Old Mar 15, 2007, 11:29 PM
slo123 is offline
Find More Posts by slo123
Joined Nov 2006
Can I just unplug the stuff from the 4-in-1 on the honey bee 2 fp?
CAn I unplug the motors so I can check stuff without the risk of catching rotors in my eyes? Will there be any problem when I plug them back in?
Any help or info on this would be appreciated
slo123 is offline Find More Posts by slo123
Old Mar 15, 2007, 11:30 PM
SinxarKnights is offline
Find More Posts by SinxarKnights
Moorefield, WV
Joined Feb 2007
Yes you can. Just make sure you either label where it goes or something.
SinxarKnights is offline Find More Posts by SinxarKnights
Old Mar 15, 2007, 11:45 PM
slo123 is offline
Joined Nov 2006
ok so it won't mess anything up or nothing like that? I can unplug and replug them as much as I need?
Old Mar 15, 2007, 11:49 PM
slo123 is offline
Joined Nov 2006
OK I'm not realy sure how to disconnect them in the first place, can you tell me ? I don't wanna rip something out you know.
Old Mar 16, 2007, 12:44 AM
4RCHELICOPTERSPA is offline
Find More Posts by 4RCHELICOPTERSPA
Joined Sep 2005
You can unplug it - 100% sure. I did that a lot
4RCHELICOPTERSPA is offline Find More Posts by 4RCHELICOPTERSPA
Old Mar 16, 2007, 12:45 AM
Joined Sep 2005
Just remember to connect them back properly
Old Mar 16, 2007, 05:51 AM
TachyonDriver is offline
Find More Posts by TachyonDriver
21st Century Space Cowboy
TachyonDriver's Avatar
Chipping, Lancs, UK
Joined Oct 2006
Main motor - trace the wires back from the top of the motor. You should find a red JST connector, just grab both bits of red plastic and gently pull apart, same as disconnecting your battery. Same applies to the tail motor - there should be a connector for that before the wires go into the tail boom.
Tach.
TachyonDriver is offline Find More Posts by TachyonDriver
Old Mar 16, 2007, 06:09 AM
bhbuster is offline
Find More Posts by bhbuster
bhbuster's Avatar
Huntsville, TX.
Joined May 2006
Remember the orientation of the wires - (such as: red wire on top of black wire or black wire on top of red wire) when you plug it back in. Otherwise your motor will spin in the wrong direction.
You will know when you give some throttle -
the rotors should spin clockwise - if not, then wires are upside down
main rotor will spin first - if tail spins, then you have tail motor in the main motor plug.
Brian
bhbuster is offline Find More Posts by bhbuster
Old Mar 16, 2007, 06:11 AM
Chipping, Lancs, UK
Joined Oct 2006
The plugs shouldn't allow you to connect stuff the wrong way, my jst connectors don't. Of course, if you've de-soldered the wires.....
Old Mar 16, 2007, 10:32 AM
PLATINUM is offline
Find More Posts by PLATINUM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
.. LOOK at the 4-1 where it shows a small +/-
be sure the plug it in with the red on +, the top is opposite from the bottom.
I do suggest you unplug power, unplug motors, then replug power..
and yes it is safe.
PLATINUM is offline Find More Posts by PLATINUM
Discussion Honeybee CP/FP 4-in-1 on a Lama Xptical Micro Helis 0 Dec 11, 2006 08:20 AM
Question Can i program my JR 9303 to a 4 in 1 from the BLADE CP??? timphan84 Micro Helis 2 Aug 02, 2006 11:40 AM
Discussion did i fry something in my 4-in-1 on my BCX? heligrom Coaxial Helicopters 4 Feb 13, 2006 09:43 AM
smoked 4 in 1 on Blade CP dave morris Micro Helis 6 Sep 28, 2005 03:11 PM
How to convert from 4-in-1 to separates? Danny Troy Micro Helis 23 Nov 04, 2004 03:13 PM
