it would be cool to be able to swap out for a new looking plane without the building
SpaKack is offline Find More Posts by SpaKack
Old Oct 10, 2002, 07:51 PM
SpaKack is offline
SpaKack's Avatar
Joined Oct 2001
you could have hard points on things that attach to the stick so that the shell could be removed with pins..like the way an r/c car shell is attached...the kits could come painted and with control horns already on..just make the change of skin and fly..
Old Oct 10, 2002, 09:36 PM
SpaKack is offline
SpaKack's Avatar
Joined Oct 2001
well I guess its not a winner based on all the negative feedback or lack of
Old Oct 10, 2002, 11:08 PM
SpaKack is offline
SpaKack's Avatar
Joined Oct 2001
ok someone say something..good or bad Idea say something..meanwile I did a bit of mspainting to show you what im thinking about..
Old Oct 11, 2002, 12:09 AM
slowflyer is offline
Find More Posts by slowflyer
Flying slowly along..
Northern Ca.
Joined Dec 2000
Great idea!! When Ya gonna come over to Antioch and fly Slow Sticks with us?--Rob
slowflyer is offline Find More Posts by slowflyer
Old Oct 11, 2002, 12:34 AM
SpaKack is offline
SpaKack's Avatar
Joined Oct 2001
Slowflyer, you know of any hobby shops in the area that have electric stuff?? you fly at a club or what? I had some ladie tell me that her husbend used to fly at the I think contra loma field and is now at the new one...
Old Oct 11, 2002, 01:01 AM
Northern Ca.
Joined Dec 2000
The closest hobby shop is in Concord. It's called Hobbytown USA. They're located at the SouthEast corner of Clayton rd, and Treat Blvd. There is also a guy named Mel in Antioch that sells stuff out of his house, I have his phone number if you need it.
The field/club you are referring to is called DVRC. They are now located in Pittsburg. I will have to look up the name of the street that they are at the end of, however, it is usually too windy at their field to fly parkflyer type planes. It is also a very expensive club to join, costing about $200 the last time I checked to join that club.
The cool club to fly with is the Concord Model Engineers. They have a city approved flying site located at the end of Court lane in Concord. This is right up the street from Hobbytown. You don't have to be a club member to fly there, but joining their club is only $20 a year. They have entertaining monthly meetings on the second Wed. of the month at the Concord Senior center.
They meet on Sundays at around 2pm to fly at Court lane. This is the active local electric only club in the area.
I will e mail or pm you my phone number. Maybe we can get together and run over to the hobby shop, and I can show you where the flying field is. I also have some flying spots in Antioch. Give me a call when you get time. I'm off work for a couple of weeks due to an idiot rear ending me.
I'm looking forward to meeting you---Rob
Old Oct 11, 2002, 07:40 PM
Flyfan is offline
Find More Posts by Flyfan
Rob H
Flyfan's Avatar
Australia, QLD, Cairns
Joined Jun 2002
Hi SpaKack, great idea........which I had 4 months ago !!!!!
I have various wings and motors for my J3 Stik, including some aileron wings, biplane and triplane. I replaced the wooden stik with a carbon rod.
I haven't made any bodies yet because I can't find a source of light but stiff material - say 1mm depron or similar. I've considered bending 1mm balsa by soaking it in ammonia etc but foam would be more forgiving. Last week I did some experiments with acrylic floor paint and various paper and fibreglass, nothing really turned out brilliant, although two layers of 190 gsn paper was stiffest (and heaviest).
In the park I've found that the geared 280 with a 7x360 NiMH gives 8 -10 min flights and some power for light winds. The geared 300 with 8060prop and 7x900NiMH is very powerful but can be too heavy for the lightweight carbon rod I used so I'm planning to build a stronger version. Indoors I generally use IPS A and the 360x7 NiMH pack, mucho power and flight times with a lightweight stick and biplane wings.
I make all thewings with the same distance front to back at the centre , they sit on two small pads 4cm by 1 cm and are held on with elastic bands. The motors are banded to a flat plate which has one side rail to ensure alignement. Can post a pic if you're interested.
