Old Mar 18, 2007, 05:01 PM
mdavenport is offline
Find More Posts by mdavenport
Joined Dec 2005
How do you know when your main motor is going on a HBFP?
Is it possible to tell if the main motor on the HBFP is on its way out. I think I must be getting close to the 10-20 hours that is quoted for its lifespan, and this could have been reduced by upgrading to a lipo (even tho I have a heat sink)..
One of the reasons I ask this is a started to get quite a bit of vibrations going through the heli whilst hovering at about waist height in the garage.
I haven't had any crashes that could have moved/broke anything that could cause these vibrations so was wondering if a motor on the way out could do this?
Mark
mdavenport is offline Find More Posts by mdavenport
Old Mar 18, 2007, 05:46 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
I think I've heard people say you get main motor glitches, and the tail can suddenly swing out 45 degrees or more as the main motor torque changes.
I'd suggest listening to FM radio to see if you can hear more interference than usual, or checking to see if you can see the brushes are worn out.
I don't think an old main motor is likely to cause vibes, as the brushes wear out long before the bearings.
RobinBennett is offline Find More Posts by RobinBennett
Old Mar 18, 2007, 06:27 PM
Chris_K is offline
Find More Posts by Chris_K
Design, Build, Crash?, Repeat
Chris_K's Avatar
Monroe, CT
Joined Mar 2005
I just went through the "worn out motor trouble" scenario with my HB CP2 for the first time. Started having trouble after about 25 packs, which comes to around 6-7 flight hours. The heli started glitching, the motor started running very hot, the run times went way down, and things just didn't feel right, particularly with the tail. That makes sense, since if I needed more left stick to hover as the motor got overheated, it would push things futher up the revo-mix curve, and make the tail feel off.
Just changed the motor out yesterday, and it feels like a new machine again. It was shocking how much of a difference it made, returning the feel "back to normal."
Regards,
Chris
Chris_K is offline Find More Posts by Chris_K
Old Mar 18, 2007, 10:42 PM
DobsOnly is offline
Find More Posts by DobsOnly
NE Florida
Joined Dec 2006
Changed out my main motor after well over 110 flights. Tail motor at 80 or better. No vibration associated to either of them.
A few thing to look at that have caused me problems with vibration:
Check Rotor blade balance and tightness should be loose enough to allow then to swing into Center when spinning up!
Check Flybar balance.
Check Rotor head for wear in the area that the Center Hub bearings seat.
Check for an out of round or cracked Center Hub.
Check the collar on the bootom of the Main Shaft. Mine was a little loose and allowed a lot of vertical movement on the Main gear and shaft. This made any vibration seem worse than normal.
Check that the ESC is mounted to both the botom and rear of the holder. Mine came loose and would cause an exagerated shaking and possibly some glitching.
Good Luck with it!
Dobsonly
DobsOnly is offline Find More Posts by DobsOnly
Old Mar 19, 2007, 04:34 AM
Joined Dec 2005
Good Luck with it!
Dobsonly
Thanks for info, will check it out.
On the point of the ESC mounting, that L shaped bracket snapped on the joint after a heavy landing. The ESC is still stuck to the bottom bit but the rear of the holder is loose. I tried to overcome this by cable tieing around the ESC and the rear bit of the holder and whilst it is tight, it could be the cause of the vibration i guess.
Can this section be repalced on its own or does it connect to the main shaft that runs through the heli?
Mark
Old Mar 19, 2007, 05:27 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
You can shine a flashlight on the endbell. Motors with less than 1mm brush (thickest part of brush) is near death.
If you are just hovering, it will be difficult to tell without visual inspection. If you can punch out already, you will notice that with a worn motor, the ehli is bogged down.
Gino CP is offline Find More Posts by Gino CP
Old Mar 19, 2007, 05:40 AM
bhbuster is offline
Find More Posts by bhbuster
bhbuster's Avatar
Huntsville, TX.
Joined May 2006
When my motor went, I had to tap the blades to get them to spin.
Brian
bhbuster is offline Find More Posts by bhbuster
Old Mar 19, 2007, 05:57 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Don't allow your motors to reach that point. The motors can still run even if the brushes are gone. And when the arms wear through, they swing to the other side shorting your 4-in-1. A 7.5a fuse protects you from this.
Old Mar 19, 2007, 06:10 AM
bhbuster is offline
bhbuster's Avatar
Huntsville, TX.
Joined May 2006
This happened within a matter of minutes (between batteries) on a heli that was 3 weeks old.
Brian
How do you know when you are going out of range? Smokescreen38 Beginner Training Area (Aircraft-Electric) 16 Dec 03, 2005 06:30 PM
Dumb question: How do you know when your batteries have had it for the day? steve crewdog Radios 4 Sep 04, 2005 05:55 AM
How do you know when a motor is bad?? jacksonjrs Power Systems 9 Feb 20, 2004 05:09 PM
How do you know when your motor is toast American Flyer Parkflyers 12 Jul 08, 2003 02:28 PM
how do you tell when your motor's going bad waagbuck Parkflyers 10 Sep 23, 2002 09:21 PM
