Old Oct 16, 2002, 09:31 AM
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
New Model
Well i got the next version mostly done.
It has about a 40" wingspan with 286 sq. inch or about 2 sq. ft. of wing area. Made from depron with carbon rod leading edge and balsa reinforcement in the middle area of wing. Servos are pull-pull and the ductfan is mounted on top.
With 2 CS-10 servos, Rec., Spd. Cntrl., GWS Duct fan, it works out to be about 3.9 oz. With my lith-ions and ready to fly right at 5.9oz.
So wing loading about 3oz./sq. ft.
Will try it out Thursday
Will send pictures soon.
SPFD
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Oct 17, 2002, 10:41 AM
INDORUS EXPARAMINTO
Joined Jul 2002
Wings Flys
Hey Folks
Well I was amazed. The plane FLYS GREAT
I was worried about the fan providing enough thrust.
Don't Worry - Be Happy
The plane took right to the air and after a little bit of trim and throttling back it was flying smoothly.
It will fly on about 1/3 throttle and really moves with full throttle. Did not want to overstress the airframe to soon so I held back on some of the pylon turns and loops.
Glides very well. ( faster then the Big Wing ) but will slow down nicely. Not much trim change needed between throttle settings(None)
Will have pictures when my buddy Don Mondica e-mails me the photos. (This afternoon I hope.)
SPFD
Latest blog entry: Grunt
Old Oct 17, 2002, 12:48 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Flying Wing Pictures
Here are some shot.Just added some video.10/29/02
click this link
http://laskren.rchomepage.com/video1/ductfanwing.wmv
Last edited by SPFD-E-FLYER; Oct 14, 2004 at 06:13 PM. Reason: NEW HOME FOR MY VIDEO
Old Oct 17, 2002, 12:50 PM
INDORUS EXPARAMINTO
Joined Jul 2002
more Flying Wing
View of top
Old Oct 17, 2002, 12:51 PM
INDORUS EXPARAMINTO
Joined Jul 2002
flying wing
bottom
Old Oct 17, 2002, 12:53 PM
INDORUS EXPARAMINTO
Joined Jul 2002
flying Wing
Size difference
Old Oct 17, 2002, 01:28 PM
Arizona Rim Country
Joined Nov 2001
SPFD
Its great watching watching this design unfold !
Such a simple thing, so many possibilities.
We have some time aloft contests and I'm thinking the big one might be a winner
pcaffeldt is offline Find More Posts by pcaffeldt
Old Oct 17, 2002, 05:55 PM
INDORUS EXPARAMINTO
Joined Jul 2002
More Photos
Size Difference
Old Oct 18, 2002, 10:32 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Just added a tailcone to the DuctFan The guy at Airomicro That he gets more thrust with the inlet ring and tailcone.
Used a balsa nosecone from old rocket parts. (I wonder if those old C & D motors work )
Will let you know hou it flys Saturday
SPFD
Old Oct 19, 2002, 03:42 PM
Oakdale, MN, USA
Joined Sep 2001
questions. . .
Hey, SPFD-E-FLYER! Coupla questions, if you don't mind.
How does your fan behave on that diet of Li-ion (X3) cells? Isn't that rather more volts than the GWS fan can take?
Also, I can't quite make out the details of your pull-pull configuration. It looks like it somehow makes a turn out mid-wing someplace. How are you doing that?
And lastly, if I haven't been pest enough, where on EARTH are you finding 40 inch sheets of Depron where you are? Care to share?
Best regards,
Dale Case
Dale Case is offline Find More Posts by Dale Case
Old Oct 19, 2002, 07:03 PM
Walled Lake, MI, USA
Joined Feb 2000
SPFD, this is really interesting. I am really fascinated by the shape of the Air Surfer wing. As I pointed out in another thread, the designer has some pretty strong credentials:
http://www.rcgroups.com/forums/showt...486#post546486
You have done a great job of scaling it up. Your smaller wing is getting close to the size I had in mind for one I wanted to power with a direct drive GWS EDP-50 (IPS) motor with 3x2 prop on a couple of Li-poly cells. I'll have to buy one of the original Air Surfer wings to fool around with in my living room over the winter. There are all kinds of different possibilities with different scales of the wing using different size motors. Very cool.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Oct 22, 2002, 08:09 AM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
Very Interesting!!!!!
Have built several glider versions UP to 48" span....amazing!!!!..nice powered version SPFD-E...like that pull pull setup...will use flexible soda straw glued to wing (to make that turn)for my guides...thanks for paving the way!!!
gpw is offline Find More Posts by gpw
Old Oct 22, 2002, 07:52 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Got Video
Hey Folks
I reworked my pull-pull system and it works good now.
Got some video and i am going to take the digital 8 and convert it to something the computer can use, but i need someone to post it.
Does anyone know somebody that can do that.
Flew over 35 min. tonight in my back yard on my qualcomms
with both planes.( Duct fan and the Big guy.)
Dale: I use the 2 cell qualcomms not 3 cells so I have not notice any problems so far. My wing is 2 pieces. Glued in the middle with the balsa spanning over the joint and then taped.
If you find that big of depron let me know.
Dave: I read some of your post and that helped me along.
I saw tha micro flight version but I notice he did not say anything about how well it flew with the aileron in the center of the plane. I had to move mine out to the wingtips. They did not work in the middle.
Got some SMALL actuaters, small motors and some lith-polys cell to try to make a smaller wing ( 20" maybe or smaller. Need to do some figuering)
Let you know.
SPFD
Old Oct 23, 2002, 06:31 PM
Virginia
Joined Jun 2002
video
I can post your video for you if it's 10 megs or less, e-mail it to me if you would like me to put it up.
EJ
EJay is offline Find More Posts by EJay
Old Oct 23, 2002, 06:34 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Video
Hey EJay
Took the dig8 in to get a DVD made. They said it will be a day or two.
Will bring it into the computer and see if I can make something that would work.
Thanks for you help.
SPFD
POWER AIR SURFER Radio Controlled Plane R.C. 49 MHz mrlepp Parkflyers 1 Jul 18, 2008 09:34 AM
Wow Wee Air Surfer?? Flynder Foamies (Kits) 8 Aug 27, 2003 11:11 AM
Air surfer and RFFS-100 hobbymart Indoor and Micro Models 9 Dec 08, 2002 12:06 AM
anyone modified a hasbro power air surfer? usare Foamies (Kits) 2 Dec 07, 2002 11:59 PM
Hasbro power air surfer usare Foamies (Kits) 1 Nov 01, 2002 12:00 PM
