Old Mar 17, 2007, 09:55 PM
ewastenw is offline
Find More Posts by ewastenw
EwasteNW
Milwaukie OR
Joined Mar 2007
Power wheels toy remote conversion
Hay I thought this would be fun for me and my son to do. Convert a toy electric ride on power wheels into an electric remote control vehicle.
Ok I don't know what size servo i will need for this. The truck has plastic wheels so not much resistants when turning. Also speed control. This is just something out of the ordanary to try and have funn doing it.
ewastenw is offline Find More Posts by ewastenw
Old Mar 18, 2007, 12:35 AM
mtfly2000 is offline
Find More Posts by mtfly2000
mtfly2000's Avatar
washington
Joined Dec 2006
Here's a link of castle creations doing it.
http://www.rcgroups.com/forums/showthread.php?t=587537
You may want a pretty heavy duty servo; I imagine you might even need two heavy duty servos if you're gonna put a kid in it. http://www.hobbypeople.net/gallery/759513.asp
as far as esc, you might be able to get an unlimited one, but it's expensive and I think you'll still run the risk of burning it up (if you put a kid in it). I would try a light switch dimmer (rated for 15amp @110v, it should be good for about 1500watts ~ 2hp) operated by a standard servo. Good Luck, give us a progress report.
mtfly2000 is offline Find More Posts by mtfly2000
Old Mar 18, 2007, 11:18 PM
E-maxx00 is offline
Find More Posts by E-maxx00
Joined Mar 2007
Simple Solution For ESC
why not rig the factory one
E-maxx00 is offline Find More Posts by E-maxx00
Old Mar 20, 2007, 07:14 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Originally Posted by mtfly2000
. I would try a light switch dimmer (rated for 15amp @110v, it should be good for about 1500watts ~ 2hp) operated by a standard servo. .
A light dimmer would not work like you think. Light dimmers are designed to work on AC not DC.
As for the factory one, it's an on/off switch.
green-boat is offline Find More Posts by green-boat
Old Mar 20, 2007, 10:42 PM
E-maxx00 is offline
Joined Mar 2007
Not to be sacastic or antything
But wouldn't a riding lawnmower be ideal
One of my future ideas
Old Mar 21, 2007, 11:37 AM
mtfly2000's Avatar
washington
Joined Dec 2006
Actually, it should work just fine. A simple dimmer switch is a rhostat, a potentiometer, or variable resistor (if you have an electrical store you could buy one in it's basic form). AC/DC won't make a bit of difference. It would only be an issue if the motor was an AC motor, which it is not. And I agree, the original on / off switch wouldn't be as classy as a variable speed set-up.
Old Mar 21, 2007, 11:38 AM
mtfly2000's Avatar
washington
Joined Dec 2006
You, gonna make your own servo?
Old Mar 21, 2007, 09:36 PM
E-maxx00 is offline
Joined Mar 2007
Yes making own servo
Old Mar 21, 2007, 10:00 PM
mtfly2000's Avatar
washington
Joined Dec 2006
Out of what? a 540 motor? That would be interesting.
Old Mar 21, 2007, 11:07 PM
E-maxx00 is offline
Joined Mar 2007
Possibly the mechanism for power seats
Old May 27, 2008, 07:17 PM
pmilano1 is offline
Find More Posts by pmilano1
Joined May 2008
Still an ongoing project?
I just picked up a one seater power wheels pickup chassis, the kind with 2 batteries.
It seems like a perfect candidate for this conversion to RC.
Do you have any insight as to what you used? Normal relays for forward/reverse high/low?
What about steering? Have you figured out anything that will center?
Lots of questions!
I did a gas conversion a few years back. Nothing fancy, just a weedwacker motor on a mower differential.
I have an anxious 10y/o!
Pete
pmilano1 is offline Find More Posts by pmilano1
Diary of a Toy Foamie Conversion - Guillow's Flying Eagle Project Mr.RC-CAM Foamies (Kits) 45 Mar 19, 2004 12:16 PM
Power system for hlg conversion KevinW Electric Sailplanes 4 Sep 25, 2003 04:59 PM
Power sytem for glider conversion? raabid Beginner Training Area (Aircraft-Electric) 2 Mar 07, 2003 11:01 AM
Power plant for Glow Conversion? Rob Schaffer Power Systems 3 Nov 26, 2002 06:59 AM
Pow Pow Power Wheels Now your drivin for real! JStory Electric Plane Talk 1 Nov 01, 2001 11:18 PM
