Old Oct 10, 2002, 10:58 AM
Lino Lakes, MN, USA
Joined Dec 2000
Prop saver for GWS IPS systems
I have just put together a short article on how to make a prop save for the GWS motor systems. It is posted at our clubs web site under the articles section.
www.marcee.org'
Here is a picture:
GHarvey is offline Find More Posts by GHarvey
Old Oct 10, 2002, 11:54 AM
I'll have the roast duck
maximus's Avatar
oakland, ca
Joined Jun 2001
Looks good but you should bottom the severo horn out on the shaft then cut off the remaining threads. It will help limit bending of the shaft.
maximus is offline Find More Posts by maximus
Old Oct 10, 2002, 12:36 PM
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi GHarvey, nice web site and good article.
Check out this thread by Tim_J-Rome from December 2001:
http://www.rcgroups.com/forums/showt...984#post153984
BC
Basketcase is offline Find More Posts by Basketcase
Old Oct 10, 2002, 01:03 PM
Lino Lakes, MN, USA
Joined Dec 2000
Original ideas are hard to come by...but it's still a good one. Wish I could get ahold of some braces rubber bands, but the O-Rings work well.
Old Oct 10, 2002, 02:44 PM
..teach monkeys to fly..
Marten's Avatar
Ottawa Intl, Canada
Joined Oct 2000
I swiped a bunch of little elastics that my daughter uses to tie her hair back. You might need more than one, but it works well. I'm still on my original 10x4.7.
Marten
Marten is offline Find More Posts by Marten
Old Oct 10, 2002, 03:42 PM
Space Coast
Space Coast
Joined Oct 2000
Dec2001, how about Mar 2001 ,
see http://12.45.56.6/~birdworks/buddrive.html
hoppy
hoppy is offline Find More Posts by hoppy
Old Oct 10, 2002, 04:22 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Yep, Like GHarvey said, good ideas are hard to come by.
And the really good ideas get spread around.
Old Oct 10, 2002, 06:29 PM
Vermont
Joined Mar 2002
I saw that GWS saver as well. Too bad they show it with the shaft still extended through the prop. That will keep it from being saved.
fdisk is offline Find More Posts by fdisk
Old Oct 10, 2002, 07:26 PM
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
Fdisk
you are right
GWS really likes the users to use the "safety spinner"
Gharvey
Why would you want a long prop shaft?
frankenfoamy is offline Find More Posts by frankenfoamy
Old Oct 10, 2002, 07:51 PM
Vermont
Joined Mar 2002
I have kept my shafts full length up till now in case I want to use the motor on a different plane and run a standard prop config.
The only problem I have had so far was a 40' straight down dive when a hornet distracted me while windy flying. The impact divided the spur gear in 1/2 and fragmented the gearbox. Maybe ... just maybe I would have had less damage with a shorter shaft.
I find the spinners make great replacement caps for my CA bottles. They fit well, don't seem to stick and have a larger area to grab on to.
Old Oct 10, 2002, 10:23 PM
galloping gimp's Avatar
Ohio, USA
Joined May 2002
If you don't have an spare servo arm, a piece of a popsicle stick or 1/16-inch plywood will work just as well:
Secure the piece of wood with the original GWS nuts and washers. Unlike the example above, you'll want to shorten the shaft to reduce the chances of bending it in a severe impact.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Help! Prop Saver for GWS Schnupper Power Systems 4 Jan 02, 2007 05:20 PM
Slofly Multi Prop saver for APC, GWS DD and SF!!! sloper steve Product Announcements 0 Mar 22, 2005 09:58 AM
Prop saver for GWS props frankenfoamy Electric Plane Talk 6 May 20, 2002 02:48 AM
GWS inner adpters for GWS IPS & EPS converted with other Propellers! GWS4CEO Parkflyers 5 Dec 12, 2001 12:55 PM
Heatsink for GWS IPS Crash King Parkflyers 20 Jul 22, 2001 01:03 PM
