Old May 28, 2007, 10:55 PM
erich is offline
Find More Posts by erich
erich's Avatar
Holden , Massachusettes
Joined Feb 2004
Yea, you did. Once.....
Green air
erich
erich is offline Find More Posts by erich
Old May 29, 2007, 07:21 AM
Wilian Amaral is offline
Find More Posts by Wilian Amaral
SENTA A PUAAA!!!
Wilian Amaral's Avatar
Brazil, RJ, Miguel Pereira
Joined Apr 2007
Thanks for the information, Erich!!!
Keep doin´ this great job!
Kind hugs,
Wilian
Wilian Amaral is offline Find More Posts by Wilian Amaral
Old May 29, 2007, 08:44 AM
erich is offline
erich's Avatar
Joined Feb 2004
Covering
The cover up continues. Did rear sides, with the natural solartex. Am leaving rear bottom open till the control wires are installed and tested.
erich
Old May 30, 2007, 03:57 AM
erich is offline
erich's Avatar
Joined Feb 2004
Time to cover the main part of fuselage. Am going with the olive drab for entire front of fuselage. Believe it looks better with the aluminum cowl. Did this section using 2 pieces of the Solartex. Started on center line top. After marking location of cabanes and cutting them out, worked my way down from top to bottom. The top and back edges I had cut before ironing on the Solartex. The bottom was cut after all the Solartex was ironed on. Overlapped under cowl area about 1/4". Even with all the curves in this area, not even a hint of wrinkles. Went over area well, with a hotter setting to make sure of a good wood to cover bond.
After finishing with the Solartex, was anxious to start staining the cabanes. So..completely forgot to take photos, until after I had already taped down the area under cabanes with wax paper, and glued on the cabane wood thingees. Well at least the struts area ready for the finish.
erich
Old May 30, 2007, 04:06 AM
erich is offline
erich's Avatar
Joined Feb 2004
Fuselage Covering Continues
Time to cover the main part of fuselage. Am going with the olive drab for entire front of fuselage. Believe it looks better with the aluminum cowl. Did this section using 2 pieces of the Solartex. Started on center line top. After marking location of cabanes and making cutouts, ironed on the Solartex, down from top to bottom. The top and back edges I had cut before ironing on the Solartex. The bottom was cut after all the Solartex was ironed on. Overlapped under cowl area about 1/4". Even with all the curves in this area, not even a hint of wrinkles. Went over area well, with a hotter setting to make sure of a good wood to cover bond.
After finishing with the Solartex, was anxious to start staining the cabanes. So..completely forgot to take photos, until after I had already taped down the area under cabanes with wax paper, and glued on the cabane wood thingees. Well at least the strut covers area ready to be stained and sealed.
erich
Old May 30, 2007, 04:39 AM
adamtc is offline
Find More Posts by adamtc
adamtc's Avatar
Southampton ,England
Joined Oct 2006
Kinda looks like a big dead creature lying upside down....
I dare not ask what colour the cabanes will be........(yellow????)
adamtc is offline Find More Posts by adamtc
Old May 30, 2007, 05:00 AM
erich is offline
erich's Avatar
Joined Feb 2004
Yellow....hmmmm....I may have been a little hasty with my choice of antique walnut. Hey I can always paint em yellow later. Does sorta look like a dead..headless horse.
erich
Old May 30, 2007, 05:30 AM
adamtc is offline
adamtc's Avatar
Joined Oct 2006
Antique walnut?? are you nuts?
Old May 30, 2007, 09:32 AM
irish_lord99 is offline
Find More Posts by irish_lord99
Balsa for me, thanks.
irish_lord99's Avatar
Yalova, Turkey
Joined May 2007
Dude, there's nothing wrong with walnut!!! Go with natual wood, man, run with it!!!
Seriously, I think that having natural wood showing on a plane of that era is awesome.
Just my two cents worth.
irish_lord99 is offline Find More Posts by irish_lord99
Old May 30, 2007, 10:34 AM
erich is offline
erich's Avatar
Joined Feb 2004
Adam
In answer to your question. Hasn't that been made abundantly clear to you, by now.
You tell him lord99.
Anyway it's to late, got 3 coats of the stuff on already. Course I do have some latex offwhite, that had been used to paint the apartment a few years back. Could slap that over the antique walnut.
erich
Old May 30, 2007, 01:39 PM
Yalova, Turkey
Joined May 2007
NOOOOOOO!!!!!!!!!!!!!!!!
heh hee
Old May 30, 2007, 03:38 PM
erich is offline
erich's Avatar
Joined Feb 2004
Not to worry lord99, just trying to make Adam feel better, about a little event in 1776.
erich
Old May 30, 2007, 06:06 PM
Tim Farrar is offline
Find More Posts by Tim Farrar
Bi-Planes
Tim Farrar's Avatar
Houston Texas
Joined Apr 2006
erich :
Looking gooood !!!
Remember those plastic aints with different legs, antenna's, and arms that you put together how ever you wanted ? It was some sorta kids game.
Well thats what it looks like to me right now.
SEEYA, TIM
Tim Farrar is offline Find More Posts by Tim Farrar
Old May 30, 2007, 08:41 PM
erich is offline
erich's Avatar
Joined Feb 2004
Tim
Cooties maybe? When I finally get all the paint on her, hopefully she'll look like Cinderella, and not one of the less atractive stepsisters.
erich
Old May 31, 2007, 02:35 AM
adamtc is offline
adamtc's Avatar
Joined Oct 2006
1776?
You got me there? We did own a lot of countries back then and its hard keeping track of some of the smaller ones.....
Was it some local event?
Help! Flair Puppeteer MK II Wing-span Scale Fuel Planes 2 Aug 17, 2007 05:56 PM
For Sale Flair Puppeteer MK II Biplane erich Aircraft - Fuel - Airplanes (FS/W) 1 Jul 25, 2007 02:50 AM
Flair Puppeteer plan graham_mca Aircraft - Electric - Airplanes (FS/W) 1 Feb 23, 2003 10:52 AM
