Old Oct 10, 2002, 02:20 PM
SPEED-E-FLYER is offline
Find More Posts by SPEED-E-FLYER
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
Cool
Air Surfer Big Brother - Fanfoam Wing
Just thought you might like to see my new flying wing
It is a modification from a "AIR SURFER" glider.
Scanned the glider, brought it into autocad, enlarged it. and started to make all different sizes till I ended up with this.
wing span 65"+/-
total wing area 700 sq. inch about 4.86 sq.ft.
weight 8.5 oz. 10.5 with batt.
wing loading 2.16 oz/ft ready to fly
motor GWS-A works but I am using a duel GWS-B with 1260 prop
GWS speed control, receiver
2- CS-10 servos on the wings
Started out with the ailerons in the middle section but they did not work very well(Adverse yaw), had to move them to the outer wing tips. Worked Great. I've been flying it indoors at the soccer dome and it flys so smooth . it banks very gracefully.. It does not need any vertical surfaces. Flys outdoors very well. It glides great and the birds like it too.
VIDEO http://laskren.rchomepage.com/video1/bigbrother.wmv
SPFD
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Oct 10, 2002, 02:21 PM
INDORUS EXPARAMINTO
Joined Jul 2002
more pictures
wing in flight
Old Oct 10, 2002, 02:22 PM
INDORUS EXPARAMINTO
Joined Jul 2002
more pictures
fly by
INDORUS EXPARAMINTO
Joined Jul 2002
photos
still more
Old Oct 10, 2002, 02:24 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Scanned image
This is what I started with
Old Oct 10, 2002, 02:29 PM
Vinnya42 is offline
Find More Posts by Vinnya42
Lifes 2 short, go sloping
colorado @ 5500feet
Joined Sep 2001
Awsome I bet thing just floats all day, It is clean and simple and cheap...what could be better!
Vinnya42 is offline Find More Posts by Vinnya42
Old Oct 10, 2002, 02:47 PM
pick is offline
Find More Posts by pick
San Diego, CA
Joined Jul 2002
Very nice
What kind of gear ratio does it use? Is it just one layer of FanFold foam? What kind of outdoor flight times do you achieve.
I want to make something like this in the future.
Todd
pick is offline Find More Posts by pick
Old Oct 10, 2002, 03:49 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Hey Pick
It is one layer of Blue fan flod foam glued in the middle.
It does not do well in high-g, but for gliding around it is just great.
I am working on a smaller version of the wing using a GWS-DFU-50 with depron. Aprox 40" wing span and I will use some reinforcement with carbon rod on the leading edge and a extra layer of depron in the across the middle 1/3 section.
As far as gear ratio look up on the GWS web site . It works with the A motor but it climbes better with the C or the dual motor.
With the light wingloading and a little breeze it flyes forever outdoors. I am using some cell phone litho- ion and I dont have the time to fly all day, but I think it would easy fly for 30 min.
Here is the cross sect. view. If you can find the AIR SURFER foam glider at a toy store(TOYS-R-US) it should all make sense.
SPFD
Old Oct 10, 2002, 08:21 PM
Dale Case is offline
Find More Posts by Dale Case
Oakdale, MN, USA
Joined Sep 2001
SPFD-E-FLYER,
You should be applauded for breaking this new ground. I think this is very cool! You didn't have any photos of the bottom of the wing, and I'd love to see how you did your battery install.
I wouldn't think that a plane of this format would be required to do aerobatics or things of that nature. This is obviously a "floater" that has to be treated more delicately than your typical Zagi.
Couple of questions for you:
Had you considered a pusher configuration for saving on broken props? and
What do you have for reinforcement of the wing joint? At this span there is a lot of leverage on the center section, assuming that is where the joint is.
Regards,
Dale Case
Dale Case is offline Find More Posts by Dale Case
Old Oct 10, 2002, 08:37 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Hey Dale
Hey Dale
The two half are joined with supergold CA and Tape.
Yes their is some flex in the wing but this plane was made for more of a indoor flyer or for a calm wind not for high speed. I made it up in an afternoon and was amazed it flew so well. The guy's at the dome where I fly thinks it's pretty neat.
I wish you could see it fly.
The bottom has some velcro about 2" from the leading edge.
As for the pusher design. Give it a shot. It can fly so slow that I can hand catch it easily. It might be a little tricky to get the C of G
right with the motor in back.
Thank for your reply
SPFD
Old Oct 13, 2002, 02:49 PM
INDORUS EXPARAMINTO
Joined Jul 2002
Photos
More pictures
Old Oct 13, 2002, 03:08 PM
tpgbill is offline
Find More Posts by tpgbill
Memphis, Tn USA
Joined Mar 2001
What a great idea! I have had one of the"Air Surfer" planes for a while and enjoyed playing with it but never thought to "super size" it. Just hope I can figure out everything you did to make one.
tpgbill is offline Find More Posts by tpgbill
Old Oct 14, 2002, 01:52 PM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
Air Surfer - plan
Did you say that you've scanned the plan. If you have would you share it ?
Thanks !
Paul
wfj616@co.hennepin.mn.us
pcaffeldt is offline Find More Posts by pcaffeldt
Old Oct 14, 2002, 11:57 PM
tpgbill is offline
Memphis, Tn USA
Joined Mar 2001
Did you mold the undercamber airfoil like the Air Surfer? If so, how did you do it? I would like a copy of the scan too, please. I had just bought a supply of fan-fold when I saw your thread, maybe I need to get some more!
e-mail hcabill@bellsouth.net
Old Oct 15, 2002, 07:25 AM
INDORUS EXPARAMINTO
Joined Jul 2002
Air Foil
Tpgbill
Yes it is undercamberd like the surfer. I did it with a heat gun and a little time.
LOL
SPFD
POWER AIR SURFER Radio Controlled Plane R.C. 49 MHz mrlepp Parkflyers 1 Jul 18, 2008 09:34 AM
Wow Wee Air Surfer?? Flynder Foamies (Kits) 8 Aug 27, 2003 11:11 AM
Air surfer and RFFS-100 hobbymart Scratchbuilt Indoor and Micro Models 9 Dec 08, 2002 12:06 AM
anyone modified a hasbro power air surfer? usare Foamies (Kits) 2 Dec 07, 2002 11:59 PM
Hasbro power air surfer usare Foamies (Kits) 1 Nov 01, 2002 12:00 PM
