Old Mar 15, 2007, 09:10 PM
Mike_eee is offline
Find More Posts by Mike_eee
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
New Product
new mirage 2000 at hobby lobby
check this out
http://www.hobby-lobby.com/mirage.htm
25" wingspan, 38-1/4" long, 19 oz. flying weight. All molded bead foam construction, pre-painted with electronics pre-installed. The radio is a 4-channel 72 MHz transmitter with a 6-channel receiver. Three pre-wired 9-gram servos control the elevons and the steerable nose wheel, which is pre-installed. Assembly is quick; the main wings are "keyed" to the fuselage for perfect fit and must be glued with epoxy. 20 amp speed control and ducted fan unit with powerful inrunner brushless motor is pre-installed and ready to run. Power is supplied from the included 3-cell Lipoly battery. A dedicated wall plug-in Lithium battery charger is included for charging at home (for quick field charging order ETC2500, available separately). The tricycle landing gear provides good ground handling; takeoffs from a smooth surface are quick. Mirage is a smooth performing aircraft, rolls are axial, inverted flight is
easy and the flight speed is moderate. The delta wing will slow down well for landing and still remain very stable. Flight times are in excess of 10 minutes.
what do u guys think??? anyone already have it???
Mike_eee is offline Find More Posts by Mike_eee
Old Mar 15, 2007, 09:18 PM
Mig17 is offline
Find More Posts by Mig17
Mig17's Avatar
Seattle WA
Joined Jan 2002
It looks like it flies really well. Too bad they dont sell the airframe by itself or I would get one and repaint it in a gray camo scheme.
Mig17 is offline Find More Posts by Mig17
Old Mar 15, 2007, 10:41 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
oh man! that thing flys great! it would be sweet...but i cant afford that much. id also like a bare bones version...c'mon HL, you guys can do that cant ya? youd seel a ton that way! really looks great in the air. cant wait to see more of them around!
corsair nut is offline Find More Posts by corsair nut
Old Mar 16, 2007, 11:11 AM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Oh Baby that's purty! It needs an XF and JS on 4s though
rvincent is offline Find More Posts by rvincent
Old Mar 16, 2007, 12:37 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Is that the same as the Kamdax Mirage or slightly different? I don't recall the length of the kamdax, don't even know if you can still get them, mine's in the garage unbuilt, it will need an intake mod, too small up front.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Mar 16, 2007, 01:08 PM
darmar is offline
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
I wish they had an arf available. Anything else is waste of hard earned money.
darmar is offline Find More Posts by darmar
Old Mar 16, 2007, 01:16 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
That new mirage 2000 is about the size of the Kamdax Mirage 2000.
And I flew the Kamdax with 68mm minifan fan .
Rule of thumb For ducted fan jet:
"the larger the fan you can put in the jet the better, period."
rcguy01 is offline Find More Posts by rcguy01
Old Mar 16, 2007, 06:42 PM
Toker is offline
Find More Posts by Toker
Joined Nov 2006
Interesting. Looks a bit slow, though. What kind of flight time should I expect on that 1200mAh included battery? What exactly is a "dedicated wall charger"? Does that mean that the battery doesn't have to be removed from the plane to charge? What C rate is the battery?
Sorry about all the questions, but I've learned to ask a lot of questions before putting out more than $200 for a piece of foam. I'm a bit disappointed in my Red Arrows hawk, and don't' want to make that same mistake again.
Sure wish I could find a jet that was quick and not made of foam for $200 or less.
Toker is offline Find More Posts by Toker
Reply With Quote  (Disabled)
Old Mar 16, 2007, 07:05 PM
Jason Cole is offline
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
You'll get at least 10 minutes of flight time. The battery is removeable and has a neat little hatch on the bottom to get to it. It comes with a wall charger, but you'll probably want to use your own field charger anyway. I'm not sure what C rating is on these batteries. All I can tell you is that it is way fun to fly and lands like a dream.
Jason Cole
Hobby Lobby
Jason Cole is offline Find More Posts by Jason Cole
Administrator
Old Mar 16, 2007, 07:06 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
You can it's called the Kyosho Illusion.
Old Mar 16, 2007, 07:07 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
And Bruff has a RTF one with electronics for sale right now in the Jets Classifieds here on RCG! (An Illusion that is!)
Bajora is offline Find More Posts by Bajora
Old Mar 16, 2007, 07:36 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
I would love to get one of these Mirages! Ie looks like a great edf trainer. It's not advertised as the hottest key out there, it's meant to bed exactly what it is. If they do offer them as ARF's, I'm sure they will sell out very quickly
Old Mar 16, 2007, 07:45 PM
mode101 is offline
Find More Posts by mode101
mode101's Avatar
Wellington, Florida
Joined Oct 2005
I like this one better.
http://www.rcgroups.com/forums/showthread.php?t=651632
mode101 is offline Find More Posts by mode101
Old Mar 16, 2007, 11:14 PM
Duke58 is offline
Find More Posts by Duke58
Whispers to the Wind
Duke58's Avatar
Hayward, CA
Joined Apr 2001
That looks slick ! and where can I get some of those cooling fins for the motor?
Earl
Duke58 is offline Find More Posts by Duke58
Old Mar 17, 2007, 04:28 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Originally Posted by mode101
That one is actually smaller. it has a 21" wingspan compared to the one Hobby-lobby is offering at 25"
kahloq is offline Find More Posts by kahloq
New Product New Me-262 at Hobby-Lobby Ramones, The Electric Warbirds 210 Nov 22, 2006 05:29 PM
Interesting new planes at hobby lobby!! flying_pig Foamies (Kits) 0 Jan 28, 2002 07:14 PM
New Sailplanes at Hobby Lobby Larry Eddy Electric Sailplanes 2 Oct 26, 2001 09:23 PM
New "Sale Items" Page at Hobby Lobby Greg Covey Vendor Talk 1 Sep 25, 2001 01:02 PM
New Airplanes At Hobby Lobby greg morrison Electric Plane Talk 2 Jun 01, 2001 12:06 AM