Seems like a brilliant idea that we've had, I bet many others have too - the down side is after a bad crash you have no plane to fly (unless you brought others with you).
Flyfan
Flyfan is offline Find More Posts by Flyfan
Old Oct 11, 2002, 08:44 PM
uncled is offline
Find More Posts by uncled
Iron Mountain,MI
Joined May 2002
Good idea really :-) I've been thinking of some ways to maybe use meat tray foam to dress up the sticks with. Would be similar to the profile models. You could have a short stick model with some profile and maybe do knife edge I think the SS would be a good prospect for experimentation Could have a war bird or even a passenger type layout - - - - - lots of ways to play.
uncled is offline Find More Posts by uncled
Old Oct 13, 2002, 04:06 AM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
I've been thinking about something like this too, though probably using balsa. One big advantage is that you could make very detailed scale fuses but they would have to be strnong because the stick takes the load. OTOH you might find that in a crash the meticulously built scale fuse would turn into so much dust while your stick survived
Still, I'd be interested to hear how this works if you try it.
Good luck,
Matthew Allen
Matthew Allen is offline Find More Posts by Matthew Allen
Old Oct 13, 2002, 10:21 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Many years ago there was a company that made glow planes that were similar in principle to your idea. They were made out of a material similar to coroplast and the entire motor/gas tank/radio gear setup mounted to a pod that was inserted into the fuselage through the nose of the craft. They had several different models that all accepted the same pod, so you were only out the dollar amount of the plane iteself. As I recall, they had low wing aerobatic flyers and high-wing trainer types and other flyers in between, so you could fly the gamut on a single pod. I've never been into glow so wasn't interested in them, but I always thought it was a neat idea. I may still have an old R/C mag with pics, I'll post it if I can find it.
Tres Wright is offline Find More Posts by Tres Wright
Old Oct 13, 2002, 10:58 AM
FlycastSeven is offline
Find More Posts by FlycastSeven
Notorious Battery Abuser
FlycastSeven's Avatar
United States, MA, Cambridge
Joined Jul 2002
Tres,
The material you are thinking of is called US Air Core. I think it is actually coroplast. The ad was in the September or October issue of Model Aviation. The company bears the name of the material. They also make the slide in/out tray with everything, engine (slimer) battery, servos, and reciever. They still sell it. It would have little application in electrics as coroplast is heavy
FlycastSeven is offline Find More Posts by FlycastSeven
Old Oct 13, 2002, 11:11 AM
uncled is offline
Iron Mountain,MI
Joined May 2002
Originally posted by FlycastSeven
Tres,
Wrong - - do a search on coroplast here and see what I mean
Old Oct 13, 2002, 11:22 AM
Forney, TX
Joined Mar 2002
==The material you are thinking of is called US Air Core==
Right, that's it!
==The ad was in the September or October issue of Model Aviation. ==
Good grief, they're still making them? Wow, those have been around a looooong time! I haven't picked up anything but eelctric/silent flight mags in quite a while. I used to subscribe to R/C Modeler and saw them in there a lot.
Now that you gave me the name, a quick 'net search turned up their site here:
http://www.usaircore.com/index.html
But I don't see the removable pod models that I remember?
Old Oct 13, 2002, 11:24 AM
ktoey is offline
Find More Posts by ktoey
San Dimas, 40 km east of Los Angeles
Joined Sep 2002
SIG mfg used to market the KWIK BUILT series Super Chipmunk, P51 etc using a balsa profile and ABS shell.
These are 60 size glow planes.
I still have the SIG Super Chipmunk.
ktoey is offline Find More Posts by ktoey
Help! need a balsa 3d plane(with stick mount) for 150watts txfly 3D Flying 7 Sep 01, 2006 09:59 PM
twin motor ap slow stick... a brushed plane with 35.5oz of thrust. building soon jswjimmy Aerial Photography 10 Dec 31, 2004 09:16 PM
"stick"type plane with carbon fiber newbee E-flier Parkflyers 12 Dec 16, 2002 10:56 AM
Spad plane with jeti brushless? help! Barrett Electric Plane Talk 0 Sep 09, 2001 10:04 PM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 10:52 PM
