Old Mar 19, 2007, 01:44 AM
LuxLuthor is offline
Find More Posts by LuxLuthor
Connecticut, USA
Joined Mar 2007
Taps to charging cradle - Hyperion 1210i LBA-10 balance charging of free Li-Ion Cells
First post here not as an RC'er, but rather a high performance flashlight hobbyist from the CandlePowerForums, and seeking your help with safely charging individual Li-Ion cells like sold in this thread.
I bought the Hyperion 1210i recently, and am trying to figure out how to do a 4S or 6S (1P) Li-Ion charging setup that would also allow me to use the LBA-10 balancer. Obviously, battery holder packs like these are in series and do not allow individual taps to each cell, and especially with unprotected cells is a major fire/explosion risk.
I do not want to solder to these cells, as they have a delicate Protected PCB circuit under the + terminal. I'm wondering if I can put six individual cells in three simple battery charging cradles like this image, which has two "slots" to hold 2 batteries of various sizes.
Then I could solder individual wires to each terminal connector so it gets configured for a 6S (1P) setup and harness using the layout illustrated on this RC Calculations site.
That series of 6 battery slots (in 3 cradles) would be wired to this harness connector and plugged into the LBA-10 (& 1210i) for faster and balanced charging.
I just do not know if you can setup a charging "pack" of cradles with slots in series like this with plain wires going to the harness connector without having any balancing PCB that (I think) is normally in the Hyperion battery packs.
Here is an example of a nice MagLite mod that uses 8 x 14670 Li-ion cells to give an output of about 1500 Lumens (where normal 2D size Maglite puts out about 15-20 lumens).
LuxLuthor is offline Find More Posts by LuxLuthor
Old Mar 19, 2007, 05:20 PM
Connecticut, USA
Joined Mar 2007
If it is not safe to try and make a way to charge free Li-Ion cells in a 4S or 6S setup, I don't need to. It's just really a question of what is involved with the "taps" that are in LiPo packs. I have not been able to find any free Li-Ion cell chargers that hold more than two slots...and it seems there could be a safe setup with balancing that could work with my Hyperion & LBA-10.
Old Mar 20, 2007, 06:38 AM
Connecticut, USA
Joined Mar 2007
Here was another thread that shows their FAQ diagram. The idea is to use the charger terminals to solder the balancing taps to that would go into a harness for the Hyperion, instead how they are normally attached to the ends of the batteries in packs.
Old Mar 20, 2007, 05:06 PM
HPSOV is offline
Find More Posts by HPSOV
Sydney, Oz.
Joined Mar 2006
I think that last diagram answers your question. You somehow need to add the 'charging leads' to your battery pack for balance charging. This is how all our LiPo packs are wired.
HPSOV is offline Find More Posts by HPSOV
Old Mar 20, 2007, 07:50 PM
Connecticut, USA
Joined Mar 2007
Yes, although I am going to add the taps to the charging cradle contacts. Also have someone interested in fabricating a cradle that would have 10-12 in series slots with adjustable springs for many battery sizes & taps on the contact points...which will go into a harness back to the LBA-10.
This is a huge market, as the only way to safely charge multiple Li-Ion cells now is with very low current 2 slot chargers.
Old Apr 29, 2007, 12:19 AM
Connecticut, USA
Joined Mar 2007
Just wanted to post this for posterity in case anyone does a search for charging individual Li-Ion cells. The details about it are in this CPF forum thread.
Discussion Hyperion balance charging three 4S packs? BBfour Batteries and Chargers 11 Jul 27, 2007 04:21 AM
Discussion Charging an 8S or 8S & 4S on the Hyperion 1210i with LBA10s ? All__talk Batteries and Chargers 1 May 16, 2007 09:55 PM
Question Hyperion LBA 10 adaptors for non-Hyperion packs? Andrew McGregor Batteries and Chargers 6 Aug 20, 2006 09:54 AM
how to do C/10 slow charging for cheap? whateverdude Batteries and Chargers 3 Aug 20, 2002 07:45 PM
Schulze chameleon charger - does it make C/10 slow charging unnecessary? Balin Power Systems 5 Mar 15, 2002 07:13 PM
